Old 02-24-2011, 11:36 AM
justin182 justin182 is offline
Mein Auto: '11 335d & '99 Z3 2.3
Stuck Rotors
I'm replacing my front brakes on my '03 540 and have run into a problem. I've removed the wheels, brake housing and carrier, hex bolt holding on the rotor. Sounds good so far... Unfortunately, the rotors are stuck to the hub and I can't remove them. I've sprayed around the hub with PB blaster and beat on the hat with a rubber mallet with no success.
They're original BMW rotors, possibly factory original, as the car has just under 60,000 miles so I don't think the PO did anything to cause the problem. I'm guessing it's just due to accumulated rust over the last 8 years.
Any ideas on how to remove the stubborn rotors?
Old 02-24-2011, 12:45 PM
I just found this and I'm going to give it a try.
I'll let you know if it works!
Old 02-24-2011, 12:56 PM
Fudman's Avatar
Fudman Fudman is offline
I was going to suggest a much bigger hammer (3 lb mallet) but that is a very innovative approach. Low risk & safe too.
Old 02-24-2011, 12:58 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
I did my 330 last week, and let me tell ya a 3lb steel sledge made short work of that. And I did not use PB blaster. About 3 really good hits directly on the rotor.
And don't hit the center, hit the edge of the rotor.
Old 02-24-2011, 12:59 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
A block of wood and a 3-pound Baby Sledge is what`s called for here....a rubber mallet will NEVER provide the shock value needed....don`t be afraid to smack the living piss out of it !
The road goes ever onward....
(R.I.P. Jever)
Old 02-24-2011, 01:05 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Bigger hammer.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 02-24-2011, 01:24 PM
cn90 cn90 is offline
With the car properly supported on jackstand, place a piece of wood between the floor jack and the rotor and jack the rotor up a bit.
It will come out.
Old 02-24-2011, 05:06 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Bigger hammer and harder blows. Just make sure not to miss the rotor and hit anything else.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 02-24-2011, 08:50 PM
I tried the trick in the video and it worked like a champ! I only used one bolt in the carrier instead of two. I did one spot, turned the rotor 180 degrees and did it there and the rotor came right off. Pretty slick.
Old 02-25-2011, 08:17 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Make sure that you clean all the rust off of the hubs before you plant those new rotors back on the car.
If you don't clean all the rust off you will have problems later. A wire brush and light sandpaper to buff
all of the spots where the rust is on the hub will make sure your brakes will be surge free and with out
vibrations causing the rotors to warp--don't want any high spots.
Good job
Old 02-25-2011, 09:48 AM
Fast Bob's Avatar
Keeping it surreal
Good job
A *thin* coating of White Lithium Grease, wheel-bearing grease, or any other grease that will resist salt water, smeared onto the mating surfaces, will minimize chances of this happening in the future.(Be careful to keep grease off the braking surfaces) This should also be done any time wheels are removed....5 minutes spent wire-brushing the hubs and wheel flanges, and applying the grease, is time well-spent. It will save you grief on down the road.
(R.I.P. Jever)
Old 04-27-2011, 11:11 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the record, chemically removing rust on rotors was discussed today over here:
- E39 (1997 - 2003) > Why are my rear rotors rusted?
This says the phosphoric acid is just there to speed up the conversion by tannic acid:
There are two primary components in a rust converters: a tannin (usually in the form of tannic acid) and an organic polymer. The organic polymer provides a protective primer layer. Since the conversion reaction occurs faster in an acidic environment, some manufacturers will add oxalic or phosphoric acid to their rust converters to lower the pH and speed up the reaction.
It says the "tannin" is the key ingredient:
The tannin is the heart of a rust converter. It reacts with the iron oxide, converting it to iron tannate, a stable blue/black corrosion product.
Although, later on, it does mention phosphoric acid rust converters but then deprecates them:
a rust converter should have a pH of 2 to 2.5, the optimum range for forming a durable iron tannate film, and it should contain tannic acid. (In some converters the principal chemical is phosphoric acid, which reacts with iron and rust to form a phosphate coating--a corrosion retarder, but not on the level of a tannate coating.)
