Old 03-03-2011, 11:37 AM
stroatenmoaker stroatenmoaker is offline
Touringman
Mein Auto: 530i Touring 2001
Does a defective thermostat affect your MPG
Thermostat will be replaced soon, gauge is not going further than 10 o'clock position, never reaches 12 o'clock. Does anybody know if a defective thermostate (always fully open) affect your MPG ?
Thanks.
BMW 530i Touring 2001
Old 03-03-2011, 11:43 AM
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
I would guess yes - slightly, in that the engine does not get up to optimal operating temperature.
Old 03-03-2011, 11:44 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
If your engine is cold then yes, it will use more fuel. My dad once took the thermostat out of my mums magna and just run it without one. Ran like sh1t because it was always cold and the consumption went through the roof!
Sent from my iPhone using BimmerApp
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 03-03-2011, 11:46 AM
bobdmac bobdmac is offline
Mein Auto: 2001 540i/6, '90 BMW k75s
It will hurt it somewhat because thermostats keep the engine at its most efficient operating temperature. Maybe someone with some first-hand knowledge can quantify it in terms of MPG per degree of deviation.
Old 03-03-2011, 11:53 AM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Hofmeister Kink
Mein Auto: 2003 530i/5
Yes it will.
BMWCCA # 430911
Old 03-03-2011, 01:15 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
It depends on the mode of failure.
Stuck HOT: Engine overheats ---> $4-5K damage
Stuck COLD: Engine runs cold, fuel mixture is rich ---> lowering the fuel mileage.
Old 03-03-2011, 02:37 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Unless all your driving is under five or ten minutes, I can't imagine that first five minutes of slightly cooler engine temperatures mattering all that much to your gas miles per gallon given all the other variables in the mpg equation.
BTW, do you have the high cluster?
Old 03-03-2011, 10:57 PM
Touringman
Yes, I do have the high cluster
Old 03-05-2011, 09:35 PM
bluebee's Avatar
Then, even with the averaging gauge busted, you should be able to read two different KTMP figures (from the dual temperature sensor) on your cluster as shown in my post above.
- High instrument cluster check of the cooling system temperature KTMP (1)
mpg, thermostat
