E30 (1982 - 1993)
Old 03-20-2011, 11:44 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
broken shock mount?
am i right in thinking this is a broken shock mount or do i just need to tighten that metal plate down so it contacts the rubber?
This is an 8 second video of the rear shock mount while bouncing the car..
thanks
Old 03-21-2011, 01:04 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
She's toast. Get BMW oem ones or solid ones. The repcos ones are **** don't even consider it. I have oem
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 03-21-2011, 11:49 AM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
thanks
Hahaha yeah dude that's beyond blown
Old 03-21-2011, 01:44 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
Get the oem vert mounts.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 03-21-2011, 05:50 PM
a930rocket a930rocket is offline
Mein Auto: 1991 318is
Is it just me, or was that washer upside down?
I guess I'd flip the washer before I sprung for new bushings.
1991 318is
1987 911 Turbo
Old 03-21-2011, 07:08 PM
Krumchev2's Avatar
Straight Bimmin
You could do that but just by looking at it, that bushing looks trashed
Old 03-22-2011, 03:01 AM
I'm pretty sure it's ipnstalled the correct way around, but I could be wrong, best to check pelican writeup or something
E30 above Sold
Old 03-22-2011, 06:27 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Washers correct, flip it and it will deform. I use the JT auto ones, cheap and last
fo eva.
E30 vert and E46 ones are the oe upgrade.
Old 04-10-2011, 06:10 PM
ok cool got 2 new shock mounts on the way
just want to check what else i need..
2 x gaskets (one each side)
2 x locking nut for the top of the shock (one each side)
what about the two nuts on each side that hold the shock mount in, are they self locking or can i just reuse them?
and is it ok to reuse the lower shock absorber mounting bolt?
Old 04-10-2011, 07:16 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
you have locking nuts on your shocks ? all you should need is the mount. the gaskets really dont do much(if anything) at all.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-10-2011, 09:24 PM
according to pelican i do?
http://www.pelicanparts.com/bmw/tech...ock_mounts.htm
'Now slide the new shock mount over the shock rod and place the large washer over the top of the mount and install a new 17mm locknut.'
Old 04-10-2011, 09:39 PM
fcsteve's Avatar
610EUROs
never heard nylon nuts called locknuts. ive reused nylon nuts dozens of times. ive run my bilsteins through 3 e30's without changing the nuts. the bolts for the shock mount sides are not nylon nuts.
Old 04-11-2011, 08:22 AM
Yes on the lower bolt.
Did you get the E36 spacer plate as well? It's my understanding that it acts as a reinforcement...
http://www.pelicanparts.com/cgi-bin/...30%38%30%22%3E
1991 318is
1987 911 Turbo
Old 04-11-2011, 11:49 AM
We call them locknuts here. Language thing again ha
That's correct it does in theory, but you can make your own mind up as to whether you think you will need it. I personally wouldnt and haven't bothered
E30 above Sold
Old 04-11-2011, 11:53 AM
On Top
Do not re use:
Crank bolt
Head bolts
Guibo nuts
upper shock mount nuts
upper and lower balljoint nuts
Front and rear shock/strut to mount nuts
and there are many many more. a good rule of thumb is, if it is nylon lined or oval discard. Most high torque to yield fasteners on the engine is also likey one time use as well.
At least that's what they teach you in STEP class.
Old 04-11-2011, 07:39 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
always heard them called nylocks...no to be reused, but it happens all the time.
Old 04-12-2011, 05:31 AM
On Top
It does, and you CAN get away with it SOMETIMES. I personally don't feel confidence sending young lady out on new control arms and front struts with re used one time hardware. I don't want to be the reason her lower balljoint came apart and killed her and the family of 4 traveling behind her.
Some people wash zip lock baggies and reuse styrofoam plates and plastic cutlery. Doesn't make it right though.......
Old 04-12-2011, 05:44 PM
eieio4tn's Avatar
BMW...riceless
lol...that's sick...
cheapness never pays off. reusing nylocks in a boat transmission makes one a good swimmer. ask me how i know.
Old 04-15-2011, 12:06 AM
i once saw someone with a plastic bag on their leg to protect their cast, the next day i swear it was recylcled as their lunch bag..wtf
anyway the mounts arrived, it was pretty easy by looking at them to see how totally shot my current one is, so the only nyclok nut i have to worry about in this job is the one on top of the shock right?
i didnt go for the reinforcement plates, im a student and money is tight + its only a 320i, i just want to keep it in nice running condition and save all the modifying / improving for the day when a get a 325i
Old 04-16-2011, 05:34 AM
On Top
Screw that motor swap the car you got.
Old 04-16-2011, 08:55 AM
E30 F34R's Avatar
E30 F34R E30 F34R is offline
Metric Mechanic
Mein Auto: Polly(My '87 track ****)
If you close your eyes while the video plays it sounds like you're doing it xD
Old 04-18-2011, 08:24 AM
adamsmj adamsmj is offline
Mein Auto: BMW 320i
I have the exact same issue. Would love some more info on parts required. If it's not too hard I may attempt to DIY.
Old 04-19-2011, 10:14 PM
it seems all you need per side is:
1 x shock mount
1 x gasket
1 x lock nut for the top of the shock
this is a pretty good diy article:
im just waiting on the gaskets and locknuts
Old 04-20-2011, 03:17 AM
Buy my e30 tim. It's listed on bimmerspport and trade me. Shameless plug lol
E30 above Sold
