Old 03-15-2011, 03:50 PM
Redion Redion is offline
Mein Auto: 2003 525i
Castrol vs. Bmw
can someone please explain to my why on the owner's manual and on the oil cap it says that bmw recommends castrol but when you go to the dealer to buy oil they give you bmw high performance. i never seemed to understand it
Old 03-15-2011, 04:43 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Don't go to the stealer for that stuff, any BMW LL-01 approved oil (such as Redline or Mobil 1 0w40) will meet or exceed BMW's spec.
Castrol has a contract with BMW for oil. All BMW fluids and most parts are not made by BMW. Oil is no exception. Castrol makes the oil for BMW at least in the US. There is no benefit to using Castrol or BMW's oil, provided the oil you are comparing to is LL01 approved. The LL01 designation is primarily to ensure the oil will perform reasonably well on BMW's nutty oil change schedules. It is highly recommended that you ignore BMW's oil change schedule and at least double up the frequency of change
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 03-15-2011, 04:48 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
It has been discussed before. Did you search for it?
There was a thread, with pictures of the cap (joking which way to put the cap on, with the Castrol facing this way or that).
Screenshots and web sites were given, IIRC, where it was simply a Marketing ploy. Nothing more. Nothing less.
And we all know how much we love M A R K E T I N G!
In essence, the oil cap words are meaningless.
However, in contrast to what you intimate, if you look at ANY of the zillions of 'what oil' threads, you'll see they all point to the list of "BMW Approved Oils", and, IIRC, on that list, are quite a few Castrol formulations.
I'll see if I can dig that up on the next list (but it does look like I'm doing the work for you who should have done it first and said that you did).
Old 03-15-2011, 05:59 PM
bluebee's Avatar
Here is the canonical thread for the BMW Approved List (look for Castrol):
- BMW approved oils
And see this quote about Castrol:
I never choose motor oil by brand (except as it relates to the above criteria). That's why it's so hilarious to see "USE CASTROL" embossed on all our oil-filler caps! Even Castrol makes oil that doesn't meet (all) BMW specifications!
- Engine oil (E39 1999 & later): 15W40 LL-01 mineral oil BMW PN: 07.51.0.017.868 (amazingly, only one SAE weight is specified! Don't be confused because Bentley page 020-11 lists only SAE 15W40 while page 020-9 confusingly lists only SAE 5W30 & SAE 15W40 but page 020-11 appears to be the specific listing to follow). Various dogmatic camps differ on 'opinions' (1) but there is only one BMW-approved list (1). [Volume: I6=6.9 quarts, V8=7.9 quarts]. Replacement Interval: The instrument cluster Service Interval Indicator (SII) will determine when necessary by lighting the yellow light and indicating "OIL SERVICE". On average, most seem to change oil & filter (Mann, Hengst, or Mahle only!) & 36mm 6-point socket oil-filter cap o-ring (91x4mm) & copper crush washer roughly thrice a year at about 4,500 miles; most replace the smaller lower oil-filter-post o-rings every five years or so (7x2.5mm). Keep a spare 17 mm drain bolt handy on the I6 as it's hollow and can break from over tightening (M12x1.5x18mm). Torque filter cap to 18 ft-lb, drain bolt to 21 ft-lb. Note: Mixing oil types (mineral vs synthetic) is permissible; but bear in mind "synthetic" is an advertising term and quite a few oils labeled as such are not PAOs or diesters (1). Best to use either the oil-pan gravity-drain method or the MityVac vacuum-extraction method (don't use the Motive vacuum extractor). Most replace the oil filter & oil-filter-cap o-ring on every oil change and the lower small o-rings on every other change. Keep a spare oil drain plug handy, especially in the I6 as the bolt is hollow and prone to breaking when over torqued.
- Engine oil (gas, E39 1997 & 1998): Synthetic 5W-30 LL-01 (aka long-life 2001) BMW PN: 07.51.0.017.866 (amazingly, only one SAE weight is specified! This is confusing because Bentley page 020-11 lists only SAE 5W30 while page 020-9 confusingly lists only SAE 5W30 & SAE 15W40 but the 020-11 appears to be the specific listing). Replacement Interval: The instrument cluster Service Interval Indicator (SII) will determine when necessary. Note: Mixing oil types (mineral vs synthetic) is permissible. On average, most seem to change oil & filter roughly thrice a year at about 4,500 miles.
Old 03-15-2011, 06:49 PM
thanks for the reply....i did search but i guess not enough and as thoroughly as i should have.....very informative and btw i always put my cap the way its in the pic thanks
Old 03-15-2011, 06:52 PM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
Here in Australia, I went to my local auto store and in their handbook castrol was not recommended as it did not have the ll01 that BMW estates must be used. I ended up buy liqui moly which is recommended. I had the choice of that or mobil 1 which was freaking expensive as!
Sent from my iPhone using BimmerApp
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 03-15-2011, 07:36 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport, Scuderia
Because the BMW high performance synthetic is manufactured by Castrol.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 03-16-2011, 10:25 AM
IndiansFan's Avatar
IndiansFan IndiansFan is offline
Mein Auto: '99 528iA
For me, it's more ecconomical to go to the dealer. I have three E39's, and one E34. My dealer charges $6.50/qt. Advance Auto charges $8.00/qt. for Mobil1 0W40. That saves me about $40.00 every time I change to oil for the fleet.
Either write something worth reading or do something worth writing.
Benjamin Franklin
2004 X3 2.5 TITANIUM SILVER/Grey - Sport/Premium Package
2001 530iA STEEL BLUE/Sand - Sport/Premium/Cold Package
1999 528iA JET BLACK/Black - Sport/Premium/Heated Seats
1982 Fiat 2000 Spider - BLUE METALLIC/Blue
1999 528iT CASHMERE BEIGE/Sand - Sport/Premium Package - 5 speed SOLD
1989 535i SALMON SILVER/Black SOLD
Old 03-16-2011, 10:38 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
I actually use the German Castrol 0 x 30 (LL01 approved). No issues.
Old 03-16-2011, 12:20 PM
bluebee's Avatar
So that every question already has an answer (over time), I added the following to the bestlinks just now:
- Why does BMW say "Use Castrol" on the motor oil filler cap (1) (2)
In that reference thread, you'll see this interesting marketing blurb:
Old 03-16-2011, 12:39 PM
bluebee's Avatar
I really don't know why I do this, it's a laziness disease I think (I hate looking stuff up twice), so I just updated the links after re-reading those threads:
- Why does BMW mold "Use Castrol" on the oil filler cap (1) (2) (3) (4) (5) (6) & what is the definitive list of BMW-approved motor oils (1)
BMWCurrentListing_of_SyntheticOils.pdf
Notice the marketing horseradish in the top and bottom of this link (below):
Name:	Castrol Motor Oil and Lubricants - BMW.jpg
File Type: pdf Castrol Motor Oil and Lubricants - BMW.pdf (97.0 KB, 647 views)
Old 03-25-2011, 12:35 PM
rmaher rmaher is offline
Mein Auto: 330CI
oil sale
FWIW - Advanced Auto is selling 5 qts of Mobil1 and any Mobil1 filter for $32.99 through the end of the month (March 2011).
Old 03-25-2011, 12:45 PM
ECSTuning's Avatar
Instructor of the Stig™
We take the guess work out for you!
Click HERE for more information.
Please let us know if you have any questions! Feel free to shoot me a PM or email.
Best,
Joe
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
