2003 X5 3.0 w/Xenon Headlamp Problem - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 08-12-2010, 06:20 PM
des2002 des2002 is offline
Mein Auto: 2002 X5
The head lights will come on work fine and then both shut off or one comes on and the other is out. I have replaced the dash switch and the bulbs. just cannot figure if it is a wire or as someone suggested a lamp ballast ?
Old 08-13-2010, 06:58 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
If these are OEM then the HV wire is part of the ballast. Is the "out" light always on the same side? If so, switch the ballast from the "on" side over and see if the light stays on. You may need a $tealer to check the LKM to see if it has any problems. You can pick up ballasts on Flebay from time to time.
Old 08-13-2010, 04:33 PM
Mein Auto: 2002 X5
I will try the ballast swap this weekend, thanks for the help. do you know what a ballast costs ? and the LKM ? (light kontrol module?)
Old 08-14-2010, 07:36 AM
Zulu95's Avatar
Ballast on fleabay are $40-$50 for OEM last time I looked. $tealer charges mega-bucks. LKM required the dealer computer or the like to install it. They run somewhere in the region of $500. I had my LKM fail while still under CPO and the $tealer quoted $450 or so then plus labor. CPO picked it up.
Old 02-26-2011, 08:24 PM
command command is offline
Mein Auto: 325
Problem is ballast ,need chaget it . and this oem ballast made form Hella.
Like this
