Old 03-21-2011, 07:44 AM
Bailey228 Bailey228 is offline
Send a message via MSN to Bailey228
Mein Auto: E39 / E46 / E36 / E30x2
Just for everyone's information, I contacted the seller of these "Glass Headlight Covers for E39" on Ebay, and it turns out that they are NOT glass - just standard poly covers.
From Ebay Seller:
"Hello, it is plastic as well. Thanks
- abs24shop"
Just a heads-up for anyone thinking of ordering.
Cheers... Glenn
Originally Posted by Bailey228 View Post
It appears that glass is available in Latvia only, according to an EBay search...
http://cgi.ebay.com/ebaymotors/BMW-E...ht_2106wt_1074
I'd pay 150.00 for glass - but you have to ask yourself "Why only in Latvia?"
Maybe someday I'll take a shot. Better than spending it at the casino.
Cheers... Glenn
"The right to speak freely does not guarantee the right to be taken seriously"
Old 03-21-2011, 12:17 PM
WagonTheDog's Avatar
WagonTheDog WagonTheDog is offline
Mein Auto: 2000 528iAT
DONE, PURCHASE MADE
Pics, critique, and all the other baloney you're probably expecting will be forthcoming
"Experience is a hard teacher because she gives the test first, the lesson afterwards."
Old 03-21-2011, 12:31 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Originally Posted by WagonTheDog View Post
DONE, PURCHASE MADE
I am glad you took my advice.
http://www.bimmerfest.com/forums/sho...6&postcount=13
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 03-22-2011, 11:27 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
Take a look at the price now!!
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 03-22-2011, 11:42 PM
Whorse Whorse is offline
Mein Auto: e30, e39
am i the only one that sees this price? US $658.28
Andreas
Queens NY
BMWCCA# 186796
86 325es (wrecked by careless driver)
87 325 300k (project for life) aka 1BADETA/Christine
89 525i 190k Winter/Drift Poutana
00 540is 6spd 223k (daily driver) new motor at 214k due to chain guide failure
Old 03-23-2011, 02:34 AM
ivan soldat ivan soldat is offline
Mein Auto: 2000 540i M6
Holly deal!!!!!!!!!!!!!!!
What a bargain
Old 03-23-2011, 02:49 AM
Westech's Avatar
Westech Westech is offline
Mein Auto: '00 Z-3 '06 325ixT
This now begs the question: WHAT'S THE PRICE ?
Old 03-23-2011, 06:26 AM
$658.28 That's six hundred fifty eight dollars and twenty eight cents!
Old 04-02-2011, 05:42 PM
The price thing is a mistake
and the lights are missing the front lens cover of the side marker light.
Unless you're okay with the bare bulb look on your turn signal PASS
Old 04-02-2011, 06:02 PM
Piston_broke's Avatar
Piston_broke Piston_broke is offline
What was that noise??
Mein Auto: E28 M535i, E30 323i
Seen these advertised before along with disscussions on them.
OP is up for quite some work getting a the 2 x lens in place for the blinker/indicator.
WTH don't they come with blinker lenses in place?
Also keen to see if the blinker lens holes are positioned exactly centred (horizontally) with the h/light bulbs. I hope they are.
The new price? I can only hope it's a mistake, 'cause he aint gonna move them at that.
Looking forward to installed light pics and experiences by the OP.
Old 04-02-2011, 08:10 PM
Ha, I started this thread (the OP) because I didn't notice the situation with the turn signal lens. I contacted another Ebayer who purchased them and they ended up getting rid of them because of the bare bulb thing.
I'm pre-facelift (6/2000), and THESE are actually the correct clear corners, which I should be receiving Monday: http://cgi.ebay.com/ebaymotors/CORNE...item2a0f52da7d
Old 04-02-2011, 08:28 PM
Good to see you're getting the correct lens. I'm sure the end result will be outstanding.
Were you able to return the first set?
Old 04-11-2011, 11:16 AM
Finally installed
First, the good...
On the car, they look like a million bucks:
OFF the car, they look like the $60 and shipping I paid for them... The injection molds used to make the housing left a tremendous amount of plastic flash behind, which took a lot of trimming with a razor knife to make fit. The pictures attached are the OEM lights used for example purposes. The red arrows indicate areas which took a lot of work.
ALSO - These covers came with a low-beam lens not designed for the HID projector. What I ended up doing was removing the HID lens from the OEM set, and switched it out. Pictured is the NEW, low-beam lens installed into the old, OEM amber light set.
I would NOT use these covers AT ALL in areas prone to bad climate. The fitment is not very precise, and the only reason I'm leaving them on for now is because they do LOOK awesome, and my car is garaged here in SoCal, so moisture isn't much of an issue.
These are just what you'd expect for $60 and shipping, and make an excellent TEMPORARY fix for cloudy lenses if you can't afford to go all-in on something high quality.
Which is what I will be doing in the near future...
Old 04-11-2011, 11:19 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
And so it goes...
