Old 03-07-2011, 10:22 PM
BeemVerg's Avatar
BeemVerg BeemVerg is offline
Officially Bimmerfested
Mein Auto: '01 530i
Oil Pan Gasket replacement - how much ?
My BMW cert. mechanic is charging me $562 to replace an oil pan gasket. Is that reasonable ? Isn't it a matter of lifting the car, removing the "easy to reach" nuts and bolts, replacing the gasket, putting bolts back ?
Job01 ENG. OILPAN GASKET 530I 01 Labor: $450.00
__________________________________________________ ________________
11-13-1-437-237 OILPAN GASKET 1.0 @ 46.00 =$ 46.00
5W30 ENGINE OIL 7.5 @ 7.50 =$ 56.25
R+R LOWER OILPAN TO REPLACE GASKET
OILLEAK FRONT FRONT OILPAN GASKET
Estimate Cost Summary
Haz Waste: $1.50
Tax: $8.95
Estimate Total: $562.70
Pictured above: Smart Car circa 1955.
'01 530i, ///M Sports Package, Xenon lights, Steptronic A/T, icelinkPlus iPod module
'04 328i, Sports Package, Xenon lights, Dice iPod module
Old 03-07-2011, 10:29 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
it is
6-8H labor but nothing complicated
do it
Old 03-08-2011, 06:51 AM
cn90 cn90 is offline
It is probably NOT the Oil Pan Gasket, that thing rarely leaks before 200K miles.
This was what I though a few years ago. It turned out to be the Oil Filter Gasket, a $6 part from dealer and 3h labor.
Here is the DIY:
http://www.bimmerfest.com/forums/sho...d.php?t=414315
Old 03-08-2011, 07:13 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Cam has been right very often (I've seen plenty of people come here swearing they have a oil pan gasket leak only to find that five dollars later and a few hours of effort, they're happy to resolve the OFH leak).
Here's what is in the bestlinks on this (the bestlinks has ALL of Cam's DIYs!):
- CCV FAILS: crankcase ventilation valve diaphragm tears, freezes (1), &/or clogs (1), necessitating CCV replacement (M54,M54,M54) (M52,M52) (M52TU) (M62,M62) ('99 528i) ('98 528i); raising pressures, often causing the OFH oil filter housing to leak (1) (2) (3) (4); frequently blowing the VCG valve cover gasket (1); and sometimes the head gasket (1) (2); often causing vacuum leaks (1) (2) (3)
As for labor charges, simply go to the bestlinks to find:
- BMW phantom diagrams (1) & nominal prices by part number (1) labor rates by zip code (1) (2) (3) where to find a good mechanic (1) (2) joining BMWCCA (1) (2) & finding a reputable BMW indy in your area (1) (2)
Old 03-08-2011, 07:54 AM
BeemVerg's Avatar
Mein Auto: '01 530i
He already replaced my oil filter housing seal (cost me $387) and it still has dripping oil. Now, he says it's the oil pan gasket.
I cut and paste his estimate on my initial thread.
Old 03-08-2011, 08:03 AM
Then check the OFH Gasket area with a mirror again.
- Clean the whole area with engine cleaner and some gentle water spray.
- Run engine, go shopping etc for a few hours.
- Check the area below the OFH Gasket area with a flashlight and telescopic mirror.
Or better yet, check it from below with a flashlight (remove splashguard 1st).
Old 03-08-2011, 08:12 AM
bluebee's Avatar
Well, if it 'is' the oil pan gasket, it's apparently not pretty on the I6 to replace:
- How to fix broken or stripped oil drain pan plug bolt threads (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) & replacing the oil pan & how to replace the BMW E39 oil pan gasket DIY (1)
Old 03-08-2011, 08:44 PM
BeemVerg's Avatar
Mein Auto: '01 530i
HOLY ! Sorry about your experience! I guess paying him almost $600 is worth it.
btw, thanks for all the tips! At least my mechanic is on the list.
Old 04-26-2011, 08:59 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Bump.
Anyone do this?
Old 04-27-2011, 04:16 AM
Mudbone Mudbone is offline
Mein Auto: 2003 530i
Originally Posted by Jason5driver View Post
Bump.
Anyone do this?
I replaced my oil pan gasket without removing anything other than the attaching fasteners. I cut the replacement gasket into two pieces in order to get it back in and then applied gasket sealant at the cut lines to seal those areas. You can do this job in 2-3 hours. Search for my thread "Replaced oil pan gasket" for the full story.
It has been over 3 weeks now with NO LEAKS!!
Old 02-21-2017, 04:57 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
I did the search but only this is popping up. If you're still on can you pop the link up? Thanks!
Sent from my SM-G935V using Bimmerfest mobile app
Old 02-21-2017, 07:26 PM
Wgosma's Avatar
Wgosma Wgosma is offline
Mein Auto: 2000 528i M-sport 5spd
Look here: (VERY long thread) http://www.bimmerfest.com/forums/sho...166&highlight=
Bill / Oceanside, CA
00 528i - 5 spd M-Sport
Old 02-22-2017, 05:55 PM
I would not cut the gasket and install it.
I replaced the oil pan gasket, and it literally exploded when removing it.
Pieces of plastisized rubber fell all inside the pan.
Drop the front subframe, then the pan - do it right.
Old 02-23-2017, 08:14 AM
Wgosma's Avatar
....tho the gasket can be replaced w/o dropping subframe it sure looks like an awkward and tight space to be working in. Frankly, unless the leak is significant I'd leave it alone and I've with it.
Old 02-24-2017, 02:23 AM
Chedley Chedley is online now
Mein Auto: 2001 E39 540i
Jack up the front of the car by about 20 inches. Then you can crawl under the frame to remove the oil pan, and replace the oil pan gasket. It is a 2 hours job, not too difficult.
Also, after removing the oil pan, and while you are under there, make sure you check and if necessary tighten the oil pump bolts.
See https://www.bimmerforums.com/forum/s...IY-replacement
Old 02-24-2017, 02:34 AM
Check this write-up. It is doable. http://www.magnum1.com/magnum/BMW-74...-Bolts-740.php
Old 02-24-2017, 03:59 AM
Alika808 Alika808 is online now
Mein Auto: X5/330/Range Rover HSE
Check this site the cost estimate. Just input the car information and your location.
https://repairpal.com
Old 02-24-2017, 09:42 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
It's not that easy on the I6.
2002 530i
Old 02-24-2017, 09:47 AM
u.nanimous u.nanimous is online now
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
Alika has a good response but I'm not sure anyone else is paying attention. This thread died back in 2011 and it started about an E39 530 but some recent links are in regards to the M60 and M62 engines which is the V8 so...
Are you asking this about your 2009 335i?
Edit: Sorry for leaving you out c4t, you must have posted while I was typing. +1
Before...
After...(this may take a few years, it's my DD and I have bigger projects)
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG (hello X7, and lottery!)
1999 BMW 740i - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 BMW 330xi - fXtXeX/son project time - still needs work but he's driving it
2008 BMW 335xi - quite the replacement winter beater for an Impala!
