Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 02-16-2011, 03:59 PM
Vinsobe Vinsobe is offline
Mein Auto: 740i
Dme and Ecm
Hello, I was advised by my mechanic that my DME computer is no good. He told me they are not programeable so its not worth it to buy a second hand one. So checked on line and prices for new ones were outrageous. So i checked Ebay and found some. Some I contacted the seller and he assured me it was plug and play no programing necesary. So against my mechanics wishes I bought the part. My mechanic installed it and low and behold it doesnt work. Does anyone out the have any expierience with DME and ECM? Thank you!
Old 02-16-2011, 05:27 PM
setconstr setconstr is offline
Mein Auto: 2001 740i sport 2006 m6
dme
check out RPM Motorsport they can reprogram and are very helpfull you can chat right online with them
Old 02-17-2011, 01:32 AM
Mein Auto: 740i
Thank you!
Old 02-17-2011, 06:15 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Why you need to change DME or ECM? What problems you had in order to change that?
I'm just curious...
Old 02-17-2011, 08:24 AM
Mein Auto: 740i
It appears to have been in a flood. The signals stopped working.
Old 02-17-2011, 10:27 AM
joyism5's Avatar
Sorry for you. Have you checked the ECM relay? There are a lot of test to do before putting a diagnose like bad ECM. I hope your mechanic knows what his doing.
I once was trying to find the issue with an E38 which was not starting. 2 other mechanics say that is bad ECM. Car was not starting often and without any reason. It took me a lot of time to test signals from ECM. Sometimes were working sometimes not. Finally I found out after a lot of hours spent that the weather seal from the windshield was damaged by the sun and it was letting water to drop on the cables and then in the box where the ECM is. It was not necessary to rain outside.This happen when the humidity was high in the air or when washing the car.
Anyway I wish you luck with yours!
Old 02-17-2011, 10:35 AM
joyism5's Avatar
ECM Engine control module needs to be reprogrammed and coded for your car ! New ECM needs to know the new signal from the key for instance. For this procedure you need to use the BMW software. This is applicableto the second hand ECM too.
Old 02-17-2011, 03:18 PM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
correct. you can use a used control module but it must be coded with your car and EWS aligned before it will start.
Old 02-17-2011, 04:38 PM
Mein Auto: 740i
Does anyone know the name of the software to code the new (used) dme computer because my original one is not fuctioning properly? Or can this not be done? Or if i go with a new dme is it necessary to change the ecm and keys as well? Please anyone that has expierience with this issue please respond ASAP! I am stuck. I toltally got screwed with this car and believe it or not i've had it for 6 months and only drove it for two days. It's just one problem after another. First the cats, then the Vanos, then the cluster, now this. Thank you in advance for any assistance! Sorry for venting its just frustrating.
Old 02-18-2011, 06:27 AM
joyism5's Avatar
Good Luck!
Old 02-18-2011, 07:23 AM
Mein Auto: 740i
Thank you so much!!!!!!
Old 02-18-2011, 08:05 AM
Mein Auto: 740i
I will foward this to my mechanic. So it can be done??I really hope this works. If you have any more info please let me know. Thank you again!
Old 02-18-2011, 09:55 AM
joyism5's Avatar
PM with your email for a little more info.
Old 03-22-2011, 09:12 PM
Spotlight Spotlight is offline
Mein Auto: 95 74OIL
Can I get that info? I am Haveing the same problem with my 95 740il need to program the new ECM/DME. Thanks
Jerrywjohnson1@msn.com
Old 11-22-2012, 05:59 PM
5494alexv 5494alexv is offline
Mein Auto: 2001, BMW 740IL
plz sent me some information to i do have the saim problem with my beemer
vogel-alex@hotmail.de
Old 11-22-2012, 06:59 PM
joyism5's Avatar
The new (or used) ECM needs to be align with the EWS (immobilizer) module, general module, transmission module. This can be done by the dealership or BMWs specialized shops since BMW software is necessary to run this procedures.
JOY = BMW
Old 11-30-2012, 09:36 AM
nomoexes nomoexes is offline
Mein Auto: E38 740il
Dme
Whoever sold you that DME should give you an immediate refund. The DME(ECU), EWS, and the Remote Key ( has a small circuit board in it) all three must be in sync. The way it was explained to me by bmwdmes.net the EWS emits a rolling series of codes that are individual to your car. Those codes are BURNED into the Memory of the DME. Hence why no used DME will work. That DME must have your EWS codes in it to function. The Key gets aligned to all 3. I had this problem months ago. The procedure was to remove the EWS and Key and send it to the techs and have a new coded DME returned back to me. Sat in a cheap enterprise rental ($69 a week) 2 weeks but I ended up saving $1000 from the BMW Stealership. Now if I can fix this oil leak I will have the perfect paid off car!
HTML code is Off
