E36 (1991 - 1999)
Old 02-20-2011, 11:08 AM
Meka78 Meka78 is offline
Mein Auto: 1999 328i
Windows and sunroof open by themselves
I just recently bought a 1999 328i and the windows and sunroof keep opening fir no reason is anyone else having these problems can someone tell me what I should do?
Old 02-20-2011, 11:52 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
When do they open? I.E. while your driving/braking/idling/using your blinker? Could you make them open, or is it just totally random no matter what? It could be bad switches, or a short. Get a wiring diagram and see if theres any relays that could be bad. Wiring = no fun in these. Good luck though
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 02-20-2011, 12:12 PM
woody underwood's Avatar
woody underwood woody underwood is offline
ZHPper
Mein Auto: 330ciZHP Mini Clubman VUE
You're probably pushing a button on your key while it's in your pocket. If you hold down the lock button, all the windows will open.
Old 02-20-2011, 12:18 PM
GiaGiaJa's Avatar
GiaGiaJa GiaGiaJa is offline
Don't Judge Me!
Send a message via Yahoo to GiaGiaJa
Mein Auto: Sedan 328i iDrive AT
Have you break anyone's heart lately?
We might need an exorcism over here!
Ohhhhh.... The ultimate attraction
"Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves." Albert Einstein
Old 02-20-2011, 12:39 PM
It happens random and I took the battery out the remote and it still happens
Old 02-20-2011, 12:42 PM
I want to know if I should return the car or is it fixable?
Old 02-20-2011, 01:01 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
There is a feature to open all windows and the sunroof by holding down the unlock button for several seconds. Since you took the battery out of the remote something else must be actuating that circuit. Normally I would recommend visiting a dealer only as a last resort but this might be worth letting them take a look at it. Might be worth at least a call to see what kind of diagnostic fee they would charge. Good luck
Old 02-20-2011, 03:11 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
NO! Never go to the stealer! I work in an independent auto-electrical shop, and we've fixed problems even the manufacturer couldnt solve. I'm sure theres one around by you; look there first. Alot cheaper than the $tealer, with same-as or better results
Old 02-21-2011, 12:44 AM
pimpin.dre pimpin.dre is offline
Sucker for the 3 Series
Mein Auto: 1995 328i, 1980 323i
Did the last owner die in the car?
i'd start by giving all the lock barrels a spray with some wd-40 (or similar) to make sure they aren't sticking inside somehow. Also, try pulling each of the switches out one by one for a few days each and see if you can make it stop.
Member of the Non-M Bumper by Choice Club Member of the Official Secret Bimmerfest Text Club
