Old 02-14-2011, 07:47 PM
stevewang stevewang is offline
Mein Auto: X5 35D
Dent Remover
Has anyone ever using dent remover like Dent King? My X5 got hit today with a big dent under the hood under the BMW mark. Any suggestion is highly appreciated. Pictures post as below. Thank you very much.
ID:	266565   Click image for larger version
Old 02-14-2011, 08:29 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
That looks a bit to drastic and on the bodyline. You are still going to need paint work
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 02-14-2011, 09:39 PM
drharley drharley is offline
Mein Auto: X5 35D, M3 CiC
Dent Doctor or the paintless dent remover will not fix your problem because the paint itself was also damaged. It's a bodyshop repair. Sorry. I have had personal experience with the paintless dent repair on my Imola Red M3. I got a dent in a parking lot right along the crease under the rear passenger side window. The paint was not disturbed. The fix cost me 125 and no one can tell where the dent was. The bottom line is that the paint itself cannot be disturbed.
Dr Mike
CAPT USN (Ret)
Old 02-15-2011, 12:32 AM
ard ard is offline
Resident Curmudgeon
Say goodbye to $1200.
For a "paintless" repair to work the paint needs to be there....
Hey, paint happens, not a big deal. Take pictures, document the work done, and drop it in the file should you ever need to sell the car and someone say "front end damage"
Old 02-15-2011, 01:16 AM
smuggymba smuggymba is offline
Mein Auto: 2011 X5 35d
1200 to fix such a small dent?
Old 02-15-2011, 08:23 AM
pk9394 pk9394 is offline
Mein Auto: X5
it happened the same on my E46 M. can't use paint-less dent remove. But I found my self an excuses to change to a carbon hood
Old 02-15-2011, 08:42 AM
E70x5 E70x5 is offline
Mein Auto: X5
Yeah, I agree. It's a bit too much damage for paintless dent removal.
Old 02-15-2011, 09:58 AM
0428's Avatar
0428 0428 is offline
Mein Auto: X5 35i Sport Sapphire
Why don't you have the person who hit you / their insurance co pay for this? Unless you hit them from behind.
Retired
1999 Prelude SH / Pearl White /
2007 X3 Sport / Jet Black /
2010 X5 Sport / Sapphire Black /
Current
2013 X5 M-Sport / M-Power / Alpine White /
Old 02-15-2011, 10:14 AM
charlesberry's Avatar
charlesberry charlesberry is online now
Mein Auto: E46 944 Turbo
For what it's worth, Flemington BMW uses "The Dent Man" his name is Bill Rochford and his phone is 609-647-6065.
I don't think paintless dent removal will work but you can follow up with Bill if you like.
Mein Auto: X5
most likely is a hit-n-run
Old 02-16-2011, 05:27 PM
ard ard is offline
Resident Curmudgeon
Yes. It is the PAINT that makes it expensive.
Dent repair itself is nothing- an hour, tap-tap, prime, some filler to get the contours perfect.
But you need to prep the whole hood, paint and blend the color, sand, then clearcoat the whole hood.
Maybe only $900?
But that's my guess.
Old 02-16-2011, 05:42 PM
PAX5 PAX5 is offline
Freude am Fahren
Mein Auto: X5 50i
Maybe only $900?
At least $1,200 ...I'd say closer to $1,800 to $2,000 being that it's in NJ. Whole hood needs to be painted after repair.
PAX5
BMWCCA #20645
Old 02-16-2011, 06:16 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I bet they might even replace the hood if the insurance company was paying - it is a tough repair spot and is difficult to get behind to get the dent out perfectly and it wouldn't be acceptable to use much filler there due to the amount of flex the hood has and the repeated opening and closing. At the cost of labor, the hood is cheaper to replace fairly quickly as a new hood would reduce prep time significantly. It is also creased heavily by the roundel, which makes PDR unlikely to be able to perfectly remove the dent - my bet would be on a hood, prep and paint - probably 1200 - 1500 and up done right.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 02-16-2011, 06:31 PM
ard ard is offline
Resident Curmudgeon
The problem with replacing the hood is blending the color...then you are blending the color onto the fenders and need to clearcoat those!!!
You cannot just 'paint color' right up to a panel edge...this is how most crap repairs are seen...the panels just don't match.
The good news it that there really is no 'other' panel within 12 -18 inches of the repaired area. That is kind of a rule of thumb- for example door damage within 6 inches of the back edge will cause them to color into the rear door, and clear coat both. Freaks people out, but it is how to get perfect repairs... or as perfect as possible.
So for a new hood, they paint the color on the hood to the edges, but then 'blend' the new color onto the existing painted fender. But this means the whole fender then gets a new clearcoat!
I'd really want just the nose colored, and clearcoat the whole hood.
