Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
How to bleed your brakes: Step-by-Step Instructions
I've been meaning to do this for a long time, since it's something I often have to explain to people. Here's my write-up on bleeding brakes. I intend to improve it over time, probably adding photos and more detail as I get feedback from people using them.
How to Bleed Brakes
Dave Zeckhausen Owner, Zeckhausen Racing 2001 540i 6-Speed StopTech 4-wheel big brake upgrade M5 3.15 Limited Slip Differential M5 Front Swaybar Dinan Stage 3 Suspension Dinan Front Strut Tower Brace Rogue Octane Short Shifter Rogue Performance Transmission Mounts European Dash Conversion CDV Deleted (of course!) |
I sincerely appreciate your great writeups and advice on tech topics.
I guess I'm not the only one that had a negative experience with 1-way valve bleeders. |
I have had "some" luck pushing a pint or so of fluid thru with 1 way bleeders, that is, purging moisture or cloudy brown fluid from a wet system.
It doesn't seem to get that last bit of air out, like you can when a person is standing at the wheel cranking the bleeder each pedal stroke & watching for an end to streams of bubbles coming out. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
