Manual,Convertible top latch replacement - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 03-10-2011, 04:00 PM
52vincent 52vincent is offline
Mein Auto: 1991 318i Convertible
Hi Everyone, new here
1991 318i
I have searched tirelessly to no avail on this site for my dilemna.
Is it possible to replace the door handle for the convertible release without removing the side panel? I have tried but cannot figure out how to disconnect the wires from the old latch which is hanging inside. I can get my hand in there but don't know how to remove the wires form the latch.
If I have to take off the inside panel, how do I do that?
Thanks for any help, I have found many answers here for other things and like the site
Great Job.
Old 03-10-2011, 08:50 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
1991 318i
Great Job.
You can do it, it will not be easy, and it will not be fun, but i've done it so it CAN be done. You just have to be patient and keep trying until you get the wires back attaches to the handle.
Old 03-15-2011, 01:54 PM
mlbryant8 mlbryant8 is offline
Mein Auto: 92 e30 mtech vert, 07 X3
Removing the wires that release the top is easy. Reattaching the wires to your new or replacement release is the hard part to do without taking out the side panel. You simply have to take out the plastic cap that prohibits the release wires from coming out of the handle. Be careful not to drop them! After that, it is a hit or miss type of situation. You will probably get frustrated and end up removing the side panel.
Old 03-21-2011, 04:46 PM
Mark_325i's Avatar
Mark_325i Mark_325i is offline
Mein Auto: '03 325i, '88 325iC
I did it a few years ago without taking off the panel. Grab the wire with a needle nose vice grip and you can just barely thread the tab into the new handle. No real trick to it -- just patience and a steady hand.
Mark
88 325iC
03 325i
Old 03-21-2011, 07:12 PM
Krumchev2's Avatar
Straight Bimmin
I did the exact same thing. Very frustrating. Patience is the key.
Old 04-26-2011, 12:17 PM
paxmaster2000 paxmaster2000 is offline
Mein Auto: 92 525it, 08 dodge ram
ok where can i get one of these handles? mine is broken. ci have checked the yards but no luck on any convertibles. i have checked the sites.
Old 04-26-2011, 12:39 PM
Krumchev2's Avatar
Straight Bimmin
Hahaha I just used a regular door handle. There's no difference
Old 04-26-2011, 12:59 PM
that is what i was hoping to hear.
Old 03-27-2017, 11:42 AM
jcjr1318i jcjr1318i is offline
Mein Auto: 1991 BMW 318i Convertable
How about the underlying problem of a broken handle.
I've done it as well.
Not easy, but it can be done.
Now I have the do it again. My question is; does anyone have any ideas to reinforce this handle?
The housing seems pretty thin to be holding those pins on the handle itself.
Thoughts?
