Old 03-20-2011, 12:55 AM
REPETE61 REPETE61 is offline
Mein Auto: 1998 528I
Sunroof stuck open on 1998 528I
Hi all;
I have researched other threads on this site but nothing has reallycompletly solved my problem. The sunroof on my car is stuck in the open (vent) position. I checked the fuses and they seem to be okay and I don't think that's theproblem anyway as I can hear the motor clicking when I have worked the switch. Owners manual mentioned if there was a power interuption to hold the button down for several seconds. I have not had a power interrupt but tried this anyway and nothing happened (except clicking in the motor). Owners manual also said to remove head console light trim and access and remove a vinyl plug where you can use an allan key to manually crank the sunroof. Did that and could see nothing but metal roof under the acces plug. No set screw!
Finally all the repair instructions I have read online mention everything from broken/debris in track or failed cassette and replacement but nothing much on motor replacement.
Also the insructions I have come across always mention to close the sun roof before disaasembling which is difficult to do as the sunroof is stuck open!
If you could direct me to a site or another thread that I may have missed I would greatly appreciate it.
Thank you.
Old 03-20-2011, 09:17 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Did you try pushing UP on the glass while jogging the button?
Sometimes this helps to get the locking pins moved out of its end travel.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 03-20-2011, 02:09 PM
Rustyzipper's Avatar
Rustyzipper Rustyzipper is offline
97' 540i
Mein Auto: 540iA
you know this happen'd to me like a week ago...was freaked out. I just played with the switch, it was cold and I'm sure was just cranky for sitting all winter closed.... when I did get it to free, I lubed everything good, and now works real smooth.
97' 540iA Build 4/96
73' 911 Targa Whale Tail
86 Coupe deville Convertible
Old 03-20-2011, 07:57 PM
thanks for the replies. we tried both solutions but still in the vent up position.
Old 03-20-2011, 10:17 PM
DHoang's Avatar
Gearhead
THe only option available is to remove the glass out of the car, and see what's keeping the rails from retracting. IT could be that one side of the rain gutter tray has disconnected itself and is jamming up the tilt mechanism.
Might be a good time to send your car into to a shop, b/c it's pretty easy to break these parts once the glass is removed.
Old 03-21-2011, 09:44 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I've never had this problem so I haven't done extensive research (as I would have had I had this problem) ... and I see you researched but you didn't say which threads you looked at so I will just provide you the 'standard' response to sunroof/moonroof stuck open problems:
- How to repair & reset the sunroof (1) (2) (3) & how to fix sun roof rattles (1) & how to test & fix moonroof leaks (1) (2) (3) (4) (5) causing water on the front passenger carpet & how to remove the roof headliner (1)
Old 03-22-2011, 08:52 AM
Thanks for the links Blue.
Some of them I did come across but none were able to solve the problem. It looks like I need to access the manual set screw via the motor through the sunroof switch/garage door opener panel. I am scred to break something taking the cover off as I can't seem to pry it off. Once I get in there at least I should be able to determine whats up with powere to the motor and manually crank the sunroof closed. Because the sunroof (sr) is in the tilt up position I can't visually inspect the track for breaks/blocks or access any of the screws to remove the sunroof. It all starts with actually being able to open/close the sunroof.
Old 03-22-2011, 09:32 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Originally Posted by REPETE61 View Post
...I am scred to break something taking the cover off as I can't seem to pry it off. Once I get in there at least I should be able to determine whats up with powere to the motor and manually crank the sunroof closed. .
Hope this helps:
Old 03-25-2011, 08:55 AM
Thanks for all your help. I did manage to get the switch/motor cover panel off prior to the above post. (just need to remember to work slow and easy with this stuff). Got access to the motor allan key screw to manually shutt the roof. Tried the switch again and it opened the slider to full and then continued to cycle through without stopping to open the vent and there it froze again. switch would not close it so I manually ratchetted it closed again. Tried again and same scenario. Went to the dealer and asked the young pup at the service desk whether it was the switch itself or if there is a part in the motor that doesn't recognize position of the sunroof and stop it in th open cycle. He told me that it may need a computer reset but couldn't tell me if it was motor or switch related, just a computer reset.
Gee, I wonder how much one of those costs?
Thanks again for all the help.
Old 03-25-2011, 09:06 AM
cn90 cn90 is offline
Have you looked through this DIY?
http://forum.roadfly.com/threads/11556388
Old 03-25-2011, 12:09 PM
Yes CN I saw it but I don't think it applies as nothing "snapped". The track and mechanism work fine it 's just the motor won't close it when it does a non stop open cycle to th event position. When manually closing it everything runs smooth.
Old 03-25-2011, 12:21 PM
So, are you thinking about a motor transplant?
Used motor on ebay is about $40-50.
Another option: remove your sunroof motor and perform surgery on it.
Old 03-25-2011, 12:51 PM
It doesn't necessarily sound like the motor to me, since it actually retracts the roof, if I'm reading his post correctly. It might just be a switch/sensor that governs the motor.
Old 03-26-2011, 05:01 PM
switch in motor is what I was thinking but not much information on it.
Old 03-26-2011, 06:35 PM
bluebee's Avatar
So that this information is easier to find in the future, I updated the bestlinks with the suggested URLs in this thread:
- How to repair & reset the sunroof (1) (2) (3) & how to fix sun roof rattles (1) & how to test & fix moonroof leaks (1) (2) (3) (4) (5) causing water on the front passenger carpet & how to remove the roof headliner (1) & how to free up a stuck open sunroof (1) (2)
Old 03-26-2011, 08:26 PM
97' 540i
Mein Auto: 540iA
.. Go Girl
Old 06-23-2014, 11:04 AM
Jetapache Jetapache is offline
Mein Auto: 1998 E39
Sunroof Stuck non responsive, in vent position, shut off car pushed down sunroof switch and it seemed to reset sunroof then it all worked fine...
Hi all;
Thank you.
