Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 12-14-2011, 03:15 PM
TxTaz's Avatar
TxTaz TxTaz is offline
It's hot in Texas
Mein Auto: 2005 645CI Convertible
The pads in the center under the engine and on the diff is for jacking only. The 4 pads by the wheels are for jacking or jack stands.
So lift the front of the car using the center pad under engine and put stands behind the front tires on the pads. Then lift the rear using the diff pad and place stands on the pads in front of the rears.
Depending on how low your jack is, you may have to lift one front corner first and support it in order to fit the jack under the front pad.
Taz... My favorite BMW so far.
Sport, Cold weather, Logic 7
19" Miro M6 Wheels w/competition stems
MGP Claiper Covers (BMW)
Dension Gateway 500 and Audio Video Router
AC Schnitzer pedals
Carbon Fiber Di-Noc Trim
5W White Angel Eyes
Polk tweeters
Old 12-14-2011, 10:38 PM
Yorgi's Avatar
Yorgi Yorgi is offline
It really helps to have two jacks if you are putting the car on jackstands.
1) Break-free all the wheel bolts
2) Jack the car up a bit on one of the side/front jack pads
3) Using a 2nd jack lift the entire front of the car using the front middle jack pad
4) Put jack stands under the two front/side jack points - ie the ones from step 2) and lower car
5) For the rear you have two options:
5a) - lift rear of car from middle diff brace - use a rubber puck or wood block to prevent damage to bolts (I am not a big fan of this point)
5b) lift from just in front of rear jackpad point at crossbrace attachment point
6) Put jackstands under rear jack pads and lower car
7) Car is now secure on 4 stands - remove wheels
I am not sure if the coupes have the ability to use point 5b, this may be a convertible-only brace.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-05-2012, 09:57 AM
satobaily satobaily is offline
Mein Auto: 2006 650i
Originally Posted by Yorgi View Post
Hey guys, if anyone ends up using this DIY and finds any problems or something that was not clear, let me know and I'll modify the DIY.
I also have a 55 page Adobe PDF version if you want to print the DIY. Send me a PM and I'll email it to you. It's 15MB so I cannot post it here as an attachment.
Yorgi, excellent, excellent write up! Many thanks for your time and efforts in producing this. I used it the other day and have the following comments:
1. The front brake rotors on the 650 come off easily without removing the caliper carrier. You just rotate them out after pulling them as far forward as you can. They go on easily the same way.
2. Getting your hand behind the box which houses the front brake sensor connector to release the latch was impossible for me. So I used a small screw driver and put it between the "loop" that makes up the latch. This made it easy.
3. The part number on the Permatex Ceramic Extreme Brake Lubricant is actually 24124, not 24125 as you have listed.
Other than that, your DIY was perfect. Outstanding! And, again, thank you.
Old 01-05-2012, 07:39 PM
Yorgi's Avatar
Thanks for the feedback, that is an awesome shortcut if you can pull out the rotors without removing the carriers. I wish I could go back and edit my posts but this site removes your ability to edit after 60 days I think.
Part #24125 is the 8oz "large" brush-top bottle of Permatex Ceramic Extreme Brake Lubricant
Part #24124 is a 2x 7g packet version of Permatex Ceramic Extreme Brake Lubricant
'04 M3 - track
Old 02-13-2012, 06:44 AM
houbmw-cm houbmw-cm is offline
Mein Auto: 2007 BMW 650i
Yorgi,
Thank you very much for the great DIY! I changed out my brakes this weekend, well actually Late sunday night. I had gotten everything removed and was installing then noticed something odd about the OEM replacement brakes. The outer brake bad did not have the clips (2 fingers) on it like the pads I removed. The parts numbers were a match for what I removed. Is this an update that BMW has made to the OEM pads or are my pads suffering from a manufacturing glitch? I wet ahead and installed the pads and the car brakes fine and I have not noticed anything odd.
Thank you and have a great day.
Old 02-13-2012, 08:43 PM
Yorgi's Avatar
Originally Posted by houbmw-cm View Post
Yorgi,
Hmm..very strange. I find it hard to believe they would remove the clips considering the caliper is designed specifically to work with clips both on the piston and on the outside. It will not affect stopping performance but you might have issues with rattling pads when you hit small bumps or maybe more pad squeal.
Maybe BMW switched suppliers? They sometimes have the same part manufactured by multiple companies.
'04 M3 - track
Old 02-22-2012, 05:12 AM
dance171 dance171 is offline
Mein Auto: BMW 645
Fantastic post!
What brand is the OEM discs/rotors?
BMW E63 645 4.4 V8
BMW E63 645 4.4 V8
E92 M3 rims
Lowered
Neon Footwells,
Tinted rear lights with flyeye
Tinted Windows
Numberplate LEDs and bright white angel eyes
Latest firmware update and MP3 capability
Roof wrapped in gloss black
Mapped
Customised exhaust super loud!!!!
Carbon Badges all round
Gloss black brake calipers with decals
Good old BMW tax disc and BMW mirror decals
Old 02-22-2012, 09:51 PM
Yorgi's Avatar
Originally Posted by dance171 View Post
Fantastic post!
OEM as in "from the dealer". BMW has several OE manufacturers for rotors - Balo, Zimmerman, Ate, etc....
I have not seen the OEM 2 piece aluminum hat+steel disc rotors available at any parts stores other than the dealer. All other aftermarket rotors I've seen are single piece "all steel" rotors.
