E90/E91/E92/E93 (2006 - 2013)
Old 05-22-2011, 10:40 AM
mbroadway mbroadway is offline
Mein Auto: 2011 335ix Sedan
Help with Coolant
Anyone who reads my blog knows that I've had a "low coolant" issue since delivery a week ago. A recent trip to the dealership showed the coolant lever to be full (the engine was warm). This morning I check on a cold engine and the level is below the "Minimum" mark.
I'd prefer to just take care of this myself without having to go back to the dealership. Can I just use some Zerex antifreeze that I've had in the garage for several years. It's not contaminated in any way. In fact, I don't think it's even been opened. Or should I just get some distilled water at Walmart and add a little of that?
Here's the background if you're interested. BLOG.
2011 335i xDrive
Space Gray | Black Dakota Leather
Sports Package | Premium Package
Cold Weather Package | NAV
Old 05-22-2011, 10:52 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
i would NOT mix coolant. some are not compatible.
if you need to top off you can add a little distilled water ( a cup or two will not throw off the freeze point enough to be a huge worry). i would only top it off with bmw coolant
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 05-22-2011, 12:20 PM
Froglet Froglet is offline
Mein Auto: Looking
You should contact your dealer as there should be NO COSTS to own, in those first 4 year/50K.
Old 05-22-2011, 12:38 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S65B40 Powered
What are you thinking?
08 E90M3 6MT Alpinweiss/Schwartz
Old 05-22-2011, 02:03 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
+1, have the dealer make this right for you.
Clearly, they have checked the level before delivery & maybe since you brought it in for them to look at. Something else is causing this. If you start draining fluid & adding fluid there's no reason to believe that will solve the problem & it may make matters worse.
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 05-22-2011, 03:50 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
BMW coolant is G48. The Zerex G-05 meets that spec. Don't use anything with high-phosphate or high-silicon content.
