Old 02-01-2011, 08:44 AM
cambrian123456 cambrian123456 is offline
Mein Auto: 2000 528iT 153,000 km
Who sells a BMW ball joint press? (31 2 240)
Anyone know where I could buy a BMW ball joint press or alternatives to it?
Here's a picture of the tool from Beisan Systems:
Old 02-01-2011, 08:52 AM
kyle540i kyle540i is offline
Mein Auto: 98 540i
I got mine from Harbor Freight. $20.
I used a grinder to modify the fork so it would push on the ball joint stud in a straight line (as opposed to pushing it to the side & requiring more force).
It worked GREAT!
http://www.harborfreight.com/automot...tor-99849.html
Last edited by kyle540i; 02-01-2011 at 08:55 AM. Reason: add link to tool at harbor freight
Old 02-01-2011, 09:12 AM
cn90 cn90 is offline
The O.P. is from Canada, so no Harbor Freight.
Search ebay, you should be able to find one for $20 or so.
Old 02-01-2011, 09:31 AM
Mein Auto: 98 540i
Bummer, didn't know they didn't sell online to Canada.
Old 02-01-2011, 10:03 AM
Just got a quote from a local BMW dealership . . . $305.93 CAD!
Old 02-01-2011, 10:24 AM
Amazon has it.
Sears has it:
http://www.sears.com/shc/s/search_10...all+joint+tool
Old 02-01-2011, 01:07 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
You might be able to improve upon what is in the VERY best of E39 Links
- How to make your own ball joint replacement tool (1) (2) (3)
Old 02-01-2011, 01:30 PM
Bluebee,
The OP referred to the Front suspension ball joint tool.
The Rear ball joint tool is a different ballgame.
Old 02-01-2011, 01:50 PM
helpmyfive helpmyfive is offline
Mein Auto: 528i
This is funny! I have the front ball joint tool and swear by it. I've changed many ball joints and tie rods in my day without it, and just shake my head in how easy it is now. My humor comes from the fact that I am looking for the rear ball joint tool Bluebee mentioned. I too can't find it but in frustration walked over to the socket section at Napa. I found a socket that fits over the large collar to use as a receiver and a small one to use as a pusher. All I need now is the threaded rod which I plan to buy tonight. The two sockets were under $40 total. Now THAT is a home made tool!
Old 02-01-2011, 01:58 PM
Fudman's Avatar
Fudman Fudman is offline
That is for the official BMW ball joint tool. The BMW ball joint tool is superior to the Harbor Freight tool but for the $285 cost difference, it is not THAT much better. The BMW tool is pictured in the original post. That tool allows you to adjust the pivot point by shortening the middle bolt to keep the two arms parallel to improve purchase on the ball joint bolt. The Harbor Freight has a two position swivel only. Since the ball joint bolt is fairly long on the BMW (for sway bar links, control arms, & thrust arms), the HF tool tends to slip off the end of the bolt when tightening. Cam identifed a great trick: Leave the nut on the end of the bolt to increase surface area and improve tool purchase. An alternative, if you plan to toss the old part, is to cut the ball joint bolt about 3/4" - 1" from the end using a grinder. This shortens the bolt and allows much better purchase by the HF tool. Bottom line, get the HF tool and save the $285 for a different tool.
Old 02-01-2011, 03:11 PM
Mein Auto: 98 540i
I didn't like the Harbor freight tool out of the box. The geometry wasn't right - looked like it wanted to push the stud sideways or slip off.
So I used a grinder to shorten the fork & to open the slot a bit at the end so it would fit without the need for a hammer & without damaging the rubber boot.
It worked GREAT after that! I was able to get a straight push on the stud & they popped out with a lot less drama than I was expecting.
All that said, the quality & consistency of harbor freight tools isn't known to be the greatest. . . .
So, your mileage may vary . . .
Old 02-01-2011, 03:55 PM
Fudman's Avatar
I'd agree that the quality of HF tools is somewhat inconsistent but you can't beat the price! Most are serviceable but you find the occasional junk tool. I bought the HF spring compressor tool and it bent under load! Kinda scary!! But for the weekend warrior, I must say that most HF tools do a decent job and offer great value. You can use them once or twice and not worry about a $100 tool collecting dust in your box because it only cost you $20! I have a much larger tool collection now that I discovered HF!
Old 02-02-2011, 12:07 PM
bluebee's Avatar
Thanks Cam,
I never removed ball joints so I wouldn't know the difference.
Should I change this bestlinks reference:
To?
- How to make your own FRONT ball joint replacement tool (1) (2) (3)
Note: This picture below is from the #2 thread listed in the links above.
