Electrical WOs - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 02-25-2011, 06:59 PM
E36Maxwell E36Maxwell is offline
Mein Auto: 1995 E36
Electrical WOs
Hi everybody , I have a 95 m3 that seems to not start if not driven for 2 to 3 days due to dead battery , so it is grounding out somewhere , also every now and then when using the left turn signal " only the left " the thermostat gage seems to bounce in sequence with the blinker also the break circuit code pops up on occasion but the break lights are working perfectly , turning the car off then restarting it gets rid of the code " most the time ", any input would be helpful , thanks in advance
e36M axwell
BimmerApp
Old 02-26-2011, 04:43 PM
fun2drive's Avatar
BMWCCA 149159
Do the classice investigation method to locate the draw. This means taking the lights out of the trunk and using a VOM to the neg post and neg cable set to the 0.000A scale in amp mode.
Now remove one fuse at a time and see if the reading drops. It should be around 0.040A or less. Once you locate the offending circuit investigate what on that circuit is screwed up. I would sttrongly suggest that you check the trunk wiring post on the left side. Many times these indications you post have been caused by the wiring chaffing and breaking causing shorts, etc.
Good luck
Old 02-27-2011, 10:55 AM
Mein Auto: 1995 E36
Thanks for the info and lesson , much appreciate ...
Sent from my iPhone using BimmerApp
