E39 Cabin Filter Replacement DIY - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 03-14-2011, 07:26 AM
gunksny gunksny is offline
Mein Auto: 2003 530i
See attached PDF and photos.
2003 BMW 530i (E39) Cabin Filter DIY
Difficulty : Very Easy
Time Required : 5 minutes.
Part : Mann-Filter CUK 2736-2 Cabin Filter with Activated Charcoal for BMW (set of 2)
(available at Amazon Spring 2011 for $18.69 eligible for free shipping)
1) To access the cabin filter, lift the wire latch located at the front of each chamber and remove cover.
2) Remove the old filter by lifting up and out. Note that air flows into the chamber underneath the filter and flows up through the filter and out the top side so the filter should be installed with the arrows pointing UP.
3)Vacuum chamber and wipe down with wet rag if necessary. Insert new filter with air flow arrows pointing UP
4) Replace cover by inserting rear tabs first, closing cover and snapping wire latch back in place over the cover. Repeat for other side.
ID:	270254   Click image for larger version
ID:	270255   Click image for larger version
Name:	cabin filter chamber.jpg
ID:	270256   Click image for larger version
Name:	cabin filter.jpg
ID:	270257   Click image for larger version
Old 03-14-2011, 09:03 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Nice. Very nice. I like the idea of the attached PDF.
I just now added this to the bestlinks so others can find it easier:
- How to DIY replace the activated charcoal cabin air filter (1) (2) & what cabin filter to buy (1) (2) & cn90's inexpensive cabin filter retrofit (1) (2) (3) & cabin air filter implications for stinky air conditioning (1) (2)
Old 07-03-2011, 12:52 PM
bluebee's Avatar
To the OP: Your pictures came in handy today for this thread:
- E39 (1997 - 2003) > Mann Cabin Filter Air Flow
Thanks for adding to the tribal knowledge!
Old 09-18-2014, 11:04 AM
Deathstroke Deathstroke is offline
Mein Auto: 2003 525i E39
Question:.. what are the Cabin filters for?
What is their purpose. This is the first time ive owned a car with 3 air filters
Old 09-18-2014, 12:06 PM
Cabover1000's Avatar
Cabover1000 Cabover1000 is offline
One wheel roaster
Mein Auto: 1998 bmw 540i
More than likely your other car had one. But bmw made it easy for us to find them. On most cars there behind the glove box.
Sent from my SPH-M840 using BimmerApp mobile app
current
1993 740il chipped, 6 speed swap!
1997 Range Rover HSE 4.6
1986 F-250 diesel 6.9
1989 535i
2000 Range Rover HSE
1994 740i
1947 kb-5 international
parting out/ scrapped
1998 540i sport
sold
1999 528i sport premium
1997 540i premium
