Old 03-04-2011, 05:41 PM
israchido1 israchido1 is offline
Mein Auto: Z4 roadster
Z4 roof top stock
Hi, there I am new. My problem that I have with my 2003 Z4 roadster is that the rag top dosn't open any more. Does any body has an idea of what could be bad? is automatic opener and only make noises. I would appreciate
Old 03-04-2011, 06:08 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
If you search and read through the posts, you will find that the most probable cause with the limited information you gave is that your electro-hydraulic motor is bad.
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 03-04-2011, 07:01 PM
rcleme05's Avatar
rcleme05 rcleme05 is offline
Some Say...he apexes late
Mein Auto: Z4MR
You might check the two rotary locks in the trunk to be sure they are disengaged. If not, the top wont move, and the light just blinks.
--Triple Black '06 Z4MR, Remus, V1, 3.91 gears, CDV, KWs, UUC, Mason Engineering Clutch. Zip 90034 -- Z4M Flickr Gallery
-- All head gaskets die; only some have truly lived!--
Old 03-05-2011, 10:25 AM
shipkiller's Avatar
Mein Auto: Me
If his motor is running (making noise) then all the switches and interlocks are good.
Those two 'rotary handles' just raise and lower the 'Convertible Top Floor'. The CTF has a tap/tang in the middle of it that actuates the micro-switch on the bulkhead.
A faulty motor can make noise but not provide enough hydraulic pressure to move the top.
Old 03-05-2011, 10:36 AM
Swanicyouth's Avatar
Swanicyouth Swanicyouth is offline
Mein Auto: M Roadster
I'm 90% sure Yr motor is bad. The older Z4s have issues with water getting in the motor. Most of them died in five years or so that saw a lot of water. I believe Shipkiller has an excellent DIY someplace. If you hear it running above your head but the top doesn't retract, that's the most likely scenario
