E36 (1991 - 1999)
Old 02-13-2011, 12:20 PM
CT7er CT7er is offline
Mein Auto: 2017 G12 Individual
1995 318is -- Oil leak
My wife's 1995 318is has recently developed a small oil leak (the first engine-related issue it has had). The car has only 59,000 miles and is otherwise in almost perfect condition (garage kept). Upon inspection by my BMW service center, they informed me that the head gasket appears to be leaking in a few spots (no milky substance), and they recommend replacement of the head gasket and, based on their maintenance guidelines, replacement of the front crank seal , timing cover gasket, oil pan gasket and maybe coils. They are quoting $3,800 for the work ($3,100 labor, $700 parts -- without coils), without opening anything on the engine. The dripping amounts to only a few drops per day without having to add oil during the four months since the problem developed. Is this overkill on the part of the service center or is there something I'm missing here? Any help/comments would be appreciated.
Also, I fear that I may have inadvertently tipped the scales in this direction by mentioning to the service rep that we might be in the market for a new 328i.
Old 02-13-2011, 03:22 PM
hornhospital's Avatar
D'oh, You Kids!
RUN, do not walk, to another shop, preferably an independent specializing in BMWs, and have them check the engine. 59k miles is nothing for the M42/M44 engine (mine has 229k). A few tiny drips of oil is nothing to worry about and it is highly unlikely the head gasket is leaking, certainly not leaking in the sense it makes the car at risk of breakdown.
Long story short, they don't call them "stealerships" for nothing. They are trying to do a major ripoff on you. For example, all the bits you listed (gaskets and seals), even top-tier parts, cost about 1/3 what they quoted.
Quotes to live by:
Old 02-26-2011, 07:10 AM
Thank you, hornhospital, for your common sense reply. I am planning to have an independent look at it right away.
Old 02-26-2011, 09:16 AM
ethereal45's Avatar
ethereal45 ethereal45 is offline
Send a message via AIM to ethereal45
Mein Auto: 1998 328i
Those repairs make no sense in combation.....your head gasket is leaking so they need to replace the oil pan gasket too?
1998 328i
Koni Sport Suspension
