Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X6 E71 / E72 (2008 - current)
The newest sport activity vehicle from BMW is a crossover-coupe style and is expected to appear sometime in 2008!
Old 01-30-2011, 03:04 PM
2011-X6-50i 2011-X6-50i is offline
Mein Auto: 2011 X6 50i
Burning oil?
Anyone in the forum experiencing the X6 burning synthetic?
Within the past 8k mile our X6 50i has evaporated at least 3 quarts of synthetic? if this is common please let us know...
Thank you,
Solu- Racing...
Old 02-01-2011, 02:48 PM
sdbrandon sdbrandon is offline
Mein Auto: 2012 535i
I had to add one quart over 33,000 miles of driving (between oil changes). It was around 18k miles or so.
I have heard that having to add one quart during the first 7500 miles is not uncommon. Or even 1 quart every 5-10k miles.
3 quarts within 8k miles seems rediculous. I would suspect rings, or poor engine build quality.
The darn thing only holds about 8 quarts of oil. And you lost about 40% of the oil within 8k miles. I don't think an M3 is that bad.
2012 535i
Old 02-04-2011, 02:08 AM
Scrib Scrib is offline
Scrib
Mein Auto: 2011 X6 35i/Past E90 335i
That is quite excessive oil burning unless you're driving her pretty hard. My 335i burned oil, but on the southern roads we have the opportunity to open the cars up quite a bit. Ya know blow off the dust>
Scribbie
Old 04-14-2011, 04:58 PM
cranfordguitar cranfordguitar is offline
Mein Auto: BMX x5 3.0 2007
My car was doing the same thing.. I took it in and now they are trying to charge me over 6k to fix it. They said it was the turbos.
Old 04-14-2011, 07:23 PM
sunstorm's Avatar
sunstorm sunstorm is offline
Be My Wife.
Send a message via MSN to sunstorm
Mein Auto: BMW, only BMW.
Around 600 miles burn 0.7L is BMW stander.
E38 X2 had. E39 X5 had. E46 X1 had. E65 X2 had. E71 X1 now. E84 X1 now. E90 LCI now. VW JETTA X2 had.
LOTUS ELISE SPORT X1 had. NISSAN BLUEBIRD U12 X1 had.
LEXUS SOARER 2.5T/T X1 had. CADI SRX X1 had.
Old 04-15-2011, 09:35 AM
cmyx6go cmyx6go is offline
Mein Auto: 2010 X6 50i
I burn a quart every 4500-5000 miles which is normal. Three quarts in 8000 miles seems a bit much. Get it checked out. Good luck.
Old 04-16-2011, 10:48 PM
sheardabili sheardabili is offline
Mein Auto: x6
mine was doing this and i was told it is normal it will burn 1ltr for every 1000 miles
Old 01-05-2012, 04:29 AM
brianraysmith brianraysmith is offline
Mein Auto: 2010 x6 hybrid
Heads up
My 2010 hybrid needed feeding after 8,000 new. then it settled down. The new 12 x6 550 needed feeding at the same time. HAve put another 2,000 miles on it over the holidays and it is sitting at just 1/4 below full....The last 2,000 was on hwy travel and a lot of open speed...8,000 and that muchoil does seem wrong. If they are charging 6,000.00 for correction is that not covered under your waranty? Are they giving you a hard time about covering it? We should all take note of this!
Old 04-14-2013, 04:06 PM
Kenny G Kenny G is offline
Mein Auto: BMW X6 5.0
My X6 is a 2012 5.0 with only about 11500 miles. This year i put on about 7500 miles from the last oil change and I poured in 1 quart of oil (BMW High Performance Synthetic). 3 Quarts seems a bit too much to burn... U should get that checked out.
