E34 (1989 - 1995)
Old 03-16-2014, 10:18 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Originally Posted by E34ZombieHunter View Post
That's awesome!!!! To bad im not going the DD anymore.
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 05-13-2014, 05:29 PM
d0ugi3 d0ugi3 is offline
Mein Auto: 535i
Originally Posted by robertobaggio20 View Post
A contribution : using a fuel pressure regulator meant for the the immediately lower capacity in your engine class (i.e. using a 520s fpr in a 525) will improve fuel economy by 10% or higher without any noticeable fall in low and high end performance. The engine will not start any differently either. IOW, if someone did the swop while you were not looking, you wouldn't notice the difference at all after you got back into your car and drove off. For the m20 engine, the 525 uses a 3.0 bar fpr while the 520 uses a 2.5 bar one. For the m50 cars, the 525 uses a 3.5 bar fpr while the 520 uses a 3.0 bar one.
Another contribution : using a heat shield to cover the starter does not significantly affect its lifespan.
What is the option for this for the 535i .. I'd love to get a little more mpg
Old 05-13-2014, 07:53 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
not much. Short of a more modern engine.
Coming from someone who's passionate about that old workhorse sounds strange.
But its actually spot on.
The most you can do is to do a full tune up including a valve adjustment which should yield
you a good 18 maybe 20 mpg depending on driving habits, environment, and geographic location.
That said I do know of a guy named Shogun who has fuel efficiency chips for the m30 but he'll have to fill you in on the details himself.
He's a member of Bimmerforums and also has his own webpage which I linked in the e34 bible.
_______________________________________
Content Writer - FCPEURO
95 e34 525 5 spd S52 Swap...Sold
01 e38 740i msport (under restoration )
Old 05-27-2014, 12:22 AM
Mein Auto: 535i
If it's like bumper to bumper traffic I get about 16 mpg
If it's average city driving I get about 18 mpg
And highway I get 22-20 depending on my speed (64-75)
So I get decent mpg but wouldn't mind better and if a smaller Fuel pressure regulator would do the trick and I wouldn't lose too much HP . Sign me up
Old 06-10-2014, 09:38 AM
MeanM50 MeanM50 is offline
Mein Auto: E34/5
One note, if you are planning a custom tune, (bigger injectors, turbo, WAR chip, swap, etc...) the 540 hfm IS an upgrade as it's reporting resolution is much higher. This allows for more incremental tuning if you know how to use it. If you don't understand what I just said...ignore this post.
Old 06-10-2014, 11:12 PM
Good post MeanM50. Glad to see your still around. BF.C and/or here
Old 06-11-2014, 10:30 AM
Mein Auto: E34/5
My name on other forums is E34ührer. I am always around. I don't come here often. This place is too frustrating most of the time. 'Facts' become 'lies' and false info becomes 'fact' here a bit more than I care for. I pop in once a year to check things out...we will see how long it takes this year for the mods to gang up on me and give me infractions because I don't agree with their friends...
Old 06-11-2014, 12:45 PM
Understood, and Understood.
Yeah the facts become lies and false info becomes Fact thing we've been trying to curb to a halt lately. It is freakin' frustrating.
I wouldn't worry about the ban thing.
With the combination of a few bfc veteran crossover members and the more seasoned fest members we pretty much police this ourselves.
Because of this it's been pretty loose and not as uptight as it used to be.
The Mods step in more or less to make sure that we don't start attacking each other in a cannibalistic frenzy.
Yeah I know who you are. Lol
But I must have got you confused with MeanM50 from bf.c. with the calypso e34 from out west.
Still the greeting is the same. Welcome back.
Old 06-11-2014, 12:51 PM
Mein Auto: E34/5
Same person...me. sold the calypso sedan. Orient touring replaced it.
Old 07-26-2014, 10:20 AM
fabian5 fabian5 is offline
Mein Auto: 02' 325i 5spd
ID:	454500 is this thing legit cause theres gotta be some type of catch for a chip this cheap. Does it work is my question?
Fabian
Old 07-26-2014, 11:02 AM
Originally Posted by fabian5 View Post
Attachment 454500 is this thing legit cause theres gotta be some type of catch for a chip this cheap. Does it work is my question?
