E36 (1991 - 1999)
Old 02-26-2011, 07:25 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Replacing Brake Calipers in Pairs?
I searched and didn't see anything, so here we go...
I noticed that my front left brake caliper was sticking ever so slightly last night. I bought a caliper rebuild kit, took it apart, scrubbed and cleaned everything, and put it back together with the new parts. Unfortunately, the caliper piston did have a small amount of pitting/corrosion on a small portion of it. I used some Scotch-Brite to scrub it off as much as possible, but it's going to need to be replaced eventually. After putting it back together, the caliper no longer sticks , but I know its days are numbered.
My question is: is it necessary to replace the front calipers on BOTH sides of the car, or can I safely get away with replacing just the one?
I've heard from others that a new caliper could/will be able to apply more pressure than the old caliper on the other side of the car, thereby causing uneven braking force from left to right. That said, with the new seals on my rebuilt caliper, I didn't notice any pulling during my test drive, so I wonder what the difference between my rebuilt caliper and a new caliper would be.
Thanks guys!
1998 BMW 328is
1966 Pontiac GTO
Old 02-26-2011, 07:38 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
NO, only replace a bad caliper where required. You do NOT need to do both sides at once.
Old 02-26-2011, 07:54 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
What he said^
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 02-26-2011, 08:18 PM
ZeGerman's Avatar
Warm Leatherette
Really, so there's no truth to the replace in pairs theory? That's what I thought. Seems like if a caliper is moving freely and makes a good seal, it's working at fully capacity.
I could more likely see there being a need to replace pads & rotors in pairs.
1998 BMW 328is
1966 Pontiac GTO
Old 02-26-2011, 09:23 PM
ethereal45's Avatar
ethereal45 ethereal45 is offline
Send a message via AIM to ethereal45
Mein Auto: 1998 328i
When I had a stuck caliper, the shop I took it to said they could rebuild the caliper or replace just that one. The mechanic said he thought it looked good enough to just rebuild and stick back on the car. He was only going to replace the one, not both.
Anyways, he is a very good mechanic -- so good that people in my area who have warrantied BMWs will pay to take it to him and his independent shop over the dealer (the dealer here is awful). If he says you can replace one, you can just replace one.
1998 328i
Koni Sport Suspension
Old 02-26-2011, 09:37 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Yea, I think you'll be more than fine just replacing one.
Were you planning on a brand new caliper?
Turbo Build Here
Old 02-26-2011, 10:06 PM
ZeGerman's Avatar
Warm Leatherette
Actually, I just bought two remanufactured calipers from FCP Groton a moment ago. According to their photos (assuming they're accurate photos), they're just rebuilt OEM calipers, and they cost $41.86 a piece with a 15% "tax season" discount, so that comes out to $71.17 for two front caliperes - not bad. I figured at that price, I might as well just do both. I'll get the lifetime warranty on them in case anything goes south.
Hopefully they aren't junk. I'm assuming they will be fine (fingers crossed).
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2011, 08:27 AM
Needs Boost
Mein Auto: Red Sled
That's a good deal for a lifetime warrenty.
Turbo Build Here
Old 02-27-2011, 03:59 PM
that's a good price!!
Old 02-27-2011, 06:28 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, it's a pretty great price. I trust FCP to source rebuilt calipers that are just as good as anything that I could rebuild myself, so I'm not expecting any problems. Calipers are, after all, pretty simple creatures. Just a cast iron housing, a stainless steel piston, and a few seals - not much to go wrong. And like I mentioned before, if their photos are accurate, they're just using rebuilt OEM caliper housings.
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2011, 06:55 PM
ethereal45's Avatar
At that price it's almost cheaper to buy new ones rather than rebuild. Aren't rebuild kits $30 or so?
1998 328i
Old 02-27-2011, 07:51 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
The theory on replacing both is based on the concept that both have seen the same environmental conditions, same wear, and same brake fluid for the same time. If the failure was caused by internal corrosion damaging the seal, then the assumption is the other caliper is in a similar condition and will fail in a similar manner in about the same time frame.
The reality is there are variables in the materials, and the amount of moisture that collects in the brake system and where it settles. I've seen a caliper on one side badly corroded and the caliper on the opposite side look like new. I've also seen both go within weeks of each other.
On the qustion of pulling, if both calipers have the same piston area, get the same flow of fluid, and neither has any leaks, there won't be any pulling. Usually where people experience this is they get one caliper made by a different OEM than the other and there's a difference in the compressive force.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-27-2011, 08:24 PM
ZeGerman's Avatar
Warm Leatherette
Nope, rebuild kits (which consist only of an inner seal and an outer dust boot) are about $3.50. Big difference in price. That said, after discount I paid about $35.00 per remanufactured caliper assembly from FCP. That's pretty inexpensive for a sparkling clean caliper with new seals and piston.
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2011, 08:32 PM
ZeGerman's Avatar
Warm Leatherette
Makes sense, especially since one of my calipers now has now been cleaned out and had a new seal installed, while the old one is the original, yet there is no pulling.
1998 BMW 328is
1966 Pontiac GTO
brake, calipers, e36, pairs, replace
