Looking for Serpentine Belt - Other than continental - Bimmerfest - BMW Forums
Old 10-17-2011, 04:56 PM
ilian007 ilian007 is offline
Mein Auto: BMW 530i 2002
Hello,
Last 40k miles I've had bad expirience with the continental serpentine belts....
I've had 2 replaced for 40k miles and less than 3 years. (they looked wearn off like 80k ones)
Is there any other good brand I can try ?
Thank you
Old 10-17-2011, 05:29 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Get Dayco Poly belts, I think AutoZone sells them.
http://www.daycoproducts.com/daycowe...FUKo4AodgwsjtQ
Old 10-17-2011, 05:33 PM
Why not look in the thread that attempts to list the most recommended parts and brand names for the belt drive overhaul?
- Recommended parts kits for overhauling cooling, drive belts, CCV/ICV, VANOS, OFH, PSP
For example ...
We're adding "Gatorback" belts to the recommended alternator belt brands based on this post today from [energizedmortal].
"for alternator drive belt add "gatorback belt replacement" there are reports on the forum that problem cars that upgraded to hydraulic tensioners still had alternator drive belt whine that was only cured after gatorback belt replacement"
Old 10-17-2011, 08:00 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
+1 for Gatorback.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 10-17-2011, 10:06 PM
nyclad's Avatar
nyclad nyclad is offline
Mein Auto: 2002 530i Sport
Just my luck that this thread didn't exist last week. I ordered Conti replacement belts for the pulley and AC, and they arrived today. My belts were starting to squeal and tick quite a bit. It rapidly went from a slight tick a few weeks ago to sounding like a diesel engine now. I installed my current pair of Continental around 60k miles ago. Hmm...
Hello,
Thank you
Old 10-18-2011, 06:47 AM
cn90 cn90 is offline
I have no issues with Conti belt.
Just out of my curiosity, where are Conti belts made these days?
Old 10-18-2011, 07:19 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
Conti belts are about the best you can buy, If someone is going through them fast its due to another issue, Either pullies that have issues or if the engine is being cleaned all the time with harsh chemicals then that could eat at the rubber.
Old 10-18-2011, 10:05 AM
Mines said : Romania on them .... I guess that's why the quality went down.
However, take in consideration that I live in California and the temps are very high during the day 95+F (if that matters).
I hope you dont have same expirience as I do. Just make sure you check it every 5-10k miles (it is easy to see by visual inspection) Look for cracks on the belt.
Old 10-18-2011, 10:08 AM
menhir's Avatar
menhir menhir is offline
Float On
Mein Auto: Not a Bimmer
Unclear on the relationship. However, I've never used any product made in Romania to the best of my knowledge.
"The wise speak of only what they know."
Old 10-18-2011, 10:11 AM
Neither problems with my tensioner, pullies neither cleaned the engine at all. Pullies and tensioner were replaced each time I replaced the belts. Since the labor is too expensive i replace all the parts when do it.
Both times in different INDY
1st indy they bought the parts.
2nd indy I bought the parts from eeuroparts.com and gave them to the shop.
I guess I just have bad luck with defective belts.
Those are the parts I've got installed 1.5 years ago abo 15-20kmiles
Water pump (HEPU made in germany): $62.90 -----> http://www.eeuroparts.com/Main/PartD...id=11517527910
Serpentine Belt for BMW vehicles (Continental): $16.99 ----> http://www.eeuroparts.com/Main/PartD...id=11281706545
Serpentine Belt Tensioner (Mechanical): $46.15 ---> http://www.eeuroparts.com/Main/PartD...id=11281427252
A/C Belt for BMW vehicles(Continental): $10.46 ---> http://www.eeuroparts.com/Main/PartD...id=11281437450
A/C Belt Tensioner for BMW vehicles (INA) : $47.14 --> http://www.eeuroparts.com/Main/PartD...id=11281433571
Thermostat (Wahler): $59.90 ---> http://www.eeuroparts.com/Main/PartD...id=11537509227
Old 10-18-2011, 10:33 AM
For example ...
bluebee do you have in hand the gatorback part number for my E39 2002 530i ?
Thanks a lot !
Old 10-18-2011, 10:35 AM
Actually if you look at any serpentine belt, it has 2 portions:
- the ribs (for example 6 ribs) that keep the belt in the correct grooves.
- the flat portion, or the belt itself.