Old 02-02-2011, 04:20 PM
rdl rdl is offline
Mein Auto: 530i 2003
Princess Auto sells 2 of the scissor type ball joint tools. One is ~$32 and similar to the Harbor Freight pictures. I bought the $45 tool which has more range & adjustment as well as a pocket in the lever arm to locate the ball joint stud end. This one worked well for me. I recommend you grease the screw thread well. The lube as sold was not sufficient.
http://www.princessauto.com/view-all...rd1=ball+joint
Princess has half a dozen locations in Alberta, including two in Calgary.
Regards
RDL
Old 02-02-2011, 06:40 PM
Fudman's Avatar
The $45 tool looks nice. Those two extra pivot points should allow you to open up the jaws extra wide. It also looks like there is a little socket for the ball joint bolt to reside in. That'll help keep it from slipping off. Nice find!
Old 02-02-2011, 07:00 PM
Thanks RDL!
Old 02-02-2011, 07:34 PM
Mein Auto: 528i
F! I picked up a stainless carriage bolt, a few nuts, a 3 inch long nut, a threaded rod and a bunch of washers. I tried the carriage bolt first, but it started to spin, so I switched to the rod. Using the 3 inch long nut was a good call as it would never strip out. I cranked and cranked on the setup for quite a while with NO movement. I did get it to budge a little, but still wasn't going. I repositioned everything when it finally started to move. I got the one side out, got the new one in and stopped for the day. I am confident I can get the other side in in under an hour. My biggest mistake was the position of the huge socket on the back side to receive the joint. I had it just barely over the lip on the joint causing it to bind at first. The total cost of everything was under $70. I got the two sockets (only used one) for $20 each, and the threaded rod and all the parts were under $30. My joints were really frozen in there.
Old 03-16-2013, 06:43 PM
bluebee's Avatar
For the record, this was asked today:
Originally Posted by bin01123 View Post
Does anyone have a BMW Rear Ball joint tool for an E39? Or does anyone know of another tool that will work to remove and install a rear ball joint?
Old 03-17-2013, 07:33 AM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
Just for reference, Ive changed the tension struts on two E39s and didnt use the special tool. I just unscrewed the ball joint nut to the top of the stud and whacked it a few times with a 2 lb hammer. Popped right off. So one may not always need the tool. Sometimes you get lucky.
Old 07-20-2016, 04:44 PM
rbelton rbelton is offline
Mein Auto: E39
Old thread but this review is relevant for those still searching. Here's a quick review and demonstration of it working on my E39. I highly recommend this ball joint tool for the money.
Old 07-20-2016, 07:51 PM
nedmon nedmon is offline
Mein Auto: 1998 528i, 1987 Carrera,
I have a K D 3916 tool and it looks like the one pictured. About $30. It is a nice tool and makes popping a ball joint into a non event. Used it today when installing a new front wheel bearing.
Ned,
87 Carrera
07 CRV
13 328i
Old 07-21-2016, 06:13 AM
gmak2012's Avatar
gmak2012 gmak2012 is offline
Mein Auto: E60:M5 530xi E39:540 528
And yet you neglect to tell us where you bought this marvel.
Old 07-21-2016, 06:16 AM
gmak2012's Avatar
This is the one for sale on Amazon, IIRC. I've used it. Sometimes it's hard to get it in far enough on the thrust arm ball joint on an I6 - but that;s the ball joint's fault not the tool's.
Overall I'm happy with this one for the price. Just make sure that every few turns you inspect how the single arm is sitting on the stud of the ball joint - because every now and then it will be off by sub-millimeters which are enough to cause it to slip off as pressure is applied.
Old 11-13-2016, 05:35 AM
4thBMW 4thBMW is offline
4th BMW
Mein Auto: 2002 540iT Sportwagon
Anyone use this tool that looks very much like the baum tool from Pro Auto tools? >> http://www.ebay.com/itm/BMW-Rear-Axl...p=mtr#rpdCntId
Made the mistake of renting a giant c-clamp BJ kit from Advance Auto parts...BIG MISTAKE for mt '02 540i Touring for allot of reason one being having to handle 5 parts at once.
DOES ANYONE WHO HAS BMW TOOL # 90 88 6 334 190 WANT TO RENT IT TO ME? I rented jason's Sub-frane bushing R&R tool if you need a reference. TIA.
Old 11-13-2016, 05:50 AM
4th BMW
Harbor Frieght BJ popper
I bought the HF BJ tool and modified it for my 540iT by taking it to my machinist and lengthening the pivot bar and adding length to the screw push bar receiver, giving it much more reach and pressure....I call it "Monster" I'll take a pic of it later.....freaking out with giant c-clamp per FCPeuro (car parts) DIY rear E39 rear don't do it ! Especially on a Touring.