The "Rust Store" goes a little further by stating what the polymer is:
What is Rust Converter? Rust Converter, a water-based primer, contains two active ingredients: Tannic acid and an organic polymer. The first ingredient, tannic acid, reacts with iron oxide (rust) and chemically converts it to iron tannate, a dark-colored stable material. ... The second active ingredient, 2-Butoxyethanol, is an organic polymer that provides a protective primer layer. The overall chemical reaction converts rust into a stable, black protective polymeric coating that serves as an excellent primer for both oil and epoxy based paints.
Old 04-27-2011, 07:54 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
I found out that hammering on the back of the rotor can bend the hub so when you install the new rotor, it feels like it's warped! Fortunately, it was a lease vehicle so I didn't replace the hub.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 06-12-2012, 10:19 AM
Calicoastin Calicoastin is offline
Mein Auto: 2003 E39 540i auto
Just replaced my rear brake rotors and pads. The rotors were stuck/seized on the hub. The parking brake was released btw.
I tried hammering it with a 1lb dead hammer and nothing. I sprayed PB blaster on the rotors hub ring and nothing. Hammered it around the outer edge of the rotor, from the rear as well and not a mm of movement. I was really frustrated
I then sprayed PB in the edges of the rotors' bolt holes and then lightly hammered the rotor with a standard metal hammer and voila, it freed itself.
My theory is that the vibrations from the metal on metal contact from the metal hammer on the rotor and the PB blaster on the bolt holes caused it to un-seize the rotor from the hub since I hammered the rotor with good force with the dead hammer and it did not budge.
Old 01-19-2014, 12:49 PM
Tom Shaffer Tom Shaffer is offline
Mein Auto: 2003 530i sport
I tried the bolt trick and this worked great on my 2003 530i with 125000 miles. I had heated to expand and beaten with a hammer which did not work. Thanks for the tip.
Old 01-19-2014, 02:16 PM
bluebee's Avatar
I'm going to cross reference to this thread:
- How to remove stuck rusted-on brake rotors (1)
Old 01-19-2014, 02:17 PM
bluebee's Avatar
See also:
> E39 (1997 - 2003) > Stuck Rotors
Old 01-19-2014, 02:31 PM
MADBMWX3 MADBMWX3 is offline
Mein Auto: 2013 BMW X1
That rotor was possessed by the devil--no doubts.
Old 04-13-2015, 03:03 AM
xMAUIxxWOWIEx xMAUIxxWOWIEx is offline
Mein Auto: 1986 BMW 325es
I spent about a hour on one side, still no luck, goona let it sit over night and let the oil do it's work... The other side came off with a 2x4 and a few strikes with a small hammer. By smal I mean a hammer about the size of a 1/2 inch drive ratchet.. Rofl
Old 04-13-2015, 05:16 AM
Burning2nd's Avatar
Under the lift arms
your not hitting it hard enough....
watch them wheel studs happy swinging
there really on there when you hammer them in to 2 pieces... then you know that was really stuck on there,
* every mechanic in the world has ate a wheel stud on a simple stupid job because of the stuck rotor
15486372<-----
Old 04-13-2015, 05:55 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Since our cars don't have wheel studs just get a hammer that is large enough. Using anything smaller than 4lbs is just too small.
Old 04-13-2015, 09:33 AM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
remember
anti-seize on rebuild...save ya next time
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
Old 12-06-2015, 08:28 AM
rakeshv rakeshv is offline
Mein Auto: 2001 540i Sport Wagon
I am in the same situation with my 2001 540i Wagon. Going to try the bolt trick. My old Lexus LS430 had holes drilled in the rotors themselves precisely for breaking them free of the hub. Really miss those.
Old 12-06-2015, 09:07 AM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Get a Hammer and some liquid rust remover. Apply the rust remover on the hub before taking everything off so it can soak.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 12-06-2015, 09:59 AM
Thanks. Liberally sprayed the lug holes and everywhere I could find around the hub with WD40, waited a while and a few hammer blows did the trick. Originally I was trying to hit the rotor from the back side (on the principle that I wanted to get it away from the hub), but that was giving me no power. Just hit it hard a few times from the front broke it free.