I have observed this for years: the ribs crack at 20-30K miles (because the ribs have very small amount of rubber), but the belt itself remains good for years.
Old 10-18-2011, 11:00 AM
Yep! It seems that this is my case.
However, I am doing the oil filter housing gasket and since it is no extra labor i think to replace it ....
Old 10-18-2011, 11:03 AM
Yeah, the belt is cheap, replace it. Keep the old belt in the trunk just in case you do long trip.
An old belt is better than no belt in the middle of nowhere!
FYI, minor cracks of the belt are normal after 20-30K.
The major crack: yes replace ASAP!
This pic shows you the difference between minor (rib crack) vs major (belt itself) crack:
Old 10-18-2011, 11:35 AM
Gates also makes good belts.
Old 10-18-2011, 11:41 AM
Hey Jim,
I have been using Conti for years in my BMWs, Volvos etc. with no problems.
But who knows if Conti changes their mfg facility lately.
Do you think Gates is better than Conti as we speak.....in Oct 2011?
Old 10-18-2011, 03:21 PM
Bought the Goodyear, gatorback from Amazon $13 + $3.99 next day shipping.
Hopefully it will do the job
Old 10-18-2011, 03:34 PM
nyclad's Avatar
Wierd, I also have a 2002 530i, so I bought the same Conti belts as you.
These are the belts that arrived yesterday. Mine aren't Romanian, but made in Spain and UK.
Old 10-18-2011, 03:53 PM
I will double check the label on it if still reads when I pull it out to make sure I am not in mistake.
I guess after cn90 explained to me it is normal to have little cracks on it. It is all good ... I falsly expected it to look better for 40-60k miles
I will try this time the GoodYear and will see ...
I just checked if there is Contitech made in Romania ... and there is ......
http://www.prestonekorea.com/upload/...87574319_0.jpg
I guess mine was from the worse factory ...
Old 10-22-2011, 12:49 PM
nyclad's Avatar
Just to add, I replaced my belts due to the loud ticking noise. The serpentine belt only had minor wear cracks. It was the AC belt that was messed up and making all sorts of noise.
Old 12-19-2015, 11:43 PM
bitzer bitzer is offline
Mein Auto: X5 E53 3.0i
Just did mine, prior owner may have had them done 50k kms/30k miles ago about 5 years ago. Looking at them now it's off there are lots and lots of full dept parallel cracking of the ribs and they were very chalky. Saw else where they are good for 100k miles/160k kms. Our X5 has just done 150k Kms and 9 years old so just to be sure this summer in Australia I've changed both belts. Used Gates (6PK1540 for the big one) and it seems to have reduced the engine noise quiet a bit. It's fiddly to get it back on used a T55 Torx and an allen key. Pulley felt OK so put off replacing it until after Xmas as I did not want any thing to go wrong as I was doing it without taking off the friction drive fan. Take photos or draw a picture before removing the old one.
After the experience of doing it I think one should do it every 4 years or 30K miles / 50K kms regardless of how hard one pushes the engine. Ours has had a leisurely life with lots of country travel as constant speed at the legal limit 100 or 110kph (60 or 70 mph).
I am in the 65+ age group so anyone can do it if I can.
Old 12-20-2015, 05:51 AM
juststeve's Avatar
juststeve juststeve is offline
plays well with others...
Mein Auto: 5 Series
"Quality" belt manufacturers moved from neoprene to EPDM 15+ years ago.
So it becomes less and less likely one would find the visual cracking or separation associated with older belts.
http://www.gates.com/products/automo...-vs-epdm-belts
Old 12-20-2015, 07:56 AM
Brandon002's Avatar
Brandon002 Brandon002 is offline
Mein Auto: 2002 530I Sport
Gates makes the best belts on the market. Might want to try there.
Although, I've had awesome luck with Conti belts. Are you sure you don't have another issue that's causing premature belt wear? Maybe a chewed up pulley? Bad bearing somewhere causing drag on the belt? A lot of things can cause the belt to wear fast. I'd give everything a very thourough inspection before assuming it's the belt.
Old 12-20-2015, 10:02 PM
Another good option (instead of Conti) is the Japanese brand Mitsuboshi, this is used in Honda, Toyota and it is a very good brand.
Autohausaz.com sells this Mitsuboshi brand:
* 5PK905M ---> $8.17
* 6PK1560M ---> $12.94
