Old 03-05-2011, 11:09 AM
auerman auerman is offline
Mein Auto: Z3
Injector Problems
I have a 2002 Z3 roadster 3.0L Picked it on Friday the following Friday I started getting a check engine code. Bank 2 lean. I inspected the engine compartment and found a vacuum leak in the mass air flow boot. Taped it up and ordered a replacement. The next day it started skipping. Found #4 cylinder injector does not appear to be working. No ticking with a screw driver test. Any suggestions on where to go with this. When I pulled the codes there were about 5 sensors that did not report. Thinking maybe a DME module.
Old 03-05-2011, 05:14 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
When you get into the multiple code issues you really need to take it to a good independent BMW shop.
A lot of these codes related to lean or misfire can be related to one or two problems.
If you have a crack in the intake boot, get that fixed first, clean the MAF. try swapping injectors if you feel there is an issue but all in all you maybe better getting it looked at with better computer than just a code reader.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 03-08-2011, 01:36 PM
Mein Auto: Z3
Installed the boot, swapped the injector with the cylinder next to it and the problem stayed. Although I noticed the injector did fire until the misfire code reappeared. Then the injector stopped firing. Swapped the coil with the cylinder next to it and the problem moved. Going to pick up a new coil. This should fix it. will let you know
Old 03-08-2011, 03:44 PM
Mein Auto: Z3
New coil pack did the trick....puring like a kitten
