X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
#26
I have had my 2011 X-5 35d for 6 weeks now and I find the stock sound system more than adequate. I think the HD stations sound the best, better than satellite in some cases depending on the station. The sound system is not going to blow you away but how much better sound are you really going to get for $1200?
#27
I like the stock stereo. Its just fine and I like running boards. To each their own.
Just sharing MY opinion. As for being an audiophile... I do not have very expensive gear. I buy the best I can afford which is much more than most people would pay for speakers, amps, speaker wire, cables etc. If I could afford it and if I had a place to put a stack of electronics, I would buy Marc Levinson, McIntosh, B&W other high end gear. |
#29
my kids voices is cover also everything always, so i am ok with the base stereo. as of the running board they love it! for me they look good on the X's. that's the reason i didn't get the M sport because of the kid.
#30
You can add the running boards later, when you realize your mistake, and for not much more money. Upgrading the sound system is a much bigger (and more expensive) project.
Current BMW's: 2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree 2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's Prior BMW's 2008 ///M3 Vert 2008 X5 3.0 2007 X5 3.0 2006 X5 3.0 2006 550iA SP 2003 540iA M-Sport |
#31
While useless, IMO running boards complete the look
Current Ride: 2011 X5 Sport/PG/Cinnamon/Bamboo//Cargo Cover/CA/Multi Countour/Premium Sound/Convenience/Premium/Tech/Heated Front/Sirius/High Beam Assist/Running Boards/Style 335 Retired: 2008 X5 3.0si AW/Tobacco/Bamboo/Premium/Heated Front/Running Boards/6FL/Park Assist Retired: 2006 330xi SG/Terra/Alum/Premium/Sport/Cold Weather Retired: 2003 325 'Vert/ Steel Gray/Black Dakota/Burl/Sport/Premium/Manual Retired: 2000 323 Ci Steel Blue/Gray Dakota/Sport/Premium/CW/HK Sound |
#32
If it wasn't obvious, I was being flippant with my comment "PS: Running boards suck...".
Plenty of people here think X5 running boards work or look great, and plenty (including me) think they look terrible on the X5 and are functional disasters, and would gladly pay to have them removed if I someow ended up with them. The point being it's no surprise when one owner thinks the stock/premium/supercustom stereo sucks, and another owner thinks its just fine. PS: 3rd row seats suck... |
#33
#34
my previous X5 09 has standard sound and the sound is crap. go out in the car leave the stereo, shut the door and the sound is garbage. embarrassing! now do this on premium. the sound still solid.
#35
Got X5 y'day, not impressed with base sound. Feels like Honda accord.
#36
lack of insulation on the base sound...
#37
I agree. The other "option" is not to get them, and still have to deal with rubbing your pant leg on the "protrusion".
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011 2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010 2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired) ED Trip Report W/ Pics (And Engagement Story/Pics) |
#38
I still think the "premium" system leaves a bit to be desired.. but the base system brought me back to a 1986 Celebrity my grandparents owned..
#39
I am somewhat of an audiophile and have owned a variety of high end gear including Mac, Pass, Usher, PS Audio, Manley, etc. Have experimented with nearly all technologies including tubes, hard-drive based systems, SACD, and so on. Have had vinyl for a good while but that's on hold now.
