E46 (1999 - 2006)
Old 03-20-2011, 11:03 AM
errolcris errolcris is offline
Mein Auto: 1999 328i E46
Smells like burnt rubber
I notice sometimes when I'm driving on the freeway, smells like burnt rubber...Is this something that I should be concerned about or I need to replace something?? I also nitice this when I stop the car and smell it while engine is hot...NEED SOME OPINION ON THIS MATTER/CONCERN..THANKS!
Old 03-20-2011, 11:44 AM
jsconway jsconway is offline
Mein Auto: 325it
Sounds like your valve cover gasket is leaking and the smell is the oil getting burned off. Search here for DIY if you are capable. Sometimes you will see a whitish smoke also, typical of VCG leak. This is a fairly common E46 thing.
Old 03-20-2011, 02:08 PM
dmax56 dmax56 is offline
ocd and it shows
Mein Auto: '99 328i
or it is burning rubber...and it's a belt either slipping or getting hung up on a pulley with a bad bearing.
Any burning smells in your car, you'd typically want to be concerned about...unless it's a cigarette or blunt that you're smoking!
Old 03-22-2011, 03:21 PM
thanks for the infoo! Will probably replace the valve cover gasket... How much does it cost to have it replaced anyway? Any idea?? I could buy the part for atleast less than $30 but what about labor??
Old 03-22-2011, 08:23 PM
Mein Auto: 325it
I paid an indy mechanic $300 to replace the VCG and sparkplugs. I think if I was doing it again I would use some of the excellent DIY's found here to tackle myself.
Old 03-22-2011, 08:48 PM
moiz21's Avatar
moiz21 moiz21 is offline
Mein Auto: '99 323i 5-Spd
Do it yourself. If you have a basic set of tools, you're better off saving the 300-500$ a shop may charge you. It's not nearly as hard as you may think. Just time consuming if it's your first time.
Old 03-23-2011, 12:25 AM
Thanks for the advise.. appreciate it!
Old 12-26-2012, 06:23 PM
bimmerpepi3 bimmerpepi3 is offline
Mein Auto: BMW 325xi
After replacing the valve cover gasket did the smell go away?
Old 12-27-2012, 05:25 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
These references may help:
- How to replace the M54 valve cover gasket (1) (2) (3) (4) (5) (2004 E46 video) (another E46 video) (yet another E46 video) & which VCG brand to buy (1) (2) & what VCG lubricants to use (1) & how to replace the timing chain tensioner and rail guide on the I6 (1) & on the M62 (1) & on the M62TU (1) (2) (3)
Old 12-27-2012, 05:34 PM
rgk330i's Avatar
rgk330i rgk330i is offline
Mein Auto: 2013 335i M-Sport
Also consider replacing the oil separator valve. Although this is a relatively difficult job, more than likely it is what is causing your valve cover gasket to leak. Not much gained by replacing the VCG only to have it start leaking again.
Sent from my Galaxy Nexus using Bimmer App
2013 335i M-Sport, ED May 2013
Old 12-28-2012, 10:28 AM
SixPotPsyco SixPotPsyco is offline
Mein Auto: 320i se
FPMSL......
