Old 03-13-2011, 01:26 PM
jokuhl jokuhl is offline
Mein Auto: 2000 Z3
2000 Z3 interior door glue letting go on arm rest
I took my beloved Z in for repairs to the lower passenger side panel due to a rock thrown by a car in the next lane. How they could have missed a rock the size of a large grapefruit is troubling but the damage it did to that lower panel was incredible. I took my car in for restoration pursuant to the insurance policy. The interior of my car is excellent, in addition, I alone drive my car and the passenger seat is ALWAYS empty.
I drop off the car for repair.
Fast forward 3 days when I pick up the car. I see the repair of the panel is hideous and rough. The repairer decided to put on a rock guard surface to protect it since they said the original rock coating that came on the car had worn off. Well, I did not have to be restrained as I explained my car came to me with 6 miles on it and I alone maintain it and never in all my years of washing and caring for my car have I noticed stone guard on that lower panel. In addition, they did this ONLY ON THE PASSENGER SIDE! I checked the driver side and it was smooth. Even if BMW had put stone guard on the cars it would not be as unsighlty as the rough ragged edges as were on one side of my car at that time.
I contacted my insurer and said their repair went beyone what they were supposed to do and that they had disfiguired one side! The next morning I got into my car and looked at the passenger door! When the scream died down, I saw the passenger arm rest, that is never used, with its material pulled away and the area located just below that air bag exposed, with foam visible. I KNOW my car was not in this condition when I took it in.
The repair shop says they did not do it, that it is the glue that has let go and the material retracted. Can this happen overnight?
I am left to fix this. Yesterday I took it to an upholstry shop for an estimate. I was told it cannot be fixed, the only repair is to replace the interior door panel. He said he has seen this on others BMW and it was a defect. Can anyone shed any light on the defect part? I would replace both interiors so it would match and the cost for panels ($400 each) and install $125 each side seems really expensive to me.
I would like to take care of this before leaving on a significant drive in 2 weeks to meet up with my Z friends. Anyone who knows me, knows I love and am passionate about my car and keep it in excellent condition.
I trust and appreciate any help you experts out there can offer on this problem.
JoAnna and ROADCAR in San Diego!
Old 03-13-2011, 08:40 PM
BlackjackM BlackjackM is offline
Mein Auto: '01 Z3.0 R; '10 MB C300
Sorry to hear about that. Post up some pics so we can make suggestions.
Old 03-13-2011, 09:23 PM
Mein Auto: 2000 Z3
Name:	Z3 areas concern 2 24 11 005.jpg
Here is picture of passenger door interior where glue has let go.
Old 03-14-2011, 07:01 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
The pic you posted seems like it is something that should have happened slowly over time. I am not sure if it would do it overnight, maybe you were more sensitive to what could be wrong with the car after the experience you had and not noticed it?
New panels from BMW cost $400? Last time I checked they were over $1100 each. Install is not terribly tricky and a first timer could probably do it in 1 hour. The bulk of that being in the first panel.
I have not seen this defect before so I am not sure how common it is. Upholsterer should be able to remove the material and install new material without too much trouble. I am not sure what they would charge though. Plus you would have to do both sides unless they can get a perfect match on the material.
Old 03-14-2011, 08:46 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
In the world of sagging 318TI headliners, I've heard of people using steam to reactivate the glue. Followed by moderate pressure on the headliner.
If you are going to replace the panel anyway, perhaps, somehow heating the arm rest would reactivate the glue. But I would only try this if your only alternative is replacing the panel. (mentioned "replacing" twice for emphasis - don't screw up a part you are planning on fixing)
Old 03-18-2011, 11:00 AM
formerly updmst
Last night I saw this defect on a friend's 1999 Z3 M roadster - glue letting loose on the passenger's arm rest. Not very noticeable, except if you were looking for the problem. He was totally unaware of the problem.
Old 03-29-2011, 10:11 AM
tequila mike tequila mike is offline
Mein Auto: 1999 MZ3
something is loose
I dont see how this could happen during normal service of any kind.
Take it to a different upholstery shop for an opinion.
The way it works is
the fabric that has let go is applied as a unit to the door panel consisting of fabric than poly padding glued to a ABS backing.
the ABS backing has plastic pins molded on the back side about 6 of them about 1/2 inch long.
the pins are guided through the fiber door panel and melted (mushromed) on the back side as an attachement method.This make its near impossible to remove.
I think it could be done with a minimal amount of effort.
The pins are a large enough diameter to be center drilled and small screws and washers used to reattach it.
