Old 03-01-2011, 03:25 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
What's the wheel bearings life expectancy?
In normal driving, no tracking.
What is a realistic mileage for them assuming you have no duds?
I have no issues now, but I am curious at what mileage to look out for?
Old 03-01-2011, 03:33 PM
530iman's Avatar
530iman 530iman is offline
03 540i now
Mein Auto: 2003 bmw 540i E39
I replaced my fronts at 155,000 when the right started to make noise I think the rears have been replaced
2003 540i M-Sport custom magnaflow exhaust so far....
Old 03-01-2011, 05:38 PM
bcbp14's Avatar
bcbp14 bcbp14 is offline
Mein Auto: '87 535is
The front bearing on my 99 528i lasted until 160k, rears are just fine at 195k.
Old 03-01-2011, 06:38 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
i guess 150-200k miles as a minimum
my cars dont have this kind of issue at ~100k miles
Old 03-01-2011, 10:27 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
My left rear failed at 200k. Others ok
Old 03-02-2011, 08:44 AM
doru's Avatar
OK, thanks guys.
Some other cars have bearings that fail close to the 100 k mark, some sooner. Other car makes last about 150 k.
So it's fair to say that our wheel bearings are good quality and will last 150 - 200k miles?
Old 03-02-2011, 09:15 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Zeckhausen says to replace them preventatively around 80k in his brake DIY. I'm thinking 150k miles would be a better number though.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 03-02-2011, 12:02 PM
Pensioner Pensioner is offline
Mein Auto: BMW 528i
You guys are scaring me. My car has now done 211k and I have never even looked at it. Brake rotor and discs last about 75k. It pays also not to race from red light to the next red light.
Old 03-02-2011, 12:49 PM
540nj 540nj is offline
Mein Auto: 03 540i6
My front bearings both went before 70K miles, maybe because 540 is heavier? Also I like to push the limit on sweepers...
My indy says cars that track regularly need frequent bearing replacement.
dave
03 540i6
Old 03-02-2011, 07:11 PM
helpmyfive helpmyfive is offline
Mein Auto: 528i
I bet the life depends GREATLY on proper alignment. Even 1 degree off and you are putting continual pressure on them.
Old 03-02-2011, 08:45 PM
ztom's Avatar
dave
03 540i6
+1 I think the front bearings will last longer if not a lot of fast tight turns. My car has 220K miles and the front bearings have no play.
I had to replace my driver's side (left) rear at 200K but not the right rear. My theory is that cars make more tight right turns then left ones, like at intersections. When my rear bearing went, it went from "Hmm I hear a noise" to "I need to replace that" in a period of about 4wks driving.
Old 03-02-2011, 08:57 PM
ElwoodBlues ElwoodBlues is offline
Mein Auto: 2002 530i Sport
I think mine have been questionable since I bought the car at 130K.
I'm not 100% sure its bearings, but the front left has a definite change in tone depending on steering. (Straight = some noise, left turn = less noise, right turn = more noise) Back seat passengers think there is excessive noise from the rears, but I suppose that could be the differential also? Tried to inspect them all but couldn't find anything conclusive.
Old 03-02-2011, 10:11 PM
bricas45's Avatar
bricas45 bricas45 is offline
Mein Auto: '01 540i6, '94 325is
My fronts failed at just under 120k on my 540
2001 540i - Orient Blue
M5 bumpers, wheels, mirrors
S/C, water/air IC
A1 Headers, Random Technology Cats, Eissenmann Exhaust
3.15 diff, evosport power pullies
Koni Sports, Eibach Springs/Sway Bars
Old 03-02-2011, 10:23 PM
ztom's Avatar
As diagnosis, on my rear left bearing the noise would go away if I made the slightest turn to the left, takes the load off the left. I think in advanced case of front bearing wear, a high turn will push the rotor and when you brake there's a little delay as the caliper piston pushes back onto the rotor. I did a write up when I changed my rear bearing, can do search.
Old 09-27-2013, 07:53 PM
Jim Scott Jim Scott is offline
Mein Auto: 335i
137K on my 2009 335i and I seem to be hearing a little humming. I'm just looking at the blog wondering...bearings or brakes. I know I'm due for front pads and maybe rotors. Any sure fire ways to tell?
Old 09-27-2013, 08:24 PM
mucho mucho is offline
Mein Auto: 1999 528i and 2012 X5
My 99 528i at 181k and drive the canyons every day (65 miles round trip) and still going strong.
Old 09-28-2013, 01:10 PM
dvdlkd dvdlkd is offline
Mein Auto: 1997 528
I just replace my front bearings at 263k miles (97 528). They were still tight (no play) but they were dry. I could hear the roller ball bearings clicking over the top when the brake caliper was removed for brake pad replacment.when The rear bearings are still original. ZBOT, if you get back to this thread, what indications told you your right rear wheel bearing was going bad?
