E36 (1991 - 1999)
Old 03-01-2011, 12:02 PM
ethereal45's Avatar
ethereal45 ethereal45 is offline
Send a message via AIM to ethereal45
Mein Auto: 1998 328i
How do you jack up your E36?
Was just curious, I've been using the same method ever since I started getting into DIY projects. I use ramps for oil changes and small stuff, as those are so fast to drive up. For jacking, I use the jack pad from PelicanParts that goes into the side where the emergency jack goes.
I know some people also jack the rear from the differential carrier (or whatever you call that U-Shaped support that covers the differential). I know some people just jack straight from the differential (which I've heard is a very bad practice). I've also heard you can jack from the front crossmember behind the oil pan to lift the front. Just curious what everyone else does. I know this has been discussed before, but all the threads a just everyone calling everyone an idiot for "jacking it wrong."
1998 328i
Koni Sport Suspension
Old 03-01-2011, 12:06 PM
Los's Avatar
Los Los is offline
Too soon Junior
Mein Auto: Elise<3
I used the "differential carrier" the other day.
@hanloso. '98 328i/'09 Tahoe LTZ
Old 03-01-2011, 12:16 PM
CDirks's Avatar
CDirks CDirks is offline
Is a real boy
Mein Auto: White 1997 328i
Bottom of the rear struts and the jack pads for the rear. For the front I use the stabilizer bar
Old 03-01-2011, 12:47 PM
Hellawut??
Mein Auto: who knows?
i use the differential... no problems yet....
And the front crossmembers
-Franklyn
Old 03-01-2011, 01:21 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I wouldn't feel comfortable jacking my car up using anything other than the designated jacking locations on my car. I use one of these and a low profile hydraulic jack:
1998 BMW 328is
1966 Pontiac GTO
Old 03-01-2011, 02:13 PM
ethereal45's Avatar
That is the method I use as well. Does your jack have a "circle thing" on it that the jacking pad fits inside of? Im having some trouble finding a jack that does which isn't too expensive.
1998 328i
Old 03-01-2011, 03:09 PM
ZeGerman's Avatar
Warm Leatherette
^Yes, my jack does have a circular jacking point which has a lip around it to keep the jacking pad from sliding off. My jack is from Harbor Freight, and although it's Chinese-made, I've had no problems with it whatsoever. The cashier hooked me up with a free 2-year extended unconditional warranty (normally you have to pay extra for it). She said just bring it back close to the 2-year mark claiming something is wrong with it (even if everything is fine), and they'll swap it out for a brand new one just to be on the safe side. Works for me.
http://www.harborfreight.com/automot...ack-67022.html
1998 BMW 328is
1966 Pontiac GTO
Old 03-01-2011, 03:31 PM
ethereal45's Avatar
I need to get one of those, the jacking point/contact on my jack is really small, and it's not suitable for use with that pad. My neighbors jack has a much large contact plate...I need to get one of my own.
1998 328i
Old 03-01-2011, 03:54 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, the jacking pad on my jack is plenty wide and the lip has prevented it from slipping off on more than one occasion. I'm perfectly happy with it.
1998 BMW 328is
1966 Pontiac GTO
Old 03-01-2011, 06:40 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Got my jack at Harbor Freight too. $79. I've jacked mine up on the rear diff cross member and the front cross member without any issues. I only use those points when I'm putting it up on jack stands though.
2 Ton Low Profile Floor Service Jack
Item # 67022 Manufacturer: Central Hydraulics
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 03-03-2011, 01:28 AM
RHiN0 RHiN0 is offline
Mein Auto: 325i
bimmerdiy.com has good common maint practices to include jacking methods. One being a center lift point for raising the front. Me personally, I feel better using designated jack points. I got my jack at o'reilly for about 50 bucks. It also came with 2 jack stands which go for 50 bucks themselves. It came with a 1 year warranty and it has a good size circular contact point that i expand with a 6 in long 2x4 to expand the contact even more. It works awesome. O'reilly -----> http://www.oreillyauto.com/site/c/de...d=jack+-+floor
Old 03-03-2011, 09:45 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
These E39 links from the VERY best of E39 Links may be of use to you on the E36:
- How and where to jack up the BMW E39 with pictures of jack pads & jacking points (1) (2) (3) (4) (5) & jack stands (1)
Old 03-03-2011, 07:00 PM
hornhospital's Avatar
D'oh, You Kids!
Kind of a drastic way to illustrate the jacking points, don't you think?
...and the left rear suspension on that E36 is screwed.
Quotes to live by:
Old 03-03-2011, 08:27 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
How easy would it be to fix stuff if you could actually tip your car on it's side like that with no damage.
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 03-03-2011, 08:34 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
thats what this guy did
http://www.r3vlimited.com/board/show...=163048&page=1
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 03-05-2011, 10:50 PM
bluebee's Avatar
The guys on the E39 forum have made a science out of home-made ramps:
- How to make your own BMW car ramps (1)
Old 07-29-2013, 07:21 AM
unashamed fisch unashamed fisch is offline
Mein Auto: 2000 540i/6
Do you know the dementions of this so I can weld up one instead of buying one.
Old 07-29-2013, 07:30 AM
Burning2nd's Avatar
Under the lift arms
Jack points ftw, which is also how u put it on a lift
15486372<-----
Old 07-29-2013, 07:34 AM
Burning2nd's Avatar
Under the lift arms
Lol just posted on 3vr haven't been over that way I years
15486372<-----
Old 07-29-2013, 08:20 AM
Old 07-29-2013, 06:30 PM
shocktower shocktower is offline
Mein Auto: 97 328i
Hey you guy's do know Jack
Old 07-29-2013, 06:33 PM
ZeGerman's Avatar
Warm Leatherette
No, I don't know the dimensions off the top of my head. I can measure it for you if you really want, but I don't know how you'll be able to match the profile of the part which actually slides into the port. You can't just get piece of round steel and stick it in the hole.
1998 BMW 328is
1966 Pontiac GTO
Old 07-30-2013, 03:20 AM
Burning2nd's Avatar
Under the lift arms
thats all it is... takeing a guess with out looking at my car its proably .626 by 8" with a piece of 3" round stock cut at about .375
just a guess though
15486372<-----
Old 07-30-2013, 07:53 AM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
By the time you take measurements, take time to look for stock, measure twice, spend time machining the stock, weld it all together, and hope it doesn't fail, you could have spent the ~$40. Just buy the adapter.
Old 07-30-2013, 10:09 AM
ZeGerman's Avatar
Warm Leatherette
Originally Posted by Burning2nd View Post
thats all it is...
Except for the profile milled into it which is necessary for fitting it into the port...
1998 BMW 328is
1966 Pontiac GTO
