Old 03-07-2011, 05:53 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by Kelley71 View Post
So I put the Bars product HG1, half a bottle. ... Within 8 minutes the smoke a miss was GONE! ... The sodium silica and reenforced with carbon fibers seals the leaks and does not coagulate with anti-freeze. The best 65 I ever spent.
Wow. A miracle does come in a bottle!
I'm glad you have your engine back! This is a great reference thread for others. I already added it to the best links so others learn from all that you've done.
Thanks for helping out the team.
Kelley71 Kelley71 is offline
Mein Auto: 2000 E39 540IA Sport
The bars is fine. No fluid loss what so ever. I think I had a high place on the deck because the leak was fixed in less than 5 minutes once it started to circulate.
I drained that stuff out this weekend when I changed a rear heater hose. But I am satisfied with the result.
Old 03-07-2011, 05:54 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Car is doing great! Thanks for asking.
...I can say I know every bolt on the car now...
Hahaa, don't underestimate the evil geniuses in BMW engineering. They probably have a few more up their sleeves.
Old 03-07-2011, 06:03 PM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Good to hear!
Old 04-08-2011, 04:56 PM
franka franka is offline
Mein Auto: E39 540i Sport
Any updates? Still running well? Do you still feel strongly that Bars HG1 did trick?
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 04-09-2011, 09:43 AM
bluebee's Avatar
I will keep everyone informed on the effectiveness of the product.
Please do!
A few weeks ago I realized we didn't have a comprehensive answer of all available options for those whose cooling system overeating caused suspected blown head gaskets, cracked heads, warped blocks, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, and valve damage.
So, I've kept special note of the past two dozen or so sad stories of ruined E39 engines and the options people suggested, for example: (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24).
But, I don't remember this having been listed as an option in 'any' of those threads!
So, I'm adding a reference to here right now to the nascent pointer thread:
- What advice should we provide when a newbie asks for help with a blown E39 engine?
Thanks, and please 'do' keep us informed!
Old 08-23-2011, 09:29 PM
540i/msport/ 540i/msport/ is offline
Mein Auto: 1999 e39 v-8 6 speed
so what about the vanos ? anything special on re-assebly that you ran into with the vanos ? like adjustment or special tools other then the once you borrowed?
Old 09-09-2011, 09:27 AM
Flug540's Avatar
Today I removed the guide rails (glad I did now), cleaned the surfaces, installed new valley pan and cover, and finished the deck of the motor.
Now I am waiting on my heads, Vanos tools, and will have my valve covers powder coated.
Tomorrow I will change motor mounts.
See photos, thanks for all the insight from all you guys!
Kelley, I may need to go through a similar exercise soon. I read TIS and in order to remove the lower timing cover it wants you to drop the upper oil pan as well, which is a major pain. I see you got away without removing it, which I like very much, but a bit concerned about sealing of the lower timing cover with the upper pan after installation. Did you do anything special there to ensure a good seal, have you noticed any leaks?
Old 11-04-2011, 06:39 PM
windsmith windsmith is offline
Mein Auto: 1999 540iT
I need to get the Jesus bolt out.
I know that this is an older thread, but I thought I'd share my experience.
Back in 'the day' , with American cars, I'd just put a socket and breaker bar on the bolt, lay the end of it atop the frame on the driver side, and bump the starter. Worked every time. Can the crankshaft on the BMW handle that?
Old 11-06-2011, 05:39 AM
Burning2nd's Avatar
Under the lift arms
bad idea
15486372<-----
Old 01-27-2017, 01:22 PM
astone19 astone19 is offline
Mein Auto: 2002 540i, 2001 golf 1.8t
Hi everyone I know this is an old thread but I'm about to embark on doing my vanos and head gaskets in my m62tu,...I have the manual for the m62, but it doesn't cover the vanos on the TU, so my only concern is that it's the same proso
cedure (other then the vanos) to take off the heads...is the bolt pattern the same and the trq values? For the m62 it says they are trq'd to 80lbs then another 160 in 3 stages...I know you guys are all more knowledgeable then me lol but any tips or things u guys have encountered would be much appreciated. Between the manual and the printouts on the vanos I'm feeling confident, but I'm not sure about the heads thanks guys
Sent from my SM-G930W8 using Bimmerfest mobile app
Old 01-27-2017, 02:03 PM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
German Auto Solutions has some instructions on their website to go with the timing tools they sell, you might want to poke around there to see if the info you need is in them.
Before...
After...(this may take a few years, it's my DD and I have bigger projects)
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG (hello X7, and lottery!)
1999 BMW 740i - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 BMW 330xi - fXtXeX/son project time - still needs work but he's driving it
2008 BMW 335xi - quite the replacement winter beater for an Impala!
Old 01-27-2017, 04:36 PM
Burning2nd's Avatar
Under the lift arms
complete waste of time IMO
15486372<-----
Old 01-27-2017, 07:55 PM
berkeleydojah berkeleydojah is offline
Mein Auto: 2001 bmw 540i (sport)
Head gaskets are not really an issue with these engines unless you overheat (which could lead to other issues) but getting those exhaust header bolts are a nightmare especially the ones to the rear of the engine
