Old 02-14-2011, 02:03 PM
coachcabe coachcabe is offline
Mein Auto: 525i
LCM Light Control Module Help???
Hello all, I've got a 2003 E39 525i. I think my LCM is bad based on the posts that I'm seeing out there. My left front headlight and right rear taillight stay on even with the key. I also have no turn signals. I started having this problem a week ago but I reset my computer, unhooked my battery and left it sit for two days. After 2 days I rehooked up the battery and it was back to normal.............until my wife woke me this morning telling me my lights were on in the care
I have now pulled my LCM but when I took it apart, it looks NOTHING like the pre-2001. Anybody got any suggestions? I guess since I can't replace those (2) modules, as suggested in earlier post, I'm stuck buying a brand new one?
Any help would be much appreciated!!!
ID:	266515   Click image for larger version
Old 02-15-2011, 05:49 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Why can't you buy it used? I have swapped them from car to car without a problem.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 02-15-2011, 10:19 PM
Vin M's Avatar
Vin M Vin M is offline
Mein Auto: 2003 BMW Dinan 530i/5
Did you have the swapped units recoded to the car? If not, how did you avoid illuminating the odometer manipulation dot?
2003 530i (Sport Package) Build Date: 02/03
Titanium Gray over Black
Shadowline Trim
5-Speed Manual Transmission
Zeckhausen Modified CDV
Dinan Upgrades: High Flow Throttle Body, CAI, Stage 3 Software, and Free Flow Exhaust.
Horsepower: some is good, more is better, TOO MUCH is just right!
"If everything seems under control, you're just not going fast enough." ~ Mario Andretti
"What’s behind you doesn’t matter." ~ Enzo Ferrari
Old 02-16-2011, 04:47 AM
Yes, I would have to reprogram them. One one occasion, the customer didn't care if his manipulation dot came up he just wanted the car fixed as cheap as possible. Sure enough, the high beam stopped acting up, and it started working again but the little light came on. Even if you buy the LCM new, you will still have to reprogram it, since it is not specific to any car. When they are new, they are blank, and need to be programmed from scratch. Used, they will work, but they will have the dot come on if you don't align it to your car.
Old 02-17-2011, 07:09 AM
Mein Auto: 525i
Hello All, thanks for the replies. Here's what I did. I found a used unit, it was out of the same year car but had on the information sticker that it was an LCM lll. My old one was an LCM 4. Since they sold me this one for $75 and a new one from my local dealer was $600 I took it. It seems to work fine. Everything is back on but YES, I do have the little light on but I'm alright with that. The car has 158k on it and I'll probably never sell it, just hand it down to one of my kids. From everything I'm told, a used LCM cannot be reprogrammed for use in another car, only the new ones can can be programmed.
Old 02-17-2011, 01:05 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
You can reprogram the LCM. just be sure not to advertise a specific mileage if selling as that is considered sale using false weights and measures.
Sent from my iPhone. Please excuse typos and lack of links.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 02-17-2011, 01:32 PM
That is odd. It is even possible to reprogram the odometer to display whatever you want it to say. I had one 2008 328i that had a crack in the cluster. After changing it, I just had to hook it up to the GT-1, and got the mileage back where it was supposed to be at 37k instead of 103k that the new cluster had. I have aligned many LCMs to cars and never had a problem.
Old 02-17-2011, 06:46 PM
Mein Auto: 525i
Really? I'm sorry. I didn't know they could be. The other posts I found said they couldn't be reprogrammed. Would I need to take it to a dealer?
Old 02-17-2011, 07:59 PM
I usually take the LCM and the cluster out and take it to someone who has acess to eeprom and they will take care of it. When I put it back in, I have no problem. I am pretty sure the dealer will do it for you, but you might as well bring your firstborn along too.
Old 06-14-2015, 10:46 PM
AngelPhob1k AngelPhob1k is offline
Mein Auto:
Please help someone! So today my smart self decided to reset my battery with my light switch on and by doing that I got a short circuit through out my car. Now every single light malfunction comes on. What can I do?
Old 06-14-2015, 10:47 PM
Mein Auto:
I have a2006 530I bmw
Old 11-12-2015, 09:30 PM
AllesklarBMW AllesklarBMW is offline
Mein Auto: 530i
My 2002 530i has same issues you described. Looks like I eat a new one because tamper light is unacceptable with or without selling it.
What a racket.
Old 11-12-2015, 09:58 PM
cn90 cn90 is offline
LCM III uses VND920 chips...
http://www.bimmerfest.com/forums/sho....php?p=7457470
Old 11-12-2015, 11:22 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Methinks you are hosed. You need to take a trip to the dealer, or post your problem on the correct forum. To wit, http://www.bimmerfest.com/forums/forumdisplay.php?f=104
