Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 02-26-2011, 01:58 PM
Z4golfer's Avatar
Z4golfer Z4golfer is offline
Mein Auto: 2011 Z4 35is
Interesting warranty fix
I've had a rattle in my passenger side tail pipe for months and have just lived with it until this week. The butterfly valve would rattle when it was in the closed position. I took it into a BMW dealer to be fixed this week and they said that they were directed by BMW to spot weld it in the open position.
From what I've read, it's purpose is to reduce the sound at low rpm's. If that's it's only purpose, I'm fine with the fix.(It sounds good) However if it is also for back pressure, I'd like them to actually fix the problem by replacing the muffler.
BMW obviously engineered the flap for a reason and I probably could demand that it be corrected under warranty.
If anyone knows the exact purpose of the valve, please let me know.
Here is a link to my original post back in August.
http://www.bimmerfest.com/forums/sho...866&highlight=
2011 Z4 35is
Old 02-26-2011, 04:04 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
I think it is for one or both of these reasons:
1. Sound control at lower RPMs
2. Faster engine warmup
Others will jump in and correct me if I am wrong.
Colonel (Ret) US Army / Hagerstown, MD
2010 Z4 s30i Alpine White/Beige
PP/SP/CWP/6MT/CA/NAV/ipod/USB
ED 1-29-10/Redelivery 3-8-10 (weekend car)
2013 Audi A6 Quattro (daily driver)
2011 335d (Ret)
2009 335i vert (Ret)
2007 335i vert (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 02-27-2011, 03:37 AM
Rubber Ducky's Avatar
Rubber Ducky Rubber Ducky is offline
Mein Auto: F30 335i AT; '11 Vette GS
Dunno what might be in engineers' minds (I've worked with engineers a lot in my lifetime and that's a permanent bafflement) but can say no adverse effects of having the butterfly valve open all the time. A bunch of us have removed the short vacuum line that actuates it and capped both ends with no ill effect and better low-rpm sounds. I'd say fret not.
Old 02-27-2011, 06:45 AM
rmorin49's Avatar
+1, I did the same thing on my R32. Car sounds better and I have observed no adverse effects. Has been in to the dealer for several routine maintenance visits and no mention has been made of any effect on engine diagnostic codes.
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 03-01-2011, 07:22 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 09 335Cabrio zsp/11 335d
Isn't this the same as the "golf tee" mod? N4S
Old 03-01-2011, 08:31 AM
Well, yes, but without the golf tee... Carburetor caps work better. http://www.amazon.com/Holley-26-105-...1&sr=1-1-spell
Old 03-01-2011, 10:06 AM
Z4golfer's Avatar
When I was a kid, we'd sometimes clip playing cards to our bicycles for a cool sound as it slapped the spokes. However, I don't remember the man at the bike shop doing the same to prevent me from hearing a rattle in the chain.
2011 Z4 35is
Old 03-01-2011, 10:38 AM
HerrK's Avatar
HerrK HerrK is offline
From the Society of Automotice Engineering and bafflement dept, the light vehicle sound standard is SAE J1492. The sound level is measured and averaged from idle to 3/4 of rated engine speed ramped up over a max 15 second period. J1492 details how to conduct the test based on exhaust orientation, location of instrumentation, surface, backgound noise, etc. 95dB (A Scale) is the max most states and mfgs have adopted. So if it is quieter at idle it can make more noise at the higher speeds.
Thus the flapper in on leg of the exhaust system, to keep the average sound pressure down at idle. The flapper has nothing to do with vehicle warm up.
HerrK - Keine Eifelfahrt ohne eine Runde über den Nürburgring
May 2010 ED l 2011 35i l Crimson over Ext'd Coral Red w/brushed Alum l 6sp MT l Prem Sound l Sport Pack l 296's l Comfort Access l Alarm l Power Heated Seats l & Nav.
Old 03-01-2011, 05:41 PM
rmorin49's Avatar
I stand corrected on the vehicle warm up issue.
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 03-02-2011, 09:39 AM
Z4golfer's Avatar
Thanks HerrK
2011 Z4 35is
HTML code is Off
