Old 02-24-2011, 10:52 AM
lsutiger9904 lsutiger9904 is offline
Mein Auto: 2007 550i
Negative Camber on E60
Are E60's supposed to have negative camber on both front and rear tires? I just replaced all four run-flats with Conti ExtremeContact DWS tires because they were all worn out from the inside shoulders.
2007 550i - Alpine White Exterior - Black Leather Interior
Sport Pkg/Cold Weather Pkg/Comfort Access System/Power Rear Sunshade w/ Rear Manual Slide Window Shades/20-way Power Multi-Contour Front Seats/Navigation System/Sirius Satellite Radio/Park Distance Control
Old 02-24-2011, 02:49 PM
TMQ TMQ is offline
Mein Auto: 2008 528i
I think all BMWs have negative camber. How many miles did the tires last? If they wear out prematurely, you should consider having an alignment done.
2008 528i: Ti Silver/Black/Light Poplar Wood, ZPP, ZCW, STEP, Comfort Seat, Heated Rear Seat, PDC, Xenon, Nav, iPod. 35% ceramic tint. VentureShield Clear Bra.
BMWCCA member
Old 02-24-2011, 06:20 PM
TRS550 TRS550 is offline
Typically camber is set negative for both front and rear.
Front is around -1.3 deg with about .7 deg tolerance on either side.
Rear is around -2.3 deg with about 1.2 deg tolerance on it.
I only know this as I had my Indy shop print out all this stuff when I had an alignment done last fall.
I've owned and driven BMW's for many years. All have had camber set negative on all 4 wheels. If the cars are driven agressively the tires seem to wear evenly (as that's what negative camber does. It lets the inside tires sit flat to the road in turns). Driven like a Camry, the tires will wear on the insides.
If you tend to drive less aggressively, ask your alignment shop to set the car up with the least amount of negative camber as is possible and still be in spec. That will help your tire life and you propobabley won't notice any difference in handling.
Old 02-25-2011, 05:38 PM
TMQ TMQ is offline
Yeah, for even tire wear, Mike Miller at Roundel recommends taking aggressive (and safe) turns when you can - after all, it's a BMW, however don't be aggressive when starting from stop (BMW isn't for drag race).
BMWCCA member