Fabian
Chips to go with:
Dinan
E.A.T
Racing dynamics
Ultra chips
AC Schnitzer (rare)
Dudd chips
W.A.R chip
Shogun
I probably forgot some but unless its one of the above chips stay away.
Old 07-26-2014, 11:04 AM
Okay cause i wanna get some more power on my 93 525i and i was wondering if the ebay chip really worked or but thank you a lot !
Fabian
Old 07-26-2014, 11:44 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
1. Running lower than stock FPR will cause your A/F rations to be lean on WOT. You will also be running hotter on average. Fuel cools internals.
2. Heat shields protect wiring and heat soaked starts, they are standard and it all depends how hot it is in your city and how hard you drive.
Also they are there to protect from corrosion and road elements (salt).
Not only this is a dumbest thing I have ever read, you are actually trying to damage peoples vehicles.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 07-26-2014, 01:04 PM
Lol your late to the party on that. We already debunked Bobby's theories. but you do bring a valid point. It should be removed for the sake of good info.
Old 07-26-2014, 10:02 PM
1995i540's Avatar
Founder @ Maintenr
Sorry, I just read that and had to respond
Old 09-22-2014, 03:47 PM
fabicroki fabicroki is offline
Mein Auto: 1995 525i
http://pages.ebay.com/motors/link/?n...194854&alt=web
Is this one good?
crok
Old 09-25-2014, 12:29 AM
thumper600's Avatar
thumper600 thumper600 is offline
Mein Auto: '95 540i M-Sport, 01 M5
Well, being old school mine has a DINAN supercharger with all the ECU upgrades and to slow me down the Nuerburgring brake package. If I could only find brake pads stateside for less than $160.............................................. ...............
Old 08-12-2015, 02:15 PM
stxe1 stxe1 is offline
Mein Auto: bmw e 34 525tds
Terraclean engine and turbo air intake does wonders not huge gains5-10bhp but u really feel it
Old 09-19-2015, 09:37 PM
mrkanda mrkanda is offline
Mein Auto: 1992 E34 535i 5spd
What is the compatibility of swapping E32 suspension/ struts onto an E34?
Old 10-30-2015, 09:09 PM
From a eyeball...Strut wise and CA wise they are relatively the same.
The e38 is a different story.
Old 08-02-2016, 04:27 PM
BMW_507_4ME BMW_507_4ME is offline
Mein Auto: 530i
HP VS Torque
I read some, but not all of this thread, but enough to want to TRY to explain the difference between street / road cars and race cars. 1st, higher cam lift and longer deration are not what makes your car a fast street car. If you are an all out race car driver, and your not, it 'can" be what you are looking for. There are trade offs. you can sacrifice all your low end torque for high end HP. That is a very bad trade off for street driving. If you plan to operate you motor between 5000 and 8500 RPM most of the time, it can be a good thing. BMW made some progress with this problem with the Vanos timing that changes deration according to rpm to try and give you "some" of the best of both worlds.
Next, super free flowing exhaust. More of the same as above. Great when in the very high RPM ranges, means very little for a daily driver, in fact, many motors preform better at normal speeds / rpm's with some back pressure to offset cam overlap. A case in point, many here may remember the PONTIAC GTO back in 1965, the father of all muscle cars in the US (though not really, the 1961 two ton PONTIAC Catalina 421 SD was turning 12sec quarter miles from the factory before John D. invented the GTO). How were they doing it, with huge racing cams and hooker headers? No, with low end torque mild cams (by todays standards) cast iron headers, low end gear ratios and lots of cubic In. Well we don't have the big cubes today, but the rest remains the same, torque gets you from stop light to stop light quick, and HP gets you from 130mph to 145mph fast. Which describes better how you drive?. If you are a NASCAR driver, then disregard this bit of wisdom.
A great example is BMW's own M roadster, the 2000 was a sad 240 HP, the 2001 was a huge 315HP!, yet, there 0 to 60 and quarter mile times were just tenth of a second apart???? That is because their torque ratings were almost the same. (and most of the gains for the 2001 and 2002 were gearing changes, not HP related) Well, now you know, or you don't know, It is up to you to understand, or not
bmw tuning, e34, e34 tuning, m50 upgrades, upgrades
