E34 (1989 - 1995)
Old 03-19-2011, 04:03 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Fan removal.
Is there a way to take the fan and shroud off without the holder? I have a 32mm wrench but no holder. Can it be done?
Sent from Joe's iPhone using BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 03-19-2011, 05:33 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Nothing that i could find . Its metric and a tight area.And its a hard set to find any where but online. I just buy them and sell them .Next time im keeping the set. $$50 http://cgi.ebay.com/ebaymotors/ws/eB...m=250790608837
Old 03-19-2011, 06:07 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I'm assuming you mean the fan/fan clutch assembly and not the fan shroud. I tried using a strap wrench and screwed my water pump pulley up. Lesson here, use the right tools for the job. The one shown in the ebay link is a good deal.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-19-2011, 06:16 PM
SawheadE34 SawheadE34 is offline
SawheadE34
Mein Auto: 1995 540i
I used a screw driver between 2 bolts and it was a success. Just be careful because you can mess up your pulley.
Sent from my DROIDX using BimmerApp
Old 03-19-2011, 06:24 PM
ricks5series ricks5series is offline
Mein Auto: 525i, Corvette, 530i
I did the same as Sawhead.
Wedge a narrow screwdriver against two bolt heads, push counter clockwise while turning the bolt clockwise.
Funny thing though, I can't seem to get mine off either. Haven't even started the engine after the rebuild so I don't understand why its so difficult.
I gave up on it yesterday and took a break from the car all together so go luck with your removal.
Old 03-19-2011, 06:33 PM
Jamafia's Avatar
Jamafia Jamafia is offline
Mein Auto: 95 BMW 525i
Since you all on the topic of fan removal can some pics be taken so the newbies can understand what you all talking about and see first hand how to do it..
Old 03-19-2011, 07:57 PM
BMR_LVR's Avatar
Humble E34 lover
Here ya go Jamafia,
Here is a pitcure of the tools, the screwed up pulley and the old and new pulley.
To get an idea of how it works, look at the picture of the screwed up pulley. You can see the large 32mm bolt on the shaft of the water pump and you can see the 4 small bolts holding the pulley on. Imagine using the hold down tool (the one with the holes and carved out sections at each end) to put over two of the bolts on the water pump pulley. Then you put the 32 mm wrench on the nut on the shaft of the water pump.
To loosen the nut, you must turn it in a CLOCKWISE direction since it has reversed threads. If the fan/fan clutch has not been removed in a long time, this can take some strength or a good rap of a hammer on the wrench.
lso, I have seen the screw driver method used before, but I would recommend loosening the four 10 mm bolts that hold the pulley on prior to using the screw driver. This way, if you happen to monkey the bolt heads up, you can remove them by hand.
Steve
ID:	271110   Click image for larger version
ID:	271111   Click image for larger version
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-19-2011, 08:26 PM
cager169 cager169 is offline
Send a message via AIM to cager169
Mein Auto: 2000 bmw Z3, 1999 bmw 528
I made my own tools to remove BMW fan clutch one to hold the bolts at the narrow position and another to remove the fan. They work wonders and these tools go about all over town everytime a friend needs to work on their car .
Old 03-19-2011, 08:54 PM
BMR_LVR's Avatar
Humble E34 lover
Pics Pics Pics NAO
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-19-2011, 09:28 PM
Originally Posted by BMR_LVR View Post
Pics Pics Pics NAO
Yeah, pics. I thought of making my own tool as well
Old 03-19-2011, 09:40 PM
for some reason i only have this one pic of the pulley wrench. this one holds the pulley. they are thin so that you can remove the fan without taking the air box off or anything no hoses nothing works great on the z3,e36,e39,e34,e30 i'll to to get a pic of them tomorrow from all angles. They look cheap but work wonders the other one is a thinner version of this one.
Old 03-20-2011, 11:50 AM
Did you ever get it undone, if not this link might help.
http://www.bimmerfest.com/forums/sho...ht=fan+removal
Old 03-20-2011, 07:31 PM
jjohansson5 jjohansson5 is offline
Mein Auto: E34 540i
Air will pop it right off, I use an air chisel and one quick rap and it spins right off. It may leave a little nick in the nut but I just reuse the same spot.
Old 03-20-2011, 10:26 PM
so i went out today and got my home made tools just for the pic
They are not perfect looking but they work great for me and since i've got them done i have NEVER been stuck with a fan again.
Old 03-20-2011, 10:44 PM
luckydog's Avatar
Nice hand forged steel too.
Old 03-21-2011, 11:51 AM
ConradMacDonald ConradMacDonald is offline
Mein Auto: 1990 525i
if your looking for a 32 mm thin wrench as they are hard to find go to a bike shop as they usually have them. Just in Case anyone else has this problem
Old 03-21-2011, 01:53 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I researched this and put all the results into the VERY best of E39 Links, but this one thread below will have more than you can find on your own and should be as applicable to the E34 is it is on the the E39:
- How to make or buy your own BMW cooling system overhaul fan clutch nut counterhold tools (1) (2)
Old 03-22-2011, 12:08 PM
fcpeuro's Avatar
fcpeuro fcpeuro is offline
Sponsor
Mein Auto: All BMW Everything
Hello -
I have come across different methods of removing the Fan Clutch. Some have used the screw driver method where you jam something like a large flat head in between the bolts to stop the water pump pulley from turning. I tried this while testing the idea one and broke the pulley. Mine was not metal, but rather a ceramic like alloy / material.
I would recommend getting the right tool for the job. A number of vendors provide Clutch Removal Tools - you would do wisely to get one slim enough to fit into that space. There are some GM tools that an do the job too.
The nut on the clutch is counter intuitive or reverse threaded as it is self locking based on the pulley rotation.
I am not 100% sure on this, but I thought the E34 and E39 use different clutches and pulleys - M60B40 vs. M62 engines. Where there is a difference is usually the nut size of the cluth itself and then the distance between the bolts on the pulley - that is often why you see pulleys tools with either an extended hole on one end or double sided tools with different spacing at each end.
Cheers,
Michael
Quality & Service, Guaranteed for Life
FCP Euro - European Auto Parts Online
sales@fcpeuro.com
Old 03-22-2011, 01:00 PM
Thanks Michael! Funny thing, the housing is no longer leaking and the new part arrived this am. Go figure!
