E36 (1991 - 1999)
Old 02-24-2011, 02:59 AM
stone6356 stone6356 is offline
Mein Auto: BMW E36 320i
Unhappy BMW e36 320i- dash lights all go out, then engine cuts out
Hi, im new to this forum, but have used threads from it before to help me. But this time i could find nothing to help me. Thanks in advance for any help you can give me.
When i start the car it seems to run fine. But as soon as i rev the engine at low revs, the dashboard lights up like a christmas tree, then all the dash lights go out, the temperature gauge and the fuel gauge also drop to the minnimum point. After that if i stop reving the car it will die. At first i thought it was the ecu getting damp, so i removed the ecu, dried out the compartment where it is kept and replaced everything, but this did not seem to do anything at all.
I am completely confused by this and was wondering if anyone has had the same problem or has any advice.
Thanks for any advice.
Old 02-24-2011, 06:21 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Your alternator is dying. Get it and your battery tested. Free at most auto parts stores.
Good luck.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-24-2011, 07:28 AM
Cheers for that jonesin
Because i am unable to drive the car anywhere because it dies when i try to drive it, can i test them myself? I have a battery tester and a multimeter. So, as long as the alternator is putting out around 14.7 volts it ok right? And the battery tester will tell me if the battery is ok, if its not, i shall buy a new one.
Thanks again for the help
Old 02-24-2011, 12:07 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
The alternator is generally bad if there is less than 14 volts when the car is running.
-CJ
e36 320, ecu, electric failure, engine dies
