Old 02-13-2013, 11:04 AM
msrz2003 msrz2003 is offline
Mein Auto: 745Li
driver's side window sounds like someone is chewing on rocks when rolling up
seat belt/air bag fault warning
I have the same issue with driver side window sound, started last sunday. let me know if you get any fix or workaround...
Old 02-13-2013, 02:58 PM
mws mws is offline
Mein Auto: 760Li, F250 V10, Ex 7.3L
760Li 135K I'm working on a bunch of other threads right now regarding specific issues, but to generally add to this thread:
1] Sliding sunroof cover does not crack open when you tilt the sunroof open for a little ventilation. It used to.
2] The 760Li long-cranking and occasional hesitation or bumpy idle or dying at a stop light issue. (probably HPFP, will look to see if my fuel tank vent tubes are full of gas tonite--if so, hello $$$$)
otherwise, drives great at 135k, and everything works...as well as most cars at 20K.
Old 02-17-2013, 05:24 PM
Kcjmm32 Kcjmm32 is offline
Mein Auto: 2002 745i
My headlights started flickering dont know why..... And dealer says my amp is bad belts are cracked thrust bushings bad and e brake is rusted or seized guess I need a good bimmer tec for my 7 in the allentown bethlehem easton pa area.
Sent from my SGH-T959V using Bimmer App
Old 03-04-2013, 12:27 PM
DCCXLV-Li DCCXLV-Li is offline
Mein Auto: 03' 745LI, 02' 530I M
I have an oil leak. I have to replace alternator seal. Left license plate lamp is out. Runs great, I love this car!!!
Old 03-04-2013, 03:00 PM
chowdarygm chowdarygm is offline
Mein Auto: BMW 318i E46, 735i E65
my back seats head rests stopped moving suddenly....any idea guys?
Old 03-14-2013, 02:34 PM
momo_oo[][]oo's Avatar
momo_oo[][]oo momo_oo[][]oo is offline
Mein Auto: M35
I go for a test drive and fall in love with them and then I back off when I read the endless problems this car has.
03 GSX-R 1000
06 Infiniti M35
00 E46 323I SOLD
08 Jeep Grand Cherokee Laredo SOLD
08 E60 535I LEASE OVER
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Old 03-14-2013, 02:56 PM
gatekeeper1971's Avatar
gatekeeper1971 gatekeeper1971 is offline
Mein Auto: 2005 BMW 745i
Got a enigma for ya... Had the infamous P0491& P0492 for awhile and I know what that all entails. I usually turn CEL off and wait to catch it before it comes back on the get inspected. Well light was on this morning and when I got home from work I did some stuff round the house got back in the car to run to store and no CEL!! So I'm puzzled do what I had to do go back home put scanner to it and it says all is ok!! I'm ecstatic right so figure I go run to inspection station to get inspected. When I get about mile from house light comes back on so I pull over scan again and now I have a P1327 code yet everything else shows ok. I just went ahead and cleared code and will see what happens tomorrow bc station is closed now. Any ideas out there on what's going on with this new code. Now I have just started using this additive by Penray which my Indy told me will help clean carbon and my help with my secondary air system as well. Do you think maybe its breaking up and clearing out carbon in the system so soon. Just added it this past Wednesday surely it's not that good a product and my ports and rest of system been clogged for almost 2 years now....
Old 03-14-2013, 05:42 PM
Firecatdriverf7 Firecatdriverf7 is offline
Mein Auto: 745li ,Rx8 & 7
As long as its starts i am good. if I get nav or window ,or funny noises rattles, that's all easy fix .But the car is touchie for sure,easly upset from all the posts, I have a Rx8 and many people have terrible problems, again like the 7s I guess but love-em both
Old 03-14-2013, 05:57 PM
Punisher745Li's Avatar
Punisher745Li Punisher745Li is offline
BMW Enthusiast
Mein Auto: 2004 745LI
front rotors, front pads, some dents, replace spark plugs, front license plate bracket and chrome trim some a$$hole backup and hit me....
Bayerische Motoren Werke
Old 03-14-2013, 06:30 PM
drecoop drecoop is offline
Originally Posted by plebe1985 View Post
My tranny shifts hard, and one side blows cold ac and the other hot when the ac is on.
Did you find a solution to this?
Old 03-15-2013, 06:23 AM
trekwars2000 trekwars2000 is offline
Mein Auto: '06 750Li and '08 FEH
People on message boards don't post when they DON'T have problems.
My Garage:
2011-Current 2006 750Li
2008-Current 2008 Ford Escape Hybrid
Retired:
2006-2011 2006 325i
Old 03-15-2013, 06:39 AM
Yes I think so? Well I do,, every car has it THINGS, but people Have high expectations of the seven series because of their initial cost. Drive a cheap car and all the noises seem to be normal? being high-priced or low-price no transmission should fail under 150,000 K just my opinion I have probably about eight cars and I can't believe that you have a transmission issue with under 100k . My ford edge 209,000 km so130-135,000 miles has never had a Warranty claim since the day I bought it.So can't believe at 60k people have horror stories.