Dont know that you have much to lose.
Grind off the pins remove the panel hot glue the fabric and reattach using screws.
Might be a bit more difficult than that.
I can send you pics of the back side of my door panel.
M
Old 06-21-2011, 11:27 AM
bion bion is offline
Mein Auto: 2000 m roadster
door panel
for those that might read this. It is possible to happen overnight. The reason is the collision repair shop in an effort to run many cars through their paint booth will crank up the temp way above what the car would ever receive in normal use to bake the paint dry. . this has been know to let headliners drop, put divets in leather seats if something is sitting on them and loosen up glue on older panels.
I worked in florida andwe checked the temp on a black car sitting in the sun on a 100 degree day. the hood in the paint booth got 18 degrees hotter.
Old 10-28-2014, 08:11 AM
cargirl417 cargirl417 is offline
Cargirl
Mein Auto: Vette, Lotus super seven
Just replaced my arm rest yesterday
when the car was given to me, the door's arm rest was hanging. My new arm rest just came in. Yesterday I took the panel off and disconnected the speakers and the actuator for the mirror adjustments. After putting it all back together, I found a small half inch long tit/protrusion sticking out the back of the arm rest with no part to anchor it. I'm a little pissed. It should have been threaded rod so I could anchor it with a lock nut. That would have given the arm rest two places to support and stabilize it. I'm guessing I will drill it out today and rig up something realistic and substantial. Btw, in my research for this part, I found almost a two hundred dollar difference in pricing. Forget using search terms to find what u are looking for. Find the part number and go from there.
Sorry we don't live near each other. I would be happy to replace it for u for a cold one.
Old 10-28-2014, 02:15 PM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by cargirl417 View Post
when the car was given to me, the door's arm rest was hanging. My new arm rest just came in. Yesterday I took the panel off and disconnected the speakers and the actuator for the mirror adjustments. After putting it all back together, I found a small half inch long tit/protrusion sticking out the back of the arm rest with no part to anchor it. I'm a little pissed. It should have been threaded rod so I could anchor it with a lock nut...
You are supposed to heat the tip of a big screwdriver, and apply it to the protruding plastic mounting post, to melt it and flare it out against the back of the door panel.
Here is a new part with the intact black plastic post that you refer to:
http://www.ecstuning.com/BMW-Z3-1.9-...8735/ES102859/
On your old arm rest, the black plastic post broke off like this:
http://i49.photobucket.com/albums/f2...psaf8fb0b8.jpg
Old 10-28-2014, 08:00 PM
Cargirl
Problem solved
Thank u for the good advice. I hadn't thought of that. I settled on an assorted size pkg of internal locking tooth retainers from oreilleys. The tit was about 6 mm so I used a deep throat socket over the retainer and Forced it down snugly onto the tit with a rubber mallet. Worked like a charm with a single firm whack. If I ever need to remove it, God forbid, I would break it loose carefully with the little electric grinder. Used the same grinder to take some of the metal sheathing from the cable I installed to open hood as it was a quarter inch too long.
Old 10-29-2014, 08:06 AM
vintage42's Avatar
BMW CCA 1405
... I settled on an assorted size pkg of internal locking tooth retainers from oreilleys. The tit was about 6 mm so I used a deep throat socket over the retainer and Forced it down snugly onto the tit with a rubber mallet. Worked like a charm with a single firm whack. If I ever need to remove it, God forbid, I would break it loose carefully with the little electric grinder. Used the same grinder to take some of the metal sheathing from the cable I installed to open...
As I remember the screws at front and rear of the arm rest go into the door, clamping the door panel between the arm rest and the steel of the door. The plastic post just holds the arm rest to the door panel. When the arm rest breaks off from its front screw, the plastic post into the door panel takes all the pulling when you close the door, and it eventually breaks off.
That locking tooth retainer was logical and resourceful. And allows the arm rest to be removed from the panel without destroying the plastic post.
For all I know, your method might be the right one.
Old 10-29-2014, 01:51 PM
wrench13's Avatar
wrench13 wrench13 is offline
Mein Auto: Y2K 2.3 blk; 01 3.0 Cp
Tinnerman Speednut. Great idea there Cargirl.
Y2K Roadstar, w/60K ( motorcycle)
Y2K Z3, 2.3, w/66K, now 92K in 2-1/2 years
2001 Z3 Coupe, 3.0 w/55K - new for me - WHooHoo
Astro 1990 w/290K
Suck, Bang, Blow, that's what it's all about.
