E30 (1982 - 1993)
Old 03-14-2011, 08:58 PM
Ethandude1 Ethandude1 is offline
Ethan325i
Mein Auto: 1989 325i Convertible
Question Fuel pump relay location??
I haven't found the anything that says where the fuel pump relay is and I have NO IDEA where to find it because I'm pretty sure its not in the fuse box under the hood. i need help pleez
Old 03-14-2011, 09:09 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
simple search will tell you where it is. you have a plastic box under your hood with 3 relays in it. fuel pump relay is in there. should be right next to your afm.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 03-14-2011, 09:52 PM
Ethan325i
ah, im assuming the two identical ones are for the ABS and the odd man out is the pump relay?
Old 03-14-2011, 09:56 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
no... one is the main relay, one is fuel pump, one is horn
the two 4 prong ones are horn and fuel pump, the 5 prong one is... the main relay..
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 03-14-2011, 10:08 PM
Ethan325i
I just tried that out, I took all three relays out and the horn still worked
Old 03-14-2011, 10:56 PM
Ethan325i
Nevermind, I finally found it out, according to autozone.com its the middle.
E30 3 Series
M20 ENGINE
The fuel pump relay is mounted on a bracket on the left inner fender in front of the shock tower. There is a grouping of 3 relays. The forward relay is the main DME relay. The middle relay is the fuel pump relay. The rear most relay is the oxygen sensor heater relay.
(autozone.com)
Old 03-15-2011, 08:04 AM
mysticblue_zhp mysticblue_zhp is offline
Mein Auto: 04 330i zhp, Spece30
What are the characteristics of a bad fuel pump relay or other relays. My car is running lean at higher rpm's and I have replaced almost everything besides these relays. Can a lean issue be caused by one or more relays?
Old 03-17-2011, 12:19 AM
squenchy squenchy is offline
Mein Auto: 325i bmw
fuel pressure
have you checked your fuel pressure and fuel pressure regulator/damper/fuel filter ect. this would be more suspect that the relay.
Old 03-21-2011, 04:41 PM
Mark_325i's Avatar
Mark_325i Mark_325i is offline
Mein Auto: '03 325i, '88 325iC
The three relays are about $11 each at Pelican. $80 each at the dealership! I replaced all three.
Mark
88 325iC
03 325i
Old 04-25-2012, 04:12 PM
lana352 lana352 is offline
Mein Auto: BMW 2002 325I
any one kno where fuel pump relay is located on a 325i 2002 bmw
fuel pump, fuel pump relay