Old 03-17-2013, 01:55 PM
Lastcombo's Avatar
Lastcombo Lastcombo is offline
Mein Auto: BMW745I E65 ,BMW318 IS 94
I have posted many threads about my highmilage Seven as for THE 730D and my 745I check them out
Old 03-17-2013, 02:34 PM
Johnplumb Johnplumb is offline
Mein Auto: BMW 730d e65. 55reg
Re, what is wrong
I have had the same problem from when I obtained the car (4 years ago 34,000 miles) and no one can seem to cure the issue despite having 4 MOT,s 2 alignment checks and numerous checks carried out by main dealers and BM indies. I have had the discs and pads changed (OEM parts), just waiting to have a new set of tyres fitted to see if anything improves.
The issues I have are steering shimmy (35/45 and 65/80 ish) Along with a feeling of looseness and the car not being planted on the road, however it is dependent on the road surface, with smooth Tarmac being no problem with the car riding well.
Any ideas on what could be wrong gratefully received.
Old 03-17-2013, 03:11 PM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Originally Posted by Johnplumb View Post
Re, what is wrong
John,
Did this start happening with larger wheels? Try a shop that has a Hunter road force machine. Try this website..
www.gsp9700.com/.../findgsp9700.cfm
You need to have the wheels on this particular machine which will let you know where the problem areas are, on the tire or rim..
Also do a forum search, keywords - shaking, vibration, shake, shimmy. This will get you to threads that discuss this issue in detail
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 03-17-2013, 03:45 PM
Hi
No, as the car has always run on the same OEM 18 inch BMW wheels with either Bridgestone or Michelin primacy BMW fitment (star symbol on the tyre)
tyre size is 245 x 50 x 18
I would love to put 22 inch on such as you have on your car (stunning looking by the way) however the roads in England can be shocking and suspect that untold damage will be done running 22,s
Re the Hunter wheel machine, not sure if any available in England but will try and source an outlet. (link you supplied is currently not working.
Many thanks for the reply and advice.
Old 03-17-2013, 04:04 PM
Not sure that link worked before.. Google "Hunter Road Force Machine" Thanks for the compliment. You could have a bent rim, out of round tire, balancing could be off, among other things. Shaking in the steering wheel has to do with the front end and shaking in the seats are typically the rear.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 03-17-2013, 06:30 PM
7Fif 7Fif is offline
Mein Auto: 06 750li Sport
I still have the car..
Old 03-18-2013, 06:09 AM
raffles999 raffles999 is offline
Mein Auto: 2007 750I
Driver side mirror will not unfold, it parks itself just fine, my CD changer will reset to a different track after switching off the engine and leaving it in the garage for a day. Still love the 750i and m in awe of its power and luxury.
Raffles999
Old 03-21-2013, 02:29 PM
lodac lodac is offline
New York, New york
Mein Auto: 2004 745Li
My extended warranty finally came through from purchase of my car late last year. 04 745Li with 62k on it. extended warranty is through fidelity and is the Premium, until 10/2014 or 108k. Had issues on the transfer due to communication, and was finally transferred middle of February.
My Alt has never worked correctly from when I bought it with 62k on it. When it is cold out it would take several minutes to warm up then I would have to keep it under 1k rpm and wait for it to engage (start whining) or shut it off and start it again. The voltage would range from 13.5 to 15.4 when working. Yeah, well today with 70k on it I finally had it replaced. Paid my 100$ deductible, and my indy charged ~$908. I am so happy it actually didn't go out in the ~8000 miles I've driven in the last 4 months. I am so happy I don't have to wait for it to engage charging for fear of not being able to start it next time.
04 745Li
New York, New york
Double post * delete please
04 745Li
Old 03-29-2013, 05:23 AM
Bangsi Bangsi is offline
Mein Auto: 730d
while driving, i braked & then hear a loud BANG ! & the car pulls to the right hard ! i barely managed to control it ! thank god there were no cars around me... i thought my tire burst, upon inspection i see the lower arm broke....i take it to indy & they confirm my thgouths. right lower arm !
Old 03-29-2013, 07:26 AM
dgoodsell's Avatar
dgoodsell dgoodsell is offline
Mein Auto: 2005 745LI
Had a transmission leak from the pan that was replace under a year ago, Indy shop replaced free of charge.
Had an accident back in November lady back up into my passenger side rear door. Got a new door out of it and complete passenger side buffed and painted where needed. Actually worked out since I had some dings and scratches that needed to be remove. Since then my steering column won't move up and down still trying to figure that one out. Moves in and out just not up and down. Don't hear the motor trying to run so may need a new motor......someday. Tried the fixes I found on here but none were successful.
Mechanically no issues, car has been running flawlessly.
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Rear Entertainment Pack
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 03-29-2013, 05:51 PM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
Bwahahaha! Where do I begin? Lets see,....well first of all, my 7 is currently in the shop for the weep hole issue. Fortunately for me, the AGA pipe will bring the repair bill to a more manageable 2k dollars rather than BMWs 9k+ dollar option.
Secondly, my valve stem seals need replacing due to the common blue smoke after idle problem..(mistakenly referred to as white smoke by many).
I managed to take care of the secondary air problem (po491 & 492 codes) by recoding the computer to bypass the obd and get through emissions testing.
That's it for now other than a few other minor issues such as the driveline 2 - 1 gear clunk.
If this car weren't so damn fantastic to drive and beautiful to look at, I'd promptly drive it off a cliff AND remain behind the wheel!
Old 03-30-2013, 01:10 PM
Mein Auto: 730d
The Control arm that broke,
is a link/bolt type.