My current setup includes Meridian active speakers, which are good enough that they pulled me out of the constant upgrading game, for which I am thankful as it gets pretty crazy. I went through about $100k in electronics over 10 years. The Meridians cost as much as a new economy car, so they'd better be good. To OP: in your iPod, do you use lossless audio? In pretty much all cars I have heard (stationary!), the audio is actually BETTER than home stereos unless you're spending a lot of money at home, and Im not talking receivers. The enclosed environment, combination of hard and soft surfaces, MUCH smaller space (think headphones on the other end), contribute to a listening 'room' that is actually very sound friendly. Unless... You screw it up with a supremely mediocre system and then remove the tweeters! Yes folks, the audiofools at BMW decontented the standard stereo by (cough, hack) REMOVING the effing tweeters (what, $10 each?) entirely! So you have not-so-good midrange drivers trying to replicate the high frequencies (as well as doing their own job) and failing miserably. I have the stock stereo in my X5. I am NOT an audiophile on the road, I am a driver. Much of the time I don't even have the system turned on as I like to listen to the engine, road sounds, etc. But when I do turn it on, such as on a long drive with cruise control on, this thing is pretty bad. And comparing to the base stereo of my ML320, that was a lot better even though nothing to write home about. But a moving car is NOT the place to evaluate a stereo anyway. Too much noise... proper listening to a stereo demands an otherwise tomb-quiet environment. However, the irony here is that the X5 is pretty damn quiet, which actually promotes attentive listening, and then they bugger it up, in the standard stereo at least... I may be upgrading the X5's speakers in the summer. If it works out well, I will post a DIY. In the meantime, I run the treble all the way up and it helps a little. Last edited by kck7; 02-14-2011 at 07:43 AM. |
#40
Unfortunately for me the premium sound is a necessary upgrade to merely get to an acceptable level. There is nothing "premium" about the premium sound.
So while others might feel the base is adequate, I do not for the little time I do spend in the car, My one month old 2011 only has 300 miles on it Afterall you can blow $1200 on a pair of speaker cables easily! |
#41
As for upgrading.. I don't believe there are any cables for the tweeters already run (previously posted) so you might have more of a project on your hands..
#42
This is assuming I do it at all. I attempted to open one door panel a few weeks ago but it didn't go well as I did not have good instructions nor experience. Hoping to acquire some info which is why it's now tentatively scheduled for summer. I neglected to mention in my above post that the base stereo sound has improved a little since day one, but this may be due to a relatively common phenomenon in the audiophile's world, break in. What is always the subject of lively debate is whether the break in is of the component or of the listener's ears. I have personally experienced break in (of a component) but more so with digital pieces (eg standalone cd player) and not so much with analog stuff, or at least not as definable and conclusive. Of course what we've got here in the X5 or any factory car stereo is an entire system comprised of both analog and digital, not easily separable in reality or even in theory. What is quite clear is that BMW cheaped out the base stereo in order to sell more of the premium units. Not entirely a cool thing to do but not so surprising, given the competitiveness of the market and the only place left to really make money is in options any more. I mean, look at the nav... what, $2K? Does anyone doubt it costs more than $100 or so to install? Might even be less. Last edited by kck7; 02-14-2011 at 11:18 AM. |
#43
Tweeters
I feel that I (we've) been duped by BMW with regard to the absent tweeters.
Does anybody else feel that it's pretty deceptive to have visible tweeter enclosures (near the A pillars) and not have actual speakers inside the enclosures?
2011 X5d Last edited by Popdisplay; 02-14-2011 at 11:27 AM. |
#44
Of course it is. They are the automotive equivalent of padded bras!
#45
Cripes, you guys have me regretting not ordering the upgraded sound. I listen to mostly sports talk and 1010WINS, so maybe I shouldn't be too concerned when this sled finally gets in my possession. If it's an issue, I will contact BMWUSA and blame the ones on this board that are satisfied with the regular sound.
Just joking, of course. |
#46
Here's a fairly inexpensive way to do it. I assume you have at least premium sound with the eq. Buy this cd: http://www.rivesaudio.com/software/softframes.html Get yourself a radio shack analog spl meter noted in the instructions. Follow their instructions. Last edited by Jim E.; 02-14-2011 at 12:16 PM. |
#47
Don't worry guys, this awesome speaker upgrade will be released December 31st, 2010:
http://www.bavariansoundwerks.com/pr...grade--X5-E70/
2011 X5d |
#49
it never occurred to me that the running boards protect again doors dings. I gotta test this out. Thanks for bringing this up. Learn something new on the forums all the time. |
#50
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
