Bad vibration from front end - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 02-03-2011, 08:37 AM
sjg145 sjg145 is offline
Mein Auto: 1995 M3
Hi all - my first time posting here, so please bear with me...
I have a 1995 M3 that has had a vibration problem (seems to be from the front end) that has gotten worse over the past few weeks. It starts our at 10-15 MPH and just gets worse as speed increases. Vibration does not change with clutch in or in netural. I had thought it was some worn front tires, but after swapping the front and rear (which are new), the vibration is the same - and still feels like it's coming from the front.
It is to the point now where it is very load and I can feel it through the floor and steering wheel.
A few other points to take note of:
- when turning left - like a sweeping turn at speed - the vibration disappears, but when turing right, the virbation is the same
- when braking the vibration goes away
- when having the front jacked up, I noticed there is about a 1/2" of play in the front left wheel - specifically when I grab it at the 12 and 6 o'clock position, but also in the 3 and 9 postion.
Could the 12 and 6 wheel play be causing this vibration? Just looking at which components to start with to avoid replacing uneccescary parts.
Thanks in advance....steve
Old 02-14-2011, 07:54 PM
fun2drive's Avatar
BMWCCA 149159
Sounds like a very bad left wheel bearing.
Have you checked your LCAB, A arm ball joints and tie rods?
Old 02-16-2011, 01:45 PM
rrsperry's Avatar
rrsperry rrsperry is offline
Really Senior Moments
Mein Auto: ///M3 sc
Yep. bearings, ball joints, strut bearings are things to check.
No matter where you go, there you are.
Old 02-17-2011, 04:00 PM
reh0515 reh0515 is offline
Mein Auto: 2001 325xi
im having this same problem how much did the repairs cost you.
