Old 03-10-2011, 10:17 AM
MJim MJim is offline
Mein Auto: X5 on order
X5 M Sport chipping issue: Is it a 20in wheel thing???
I would really appreciate you feedback on this, as I've been trying to figure why some M Sports seem to suffer bad stone chipping whereas others seem to have no such problem at all.
I got talking to a guy at a dinner last night who turned out has an X5 35d M sport, with the 19in wheels. I asked, and apparently no stone chipping problem (he later wheel span off in his 997 Carrera S so don't think driving style would explain it!). I have received a comment elsewhere from someone with a black 30d M Sport that he hasn't had a problem with stone chipping, who as it happens also has 19in wheels. I have also done a quick look at some forum members who have said they suffer from bad chipping round the rear wheel arches and this time the 20in wheels seem to be a common thread.
Could be coincidence, but perhaps the added width is enough to send stones down the side of the car rather than underneath?
Is this consistent with members' experience - i.e. do all M Sports with 20 in wheels suffer chipping and 19 in wheels get away with limited chipping?? Really appreciate your feedback!
Many thanks in advance for any comments!
Old 03-10-2011, 11:49 AM
Kief's Avatar
Kief Kief is offline
Mein Auto: 2017 F80 ///M3 ZCP
Have you checked out this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=431750
2017--F80 ///M3 ZCP
2016--F-Type Coupe R*
2015--F15 X535i
2015--F82 ///M4 [ED 6/26/14]*
2015--V60 Polestar (#62:80)*
2012--E92 335is*
2011--E70 X5d*
2011--E89 Z435is*
2009--E89 Z435i*
2008--E92 335i [ED 2/23/08]*
2007--MkV GTI*
2006--R53 Cooper S (JCW) 6MT*
2006--E90 330i*
2005--E83 X3*
2004--E83 X3*
2003--E46 325Ci*
*retired
Old 03-10-2011, 01:54 PM
Kief - many thanks - really appreciated!! I did read that post a while back but couldn't figure why some seemed to be affected and others not - have tagged my query on the end of it! Once again many thanks!
Old 03-10-2011, 07:56 PM
georgejm georgejm is offline
Mein Auto: BMW X5 35d
No expert here but I think the perfect storm for chips are the 20 " wheels and NO running boards to block the road rash from hitting the front panel on the rear wheels, just my two cents.
2012 X5 35d AW/Black Dark Burl
ZAP ZAV ZCW ZPP ZPS ZRC ZTP HUD AD BMW Apps
Spare Tire-Comfort Access-Running Boards-Roof Rails-335 Wheels-Auto High Beams-Smart Phone Int.
Mods : Clear Bra-Radar Hard-wired
So far so good-made on Wednesday
Old 03-11-2011, 04:04 AM
Thanks for your input georgejm! I'd also be really interested to hear from X Sport drivers with 19in wheels - do you get any stone chipping ?? Any feedback will be very much appreciated!!
Old 03-13-2011, 10:10 AM
affinding affinding is offline
Mein Auto: 2011 X5M
I have the same problem I used bmw 19" M winter tires, the area under the both rear passenger door are chipped pretty bad especially the running board paint. i have to put some 3M to cover it. dealer said even put on the mad guard still wont help.
Old 03-13-2011, 11:07 AM
affinding - thank you so much for your reply - really appreciated !! I had hoped that the situation with chipping did not apply to cars with the 19in wheels (as my order has), but guess I was wrong. Just wanted to check before blowing $1000 on getting the 3M fitted, but can see I will need to. Will try and get fitted before I collect. Once again, many thanks.
Old 03-21-2011, 11:57 AM
kbbmw kbbmw is offline
Mein Auto: x5 5.0 m series 2011
I have the same problem on my 2011 black x5 M series . I did have the film installed right after taking delivery of the car and also changed out the 20 inch wheels to the 19 inch for winter driving. Unfortunately, the sand/gravel hits the flared front panel on the rear wheels at such velocity that it actually imbedded into the film (and yes, this is the 3M high end stuff) and it will have to be replaced this spring. I just found out that I cannot put running boards on since it is an M series. Anyone know of any aftermarket running boards that will look good and fit? I am hoping that running boards would solve some of this problem. Thanks!
Old 03-22-2011, 05:24 AM
Marlbro's Avatar
Marlbro Marlbro is offline
UK (ex-Pat)
Mein Auto: 2010 X5 3.0d M pack
Mine now has 27,500 kms, has passed through it's second winter (first with me) and I can't find any stone chips.
I did note while checking that the 3M has slightly lifted on the Left side rear wheel arch to rocker panel area, and has a very small piece that has discoloured.
I might, if bothers me too much get that area re-done.
obviously, 20 inch wheels make this issue worse than 19 inch, but the car looks better on 20 inch.
softer compound tyres will kick up more stones than harder compounds.
and if you go for 21 inch wheels your car wil look even better, but that extra 5mm on the outer side (21s have 285 wide, & 325 wide respectively) will chip up even more.
My main regeret having 20 inch wheels is the hard ride on Run Flats, but when i put my summers back on, I'm going for conventional tyres, not run flats, and they're cheaper so !!!!
2010 X5 30d M Sport pack on 20 inch
In Space Grey, Panoramic roof, auto tailgate,
Privacy Glass, Comfort seats in Black?
Rear view camera
