The X5 SAV Forum
Old 02-22-2011, 09:30 PM
drae39x5 drae39x5 is offline
Mein Auto: 2003 X5 4.4i
Tips for replacing upper expansion tank hose
Anyone got any tips on how to replace this the right way on an 03 X5?
Sent from my SPH-P100 using Bimmer App
Old 02-23-2011, 06:45 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E53, E60, E92
Unclip then use medium size screw driver to pry gently, little by little (and go around the circumference of the connector). Be careful with the plastic "U" shape pipe it rather britle with age. Worse come to worst, this hose assembly cost around $37 at the dealer, or if you break the "U" plastic shape just use copper freezer tubing for replacement; OK I only seen it done by someone, cause I broke mine and just replace it from dealer. To me I don;t want to deal with leaks on the freeway with home brew stuff.
Old 02-23-2011, 07:18 AM
Yeah mine broke on highway at night! Not fun at all. Do the clips just pull out?
Old 02-23-2011, 09:17 AM
The clip won't complete come off just pull out so you can slide the connector off the nipple (the clip stays with the connector).
Old 02-23-2011, 09:23 AM
Thats good to know! Thanks so much for your help!
Old 02-27-2011, 01:15 PM
Replaced hose photo