'04 M3 - track
Old 03-09-2012, 04:55 AM
amennrahh amennrahh is offline
BM6er
Mein Auto: 2005 BMW 645ci
As usual, Yorgi's writeup is on point. Thank you Yorgi.
Old 03-15-2012, 06:46 AM
tk123 tk123 is offline
Mein Auto: 650 ic
Thanks! You are the man!
Old 05-01-2012, 05:13 AM
speedharris speedharris is offline
Mein Auto: 650i
Brake monitor won't reset
Hi folks.... First post. First BMW, a 2007 650i convertible (love it by the way)
I changed the rear brake yesterday (Thanks Yorgi, for the great DIY tutorial) with no problems. When I went to reset my rear brake monitor, I got the rear brake warning and now it won't reset. Since I didn't have a warning before I changed them I didn't think I needed a new sensor (I have now ordered one for the rear and front). I plan on doing the fronts today as well as the oil. Any thoughts
Paul
Old 05-01-2012, 05:17 AM
Mine did the same thing. After I replaced the sensor though, it actually reset itself after some drive time.
Old 06-10-2012, 05:53 AM
BeadHead BeadHead is online now
Send a message via Skype™ to BeadHead
Mein Auto: 2008 535i sport
Ditto on the great write up!
And Yorgi, even if I hadn't seen the ON plates, I would have known you were a fine Canadian. With a 10 y/o boy, I too have hockey pucks scattered all over the garage – great jack pads!!
Old 06-17-2012, 08:59 PM
sweepy1026 sweepy1026 is offline
Mein Auto: M6
bookmark already. Very detail and clear DIY post! Thanks!
Old 07-22-2012, 06:10 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Thumbs up Thank You Yorgi!
I didn't need brakes yet, but your post inspired me to look under the air box and check my brake fluid. Horrible. I didn't find your bleeding post but this gave me everything I needed. I didn't even take off the wheels. Very simple and now my brake fluid looks nice and yellow instead of black, all for $12 worth of fluid from the dealer. This is about the fith Yorgi DIY I've followed. You Da Man! Thank you.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 09-30-2012, 04:17 PM
ansetou ansetou is offline
Mein Auto: 08' 535xi white
Hi there,
I need help!
How come I can't push the piston back, still see metal. I used a lever on the c ring and it doesn't seem to be moving a bit.
Thanks.
08' 535xi, White/Black, Premium, Cold Weather, Navi, Logic 7, iPod USB
Old 09-30-2012, 05:38 PM
itscoo2pyopants itscoo2pyopants is offline
Mein Auto: '02 m3, '00 x5, '05 645ci
Try leaving the old pad clipped in, and put the c-clamp over the old pad instead of directly on the piston.
Old 09-30-2012, 10:41 PM
Yorgi's Avatar
Originally Posted by ansetou View Post
Hi there,
I need help!
Thanks.
I agree with itscoo2pyopants, you should NOT push directly on the piston with the c-clamp. If you already have the caliper off the carrier (ie Image #18 in the DIY) then leave the old pad in the piston and tighten the clamp on the middle of the pad (see Image #20).
If you push on one side of the pad, or even worse push directly on the piston, the piston will rotate in the cup and jam. You can also scratch the face of the piston if you push directly on it which can lead to brake squeal.
If you are having trouble pushing in the piston even with a pad in place you can open up the brake fluid reservoir cap which will reduce the pressure required to push in the pad.
'04 M3 - track
Old 01-05-2013, 01:41 PM
Tampa645 Tampa645 is offline
Mein Auto: 2005 645ci
Just finished my rear brakes on the 645. Your instructions were great. Thank you very much.
Old 03-05-2013, 06:18 PM
wingnut1961 wingnut1961 is offline
Mein Auto: 2007 M6 Cabrio
Fantastic DIY! Tip - when compressing the pistons into the caliper to install new pads, crack open the bleeder valve (with a tube connected to a catch bottle) to bleed off the fluid in the caliper and avoid pushing contaminated fluid back through the ABS system. You will be bleeding the system after install anyway, so don't risk contaminating the expensive stuff upstream.
2007 M6 cabrio, SMG, Sapphire Black, Comfort Access, HUD, CF trim, Flat Black Kidneys, CF Lip, LED AEs, RPI scoops, BMC filters (charcoal delete) Evolve Alpha-N tune, custom coding.
Old 03-31-2013, 06:58 PM
juhasev juhasev is offline
Mein Auto: 2007 BMW M6
Thank you
Excellent article! Instructions worked out great for my M6. Thank you!
BR, Juha
Old 06-14-2013, 01:52 PM
NOTORIOUSe60 NOTORIOUSe60 is offline
Mein Auto: 2008 550i Sport
Thanks.
Good eye! I have a hack-around Tissot that I normally wear when working on cars (seen in most shots). I did the brakes over a 2 day period and I forgot to take off my Submariner on the second day.
I know this is old but hilarious nonetheless, changing brakes in a rolex! Cheers! Bang up write-up btw, that one's getting saved... Thanks for the PDF's
2008 LCI 550i Sport - Carbon Schwarz Metallic
Shadowline trim, Nav, Steptronic, Logic 7, Comfort Access, Heads Up Display, 20-way Comfort Seats, 172M wheels, Park Distance Control, Comfort Access, Cold Weather Package, Active Roll Stabilization
Matte Black Kidney Grill, WeissLicht Clear w/Orange led Sidemarkers, WeissLicht White LED Corona upgrade, matte black badging, Dinan High Flow Intake, Dinan Stage III Software Upgrade, Dinan Throttle Body, RPI double M5 intake scoops
