Catastrophic water pump faliure! - Bimmerfest - BMW Forums
Old 03-20-2011, 09:53 PM
holacomoestas? holacomoestas? is offline
Mein Auto: 2001 530i 5spd Auto
Sup Ya'll?
This happened a few months back, but I've decided to share my experience.
At about 159k my car began overheating. It actually went into the red zone twice, the first time I was about 5 miles from home so I just let the car cool down completely and drove it home.
Upon arriving I deduced that my fan clutch was shot. It spun freely for about 2 revolutions before coming to a stop. No bueno.
So I replaced that, let the car warm up to OT, and drove it 5 miles around my neighborhood. Everything was great and no overheating, no temp fluctuation, ect.
The next day I drove to school my temp creeped into the red zone AGAIN. So I pull over and the sweet smell of coolant hits my nostrils. By this time I'm infuriated, I called a tow truck and took it home 16 miles from downtown SA.
Once at home, I disassembled and inspected my entire cooling system. No cracks in the hoses, radiator held pressure, expansion tank was sound, thermostat was in working order, head gasket was fine. And then I pull out my water pump.
I've attached a picture of it below, just wondering if anyone here has had a similar experience with their E39's such as this one.
Old 03-20-2011, 10:07 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
cn90 has long been an evangelist for replacing everything in the cooling system. You should check out his threads in the "Best Links" sticky at the top of the E39 page. He also recommends a water pump with a metal, not plastic, impeller.
Old 03-20-2011, 11:09 PM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
That was a defective pump
Plain and simple. I ask did you do a proper coolant 'bleed', sounds like you may have had some air in your system...
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
Old 03-20-2011, 11:37 PM
BMC530i BMC530i is offline
Mein Auto: 2003 530ia 2003 X5 3.0ia
Extreme example of obsolescence at its best.
Old 03-21-2011, 04:13 AM
Jimmys 530i Jimmys 530i is offline
Wow, that's crazy. I have never seen a water pump fubar like that.
Old 03-21-2011, 04:27 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Were you able to fish all the broken plastic pieces out? What the hell did BMW engineers thinking when they decided to use plastic impeller in their WP!
Old 03-21-2011, 04:46 AM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
They were probably thinking about how much money their service departments would make replacing neglected and detonated plastic-impeller water pumps.
Just a theory of course.
Old 03-21-2011, 04:50 AM
cn90 cn90 is offline
BMW uses plastic to save weight.
Here is another example:
BTW, holacomoestas? you are "late to the party" LOL.
The cooling system has been discussed here 1000 times.
There is some overlap between 1997-98 and 1999-2003, so read it up.
1997-98 Info "cn90":
http://bimmerboard.com/forums/posts/199986
1999-2003 Info by "aioros":
http://www.bimmerfest.com/forums/sho....php?p=5040366
Old 03-21-2011, 04:51 AM
16valex's Avatar
But that contradicts the old German mentality of "over engineered"
Old 03-21-2011, 04:53 AM
BTW, The "New" WP in your first post looks like plastic impeller!
Check to be sure it is NOT plastic or some composite material.
I have been using "HEPU" brand WP now for 5 yrs, zero problems.
Old 03-21-2011, 08:02 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Quite common failure mode.
Old 03-21-2011, 08:15 AM
first540i's Avatar
first540i first540i is offline
my first bmw
Mein Auto: e39
this kind of problem happens all the time.
even the aluminum or other metal contents does the same thing
Old 03-21-2011, 08:56 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I've read a LOT (scores of articles) on the BMW water pump failures.
It is not all that common, but, common enough for the original composite (i.e., plastic) waterpump impeller to disintegrate like that. It says so right in these videos below of cooling system failures.
The metal impeller waterpump is known to fail in a different way (bearings) but I don't remember seeing a single example of the metal impeller water pump failing in the way that the plastic pump fails.
End result ... don't ever buy a plastic-impeller water pump if you can help it.
To help others, I'm going to crosslink this thread into the pictorial look at BMW cooling system failures ... to help others in the future.
- Pictorial look at typical E39 cooling system failure modes (1)
Old 03-21-2011, 09:01 AM
bluebee's Avatar
In one of these two sequential videos, they talk about the plastic impeller disintegrating inside the BMW engine ...
PART I:
PART II:
Old 03-21-2011, 09:12 AM
agent15's Avatar
agent15 agent15 is offline
Mein Auto: 87 325is, 02 530i Sport
Here's one out of an E36, posted by one of the guys on our local Euro car forum. It's a Graf, which has a tack-welded impeller. I put a Geba in both my E30 and my E39, one of the reasons being that the entire impeller is cast.
