Old 02-24-2011, 03:37 AM
ubermax ubermax is offline
Account closed at users request
Mein Auto: '08 Volvo S60, '97 Jetta
Wishing for Wider 1st Gear
does anyone with a MT wish 1st gear had a wider range ? many times when I leave the blocks at a light I get automatics immediately on my tail ! if the roadway after the light puts me in the "breakdown" lane I'm fine and I just stay there and let everyone pass , but if it's the Indy lane I end up rushing through the gears or do a right signal back to the "breakdown" which can be tricky with rush hour traffic :-) !!!!!!
Old 02-24-2011, 05:35 AM
reed75 reed75 is offline
Mein Auto: 2006 X3
Typically I only use 1st gear on hills or inclines and never on flat starts.. you can safely start out in 2nd gear and be just fine, I do it all the time...do this and you'll never have an automatic on your heels again..
Old 02-24-2011, 08:43 AM
AzNMpower32's Avatar
Tar Heel Faithful
1st gear is supposed to be short for those times when towing or an uphill start. The new X3 has a taller 1st gear but that was criticized as being tricky to engage and get moving in deep snow.
Old 02-24-2011, 09:25 AM
is a MT even available now ???
Old 02-24-2011, 09:52 AM
Tar Heel Faithful
I was referring to the xDrive20d available with the 6MT in other markets.
Old 02-24-2011, 10:40 AM
UberXY UberXY is offline
Mein Auto: 00 M5
I rarely use 1st in my M5. 2nd is good for 0 to 70.
Ub
00 M5, 05 X3, 08 X3, 10S1000RR
Old 02-24-2011, 10:59 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Looked into a short shifted for just the reason you mentioned along with a tougher fly wheel. It can be done but needs custom machining on a professional lvl.
Sent from my DROIDX
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 02-24-2011, 12:09 PM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
I had the same kind of reaction to the gearing when I first got my X3; seemed to me that 1st was too much of a "granny gear" for the vehicle.
But, as others have pointed out, you can start in 2nd pretty readily, and reserve 1st for steep hills, poor traction, or towing (should you elect to do so with your X3). In retrospect, BMW seems to have covered the widest range of contingencies with the gearing.
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 02-24-2011, 10:52 PM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
Typically what I do is shift into 2nd almost immediately... like when I hit 1500 RPM or so, and then I'll ride out the rest of the gears to a little above 3K (until I reach whatever speed I intend to). Or you can just give more throttle so that you can leave first quicker.
I find myself always leaving a pretty decent gap between me and the person behind me if I do one of the above. If I leisurely accelerate to 2500-3000RPM in 1st gear, then people will be on my tail.
Old 02-25-2011, 11:42 AM
spokelizard spokelizard is offline
Mein Auto: 2007 X3 MT
What am I missing here? Typically on a flat freeway entrance ramp I'll start in 1st, rev up to maybe 3500 or 4000, shift into 2nd, and merge into traffic in either 2nd or 3rd. Don't have any problem with cars on my tail.
If I started in 2nd, it would be even slower.
Old 03-01-2011, 04:03 AM
A lot of people I know simply don't feel comfortable with increasing the revs quickly. When the gears are short, the car will accelerate really slowly if you're the type of person who doesn't like quickly increasing the revs.
Old 03-01-2011, 01:10 PM
Aha, I guess I understand that.
But I thought BMW engine is designed for responsiveness, including quick acceleration and high revs. I don't think I'm getting anywhere close to the engine's capabilities when I do a freeway merge.
I do know I take an MPG hit, but that's worth it for a safe merge.
Old 03-01-2011, 01:14 PM
Tar Heel Faithful
BMW designs the gear ratios for a wide range of speeds. Remember, this means acceleration and cruising up to the whole 232 km/h top speed. Often in the US, we can think that the spread is too wide when really, Americans don't (legally or often) go past 130km/h.
I thought that the ratios on my mom's 325i were too wide (they kind of are); 4th gear gets to 6000rpm at 200km/h (124mph) so really I only use 1-2-3 in hard acceleration. But 200 isn't really the "left lane" of the autobahn, more like......250 lol.
