E36 (1991 - 1999)
Old 03-09-2011, 02:46 PM
e364Banger e364Banger is offline
Mein Auto: 1994 318i
sputters once its warmed up but idles just fine??????? WTF?
so i just picked up a 1994 BMW 318i and fixed the overheating problem with a simple thermostat replacement. i was stoked till i started driving it and once it warms up it sputters, spits, backfires and misfires like CRAZY!!! oddly enough though it idles like a dream. what in the world could be causing this??? i have already run seafoam through it and replaced all 4 spark plugs. no improvement at all. I got home from work today and started it up to pull it back in the garage to work on it and spun it around the block. when it is still cold it runs, accelerates, and everything perfect so i kept it running and let it get up to operating temperature and then i spun it around the block again and it ran horribly. is it the MAF sensor? O2 sensor? dirty intake manifold? PLEASE HELP!!!
Old 03-09-2011, 08:39 PM
Hellawut??
Mein Auto: who knows?
Check the codes.
Search e36 pedal trick in google
-Franklyn
Old 03-09-2011, 11:40 PM
KitsuKo's Avatar
KitsuKo KitsuKo is offline
'92 325I Rollin Stoned
Send a message via MSN to KitsuKo
Mein Auto: 1992 E36 325I
Ill be nice
http://www.bmwe36blog.com/2007/01/24...d-diagnostics/
It is difficult but, the key is start pressing the pedal EXACTLY when the dash lights come on
Old 03-10-2011, 10:59 AM
Cool. I'll do that tonight. I am also gonna check for proper ohms on my MAF sensor, throttle positioning sensor and o2 sensor. Supposedly u can google how to meter them and what they are supposed to read on each one.
Sent from my DROIDX using Bimmer App
Old 03-11-2011, 07:49 AM
kode302 kode302 is offline
Mein Auto: 1998 328is
how bout the tps sensor? its the t shaped one by the throttle.
[B]Member of the Non-M Bumper by Choice Club[/B
Old 03-11-2011, 08:29 AM
I metered the MAF last night and it appears to be out of limits. My TPS has resistance that changes as I pull the throttle back an forth and never goes to a zero value so I believe that is still good. Any one have a MAF sensor for a 1994 318is? New they are like 450+.
Old 03-11-2011, 08:32 AM
Oh yeah. The code it gives is 1214. Cant find a definite answer on that one. Some say MAF, some o2. Who knows?
Old 03-18-2011, 05:00 PM
e30luv22 e30luv22 is offline
Mein Auto: 1997 328i
maybe the distributor ?
before i got my e30 I drove a tacoma, and i know bmw and toyotas are very different but it was doing the exact same thing and i tried the o2 sensor, and all spark plugs but it didnt work so i replaced the distributor and it ran fine, no problems
bad acceleration, good idle, help advice needed, misfire