Graf with 5000 miles on it:
Cast impeller on the Geba:
While it's true the metal impellers aren't immune to failure, the ones made of a single (cast) piece are less likely to - at least the impeller itself.
Originally Posted by Fudman View Post
For me, the e39 is the ... best balance of luxury ... performance ... good looks and class. Sort of the Catherine Deneuve of cars, if you get my drift.
Old 03-21-2011, 09:27 AM
bluebee's Avatar
Very interesting. And ugly! And scary too!
I have whatever OEMBimmerparts sold me (it's metal, and it starts with a "G" but I don't remember if it's Graf or Geba.
I'll add THIS picture to the pictorial look at BMW cooling system failures!
Thanks for the edification!
Old 03-21-2011, 08:32 PM
I did bleed the cooling system correctly,
And for the DIY I used cn90's post.
Props!
I can't believe the stock internals held up so long! Don't these things go out at around 100k?
And believe me, I would have LOVED to overhaul my entire cooling system but I am in a bit of a financial hole right now.
Ends are a little tight around here. -_- Heck, if I had money like that I'd fix all my bugs!
And yeah, it's an OEM part. Next time around I'll look into getting a WP with metal impellers. (;
Old 03-22-2011, 05:26 AM
agent15's Avatar
At 160K I'd be surprised if that was the original WP in there. I believe BMW calls for replacement every 60K, so hopefully it was at least #2. Either way, at least you now have a bit more peace of mind about your cooling system.
Old 03-22-2011, 06:59 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
oh man that is crazy how bad it looked. glad you replaced it.
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 03-22-2011, 07:09 AM
...And believe me, I would have LOVED to overhaul my entire cooling system but I am in a bit of a financial hole right now.
At least you changed the most important part: the WP.
With tight financial situation, save up money and do an overhaul later, but don't ait too long.
Overheated engine = $4K damage.
Old 10-17-2012, 04:04 PM
Scrubber Scrubber is offline
Mein Auto: VW
Recently fitted a new HEPU water pump. Metal impeller (looks like brass). Looked good quality to me (Made in Germany stamped on it.)
Interesting webpage discussing the plastic impeller water pumps. (Old Durethan composite, vs newer Polyphenylene) but I preferred to go with the metal impeller of the HEPU.
http://www.blauparts.com/vw_water_pu...ntroversy.html
Old 10-18-2012, 09:20 AM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
Mine broke at about 70K and was replaced with a metal impeller. No problems since and now at 117K. But, I replaced the entire rest of the cooling system as soon as I bought the car three or so years ago.
Old 10-18-2012, 10:46 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
My Graf with a metal impeller is going on 35K miles with no issues.
Old 10-18-2012, 05:47 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
HOLY MOLY!!!
Does anyone know if anyone makes a metal impeller for the 540i? Last time I checked, it did not exist.
Old 10-18-2012, 07:58 PM
waehrik waehrik is offline
Mein Auto: e39 530i/5, e28 535i
I would actually prefer a failure by separated pump impeller over a siezed bearing. Of course that does not include a grenaded impeller as plastic bits would be scattered everywhere.
It's sad that we would have to make the choice.
But on my e28 the relatively new (replaced by the PO 15k miles and 20 years ago) water pump bearing suddenly sprung a leak at the shaft seal and promptly siezed, offering no cooling capacity at all, an immediately broken alternator/WP belt, and a siezed engine driven cooling fan. That's an immediately pegged gauge and roadside stop.
I can understand the cause for more of the bearing failures on metal impellered pumps since there is a greater amount of weight out of balance at the other end. I cannot believe that a simple cast pump like the Geba or -worse- tack welded Graf is well balanced. That amount of metal flinging around can could cause a problem on a bearing that is already fairly heavily loaded on one side only from the belt system. There is not much separation between the bearings to be able to counteract the significant moment arm created by the belt/pulley. That coupled with an unbalanced metal mass is not a recipe for longevity. I would think the Graf would be the worst as there is no way the tack welded fins are even at a consistent angle. That would slightly vary the load on the water pump as it spins, introducing even more stress on the bearings.
I'm sticking with the plastic "updated composite" impeller Saleri pump for the aforementioned reasons. I changed it out when I got the car a year ago at 60k and will do so again at 120k. It's cheap and extremely easy to replace. With biannual fluid changes I have not seen evidence of an early demise of a composite/plastic water pump. Most of the failures are from people who are at high mileages on the originals or from people who never changed the coolant, thus making it more caustic and circulating around coarse debris. cn90's example above is not only a different impeller material but is obviously degraded from extended exposure to a harsh environment. You can see how brittle the plastic has become. The OP's could well be original. With no timing belt to replace they can get neglected by an owner who buys into the "lifetime" advertising of BMW. It obviously lasted the lifetime that he had the car, so why should he care?
