sun roof won't stop at closed position - Bimmerfest - BMW Forums
Old 12-23-2012, 07:17 AM
Patrick W Patrick W is offline
Mein Auto: '98 540i
Ive recently purchased a 1998 540i. The sun roof is not closing. It will operate fully opened and fully tiled, always runs right past the fully closed and sealed shut spot.
Any suggestions as to why? Quite frustrating now that winter is here. I have found the tool and method for closing it manually, wheather is not coming but I'd like to get it to operate correctly.
Thanks in advance,
PWS
Last edited by Patrick W; 12-23-2012 at 07:46 AM. Reason: I found how to close it.
Old 12-23-2012, 07:41 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
try reset: push and hold the dression part of the
switch 5 seconds and see if it rests. Do it with engine running
Old 12-23-2012, 08:07 AM
Mein Auto: '98 540i
"...try reset: push and hold the dression part of the
switch 5 seconds and see if it rests. Do it with engine running ...'
@ jygesq : please forgive me but I don't understand the above "...hold the dression part of switch..."
Old 12-23-2012, 09:39 AM
press the sunroof switch in, instead of sliding it
that resets the system, sometimes that works
Old 12-23-2012, 07:04 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Not proof reading will get ya everytime.
Here's info from the owners manual..see the last paragraph in the far right column for reset procedures due to malfunction or power loss:
Q {BMW CCA Member #191509}
(SOLD)
Old 12-23-2012, 11:21 PM
More information may be found by typing /sunroof F3 in the bestlinks, e.g.,
- How to repair & reset the sunroof or moonroof (1) (2) (3) & how to remove the headliner (1) & how to free up a stuck open sunroof or moonroof (1) (2)
Old 12-24-2012, 06:58 AM
moots's Avatar
moots moots is offline
Dinggg....what now!
Mein Auto: '04 525i
i think you are closing it wrong.from full open,to close,slide switch forward and hold.to tilt from full open,push switch up momentarily and release.the roof will go all the way to tilt.to close from tilt,slide switch fwd and hold.to open from full close,slide the switch aft momentarily.to tilt from full close,push switch up and hold.
