3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here. |
E46 Alarm FAQ
This is a FAQ for those who might have alarm questions. I'll update it as I get updates from others.
Updated 11/21/04. --- Q: Does my car come with an alarm? A: The car's central computer is the alarm, what are missing in all E46 cars delivered from the factory are all the sensors to trigger the alarm. An OEM kit is available from the dealership that includes the motion detector, tilt sensor and siren. Q: Where can I purchase a cheap OEM alarm? A: Circle BMW (www.circlebmw.com) for $225 or Pacific BMW (www.pacificbmw.com) for $234 Q: What does it include? A: Siren, tilt sensor, interior motion sensor, and necessary screws Q: Do you recommend an aftermarket system instead? A: Some people have gone this route, but most people find the OEM alarm to be sufficient for their needs. Q: Is it worth it? Don't thieves know how to quickly disable them anyway? A: It's worth it if you want a pretty decent alarm. YMMV as with all alarms and depending on your area and your (bad) luck. Q: Can't I just activate the clown nose without the alarm? A: Yes, you can get your clown nose to blink when the car is locked and you can have your headlights and side lights flash upon "arming" and "disarming." You don't get the cool siren beeps, though. Just ask your dealer to program it. All cars up to at least MY04 have this capability. Q: Where can I find a DIY? A: Here are three. The top two are particularly useful, as they include pictures (one with a cleavage shot, too). http://www.my330i.com/mod8.php http://www.bmw330ci.com/DIY_Alarm.htm http://www.circlebmw.com/service/access/01219416538.htm Q: I know nothing about cars. I don't know how to fill my own fuel. Can I still install the alarm myself? A: Yes, it's actually pretty simple. The most difficult part is installing the siren, and the only hard part about that is just wiggling all the different cowlings out without destroying anything. All you need for the install is the alarm kit itself, a #30 Torx driver (available from Home Depot for up to $20 for a set of Torx drivers), and a 6mm nut driver (I actually had to use an 11mm driver to fit over the 6mm nuts). Q: Any tips on the actual installation? A: Interior motion sensor is really, really simple. Tilt sensor is a tiny bit more difficult. The only hard part is removing the trunk liner, and to do that you must make sure to take the plastic tray out first. You can do this by lifting the trunk mat to get to the two screws holding it in place. Finally, for the siren, make sure you take all the screws out. The DIYs claim that a number of the screws and springs are "captive," whereas only the first three springs and the final two screws are. Make sure you take all the rest out fully before attempting to remove the cowlings, or you will lose them. Q: Is it possible to install a shock sensor? A: Yes, see http://members.roadfly.com/black_man...k%20Sensor.pdf for one possible solution. Q: What is the extra fuse for? A: It's a spare for the fuse box in case you fry something while installing the alarm. Q: Now that I've installed the alarm, is it active? A: No, you should bring it into a dealer to have the sensors activated. Even if your siren sounds upon arming/disarming, the sensors cannot be active yet since they must be installed first. Q: How can I test to see if the alarm works? A: Arm the alarm and wait for about 30 seconds to a minute. Jack up the car (tilt sensor) or sit in the car with the doors locked and move around (interior motion sensor). Q: Anything I should be aware of when I bring my car in to get the alarm activated? A: Some dealers will do it for free, but most will charge anywhere between $50-$100. Also, make sure certain features are not disabled when they do the alarm programming. Many people had their "automatic door locking after driving" feature disabled. Q: Any other extra alarm programming options you'd advise? A: Those in NY & NJ should be aware of the epidemic lock popping that has been going on. Basically what happens is the thief will smash in your lock cylinder, which then deactivates the alarm. If you ask the dealer to change your alarm setting from "arm/disarm by means of locks and remote control" (the default setting) to "arm/disarm by means of remote control." This way, the alarm will sound if the door is not opened with the unlock button on the remote. You can also purchase a body colored keyhole cover from www.bimmian.com to replace the keyhole. Q: Is there a form that lists the different programming options? A: Glad you asked. Yes.
2004 BMW 330i • 6MT • Orient Blue Metallic • Sand Leather • Black Cube Trim • ZHP • ZCW Last edited by swchang; 11-20-2004 at 09:26 PM. Reason: update |
How about something on the DEI shock sensor?
http://members.roadfly.com/black_man...k%20Sensor.pdf I'm installing it this weekend, will let you know how it goes. Other items: On the install, pay attention to the DIY, most of the machine screws are captive, so just loosen until you hear them click. The 1/4 turn fastener on the firewall ISN'T captive, loosen it and take it out so you don't lose it. Putting it all back together takes some jiggling, if you wet or lubricate the weather stripping with gummifledge, it will slide together easier. |
I've read the DIYs before, but how hard is it really? I'm completely lacking car mechanic skills except for real basic stuff like changing a wheel, checking typical fluids and air, replacing battery. I know how to use your two common kinds of screwdrivers. I have a minor in EE, but forgot most of the basic laws. Is there hope? What's a torx driver and how much does one cost? |
Clown Nose Blink?
