Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 03-16-2011, 01:25 PM
Doug Gilbert Doug Gilbert is offline
Mein Auto: 2000 740il
00 740iL - Oil leaks
I have changed the valve cover gaskets and I still have a leak. What next?
Old 03-16-2011, 03:04 PM
balance balance is offline
Mein Auto: 97 740iL
First, you have to find the leak.
Where is it coming from? If you can't pinpoint it with a flashlight, degrease the general area around where the leak is coming from, let it dry, start the motor, and look for the leak. Try not to get water on any electrical components in the motor.
Keep in mind, that oil does not evaporate and what you are seeing could be residual oil left over from when the valve cover gaskets actually were leaking.
Old 03-16-2011, 08:42 PM
Danny Wolfe Danny Wolfe is offline
Mein Auto: 2001 740i
UPPER TIMING COVERS are almost always a source of an oil leak. Also check the oil lines from the filter housing to the engine block. And these cars almost always have a power steering hose leak. All of these are common on the E38.
Good luck!
Old 03-16-2011, 10:19 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
at most auto parts stores, you can buy flourescent liquid dye that is specifically for oil. they make it as well for ac systems and coolant. make sure its for oil if you do get it.
if you decide to use flourescent dye, again degrease the engine and go about running it to find where the leak is. you can usually buy an LED ultra violet light at the parts store as well which will illuminate the dye where the oil is leaking. this has been the easiest way to find oil leaks i've found. it could even be the power steering leaking. mine is and i thought for the longest time the engine was leaking. you may also use the dye for oil in the power steering. just make sure and read the directions on how much to use, its not much.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 03-18-2011, 07:04 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
Simple Green is great for doing this. It really lifts up grease & most of it will just wash off without any rubbing. I say wash off, but I don't use a hose to do this - I just fill a spray bottle with water & spray the Simple Green & grime off the engine. This is a pretty easy way to do a basic clean to see if that area is still leaking oil.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, Alpine DVD changer with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
