540 valve cover gasket manufacturers-
I see that there are 3 different gasket manufacturers offered by Pelican parts. They are all priced about the same. Is there a one that is "better" than the others or are they all basically the same?
Elring Klinger Meistersatz Victor Reinz
Good question. Maybe Pelican can suggest one with a phone call. Please let us know what you find out. Thanks.
Frank 540/6 Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy |
Ok, Franka...
Pelican said Victor Reinz is the way to go. Hopefully they are not just trying to get rid of the junk ones that nobody buys.
Was there a difference in price between the 3 choices? And what apprx is Pelican changing for valve cover gaskets these days?
Fairly reasonable, the low was $15.85 a set which does one VC and the high was $18.65 a set. Under $50 when you include new rubber bolt washers.
The Victor Reinz was on the low side.
Victor Reinz is very good quality, and so are the other 2. They are OE replacement parts or if not, close or identical to OE standards. I would use anyone of these.
I must admit I had very good luck with Victor Reinz so far.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
Thanks guys.
Thanks to the teaming up in this thread, we have a new reference addition to the bestlinks (namely which VCG brand to buy):
- How to replace the valve cover gasket (1) (2) (3) (4) (5) & which VCG brand to buy (1) (2) Last edited by bluebee; 03-09-2011 at 10:39 PM. |
I am honored for this thread to be inducted into the bluebee best links database.
![]() BTW, today, someone asked just now this question: - Valve Cover Gasket Brand - How Important Quote:
I did, its true. I actually did search, but I must not have used the right combination of keywords.
I ended up going with OEM. Outside of having to figure out the part numbers, they ended up being roughly the same price as the higher end aftermarket and "kits" 11 12 0 034 105 Left 11 12 0 034 104 Right 11 12 1 437 395 seal - 8 per valve cover 11 12 1 721 879 seal - 3 per valve cover For my 2002. Earlier cars use different parts (the gaskets at least, not sure about the bolt seals) Scott |
For the cross-linked record, this came in today:
- E39 (1997 - 2003) > Aftermarket parts |
Based on my research Victor was the way to go and that's what I went with.
Based on my research and on the advice of bimmerteck, I discarded my like-new Victor Reinz gasket after about 15,000 miles and replaced it with a Genuine BMW one when I had to replace my valve cover.
This thread today suggests the same:
- What BMW E39 parts & supplies are most often recommended to buy OEM from a dealer or sponsor (1) And, cross reference to these: - How to replace the E39 V8 valve cover gasket (1) (2) (3) (4) (540 pdf) (E38) (E38 pdf) & VCG DIYs for the E39 I6 M54 (1) (2) (3) (4) (5) (2004 E46 video) (another E46 video) (yet another E46 video) & which VCG brand to buy (1) (2) & what VCG lubricants to use (1) & how to replace the timing chain tensioner and rail guide on the I6 (1) & on the M62 (1) & on the M62TU (1) (2) (3)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-17-2012 at 05:08 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