You indicate you can have the clown nose blink without installing the alarm...how?
Torx drivers are for screws/bolts with star-shaped heads, they can be had cheap at your local hardware store if you're not looking for the highest quality tools for everyday use.
'01 330ci |
I am trying to balance my options of getting it installed at a dealer or do it myself. The dealer (or stealer, as someone calls them) wants to charge $460 for alarm + installation, and this is the best price I found in San Diego county. So if I manage to install it myself, it will be $225 and change for shipping from Circle + the cost of tools + the cost of getting it activated at a dealer and thats where these So Cal stealers may even charge $100+ for activation.
So in reality I am saving +/- $100 by doing it myself. May not be a great deal considering the time and effort and the error factor by me. I always think I will drop some nut in the middle of the engine and wont be able to pick it up...
2010 528i - Auto - Space Gray - Nat Brown - NAV - HUD - HD Radio - Xenon - Rear/Side Shades - PDC - ipod/usb - ED 10/19/2009 Previously: 2004 325i JetBlk/Blk, SP, Step, NAV, PDC, Moon - ED 12/05/2003 |
I didn't think I could do this DIY, having never worked on my own car, but I managed to pull it off. As swchang notes, the hardest part is removing or replacing some of the parts without mangling them. You'll feel like the parts that cover the siren area just weren't meant to be removed, but they'll come out with some patient tugging.
-Peter "Never attribute to malice that which can be adequately explained by stupidity." Mystic Blue 330i, SP, PP, Nav, Heated Seats, Step -- ED July 10, 2003 |
Just have the dealer put an OEM alarm on, you'll be fine.
You dont want to carry around a big old key-Fob anyways. |
The nice thing about floss is it's thin enough so it won't interfere with threading the nut. I agree the parts around the siren require some coaxing to remove, but gentle wiggling will do it. When replacing the parts, make sure the rubber gaskets are seated correctly.
Dan '03 325i OrBlu, MT, PP, SP '01 X5 3.0 AlpWhite, AT, SP, CP '89 325i Bronz, AT(retired) '02 325i StlGrey, AT, PP, SP '13 328i AlpWhite, AT8, Xenon, HK |
Talking about motion sensor....
talking about motion sensor .... i've heard that it's very sensitive
and so, i opened all the windows, armed the car ... to test how effective it is... ... but for some reasons... i was able to move my hands freely, took a bottle of water in and out, etc, the alarm still didn't go off. i then tired the passenger seat in the back, and the alarm got a bit more sensitive and finally goes off... so very strange... if I am a auto thief, i'd be a happy one for sure
For those of you with convertibles, you'll want to check out this thread. US spec cab alarms do not have motion sensors. However, the car is designed and wired for two SDR units, one installed under the center console trim just behind the shift lever, the second in a trim extension added on to the back of the center console trim on the driveshaft hump.
There are a variety of ways to get your hands on the SDR units and the rear trimpiece to add motion sensing to US cabrio alarms. IF you don't have the US kit already, you can order the entire Euro alarm complete with motion sensors. Part numbers are in the thread. Getting to know your parts guy at your local BMW dealer usually does the trick in ordering the parts. Have fun! |
I got mine to blink without alarm. |
Great FAQ. You forgot one question, the one that seems to come up even before the others. Q: Does my car come with an alarm? A: The car's central computer is the alarm, what are missing in all E46 cars delivered from the factory are all the sensors to trigger the alarm. An OEM kit is available from the dealership that includes the motion detector, tilt sensor and siren. After this kit is installed, activation by the dealership will be required. |
Leon, my MY04 was able to be programmed for clown nose only blink. I added the alarm later, though.
2004 BMW 330i • 6MT • Orient Blue Metallic • Sand Leather • Black Cube Trim • ZHP • ZCW |
Good post
You might want to add this- Those in NY & NJ should be aware of the epidemic lock popping that has been going on. You should have your dealer program the computer to sound the alarm if the door is not opened with the unlock button on the remote. Had my lock pulled twice until I put in the Euro passengers door handle cover.
Forgive my ignorance, but where is this said "clown" nose?
Are we supposed to get a clown nose with our cars ![]() Quote:
http://www.bimmerfreak.com/e46products_exterior.htm I think the "blank" he's referring to is the metal part which has the plastic cover snapped (with clips) on to it. That's the piece that replaces the lock cylinder and you screw it securely with the double treaded screw. |
#25
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
