Old 03-21-2011, 09:35 AM
saurabhwise saurabhwise is offline
Mein Auto: 2007 Z4 - E85
Angry Z4 2007 iPhone 4 bluetooth troubles
Hello All,
Has anyone paired an iPhone 4 to Z4, 2007 ?
I tried several times but it wont pair any help!!!
Old 03-21-2011, 09:47 AM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
Originally Posted by saurabhwise View Post
Hello All,
I have not tried mine yet. My iPhone 3GS paired fine, though.
Have you paired other phones to make sure you are doing it correctly?
Correct code entered? I think there is a fixed code depending on your car.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 03-21-2011, 10:14 AM
Swanicyouth's Avatar
Swanicyouth Swanicyouth is offline
Mein Auto: M Roadster
I paired my IPhone 4 to my 08 M Roadster no problem. It all hinges on the code you need to pair it. Every Z has it's own code. It should be in the owners manual on a separate sheet of paper. I heard if the code is missing, you have to locate the blue tooth module in the car and it's on a sticker on the module, but that is second hand info. If you just need to know the procedure, look online for the telephone and communication manual that comes with the car, it has to be posted someplace. If you can't find it, repost such and I will locate mine and post the procedure. My IPhone recognizes the car as BMW54xxx. Once paired, it should connect every time your car is started and your phone is in range ( as long as your Bluetooth is on).
Old 03-21-2011, 11:19 AM
madurodave's Avatar
BMW Enthusiast!
When paired, it shows the last few digits of your VIN.
The Bluetooth code is on your module as a backup if needed.
Madurodave
Member of BMWCCA!
Old 03-21-2011, 01:41 PM
Psygnosis Psygnosis is offline
Mein Auto: 2004 Z4 3.0i Sport
Your car is equipped with BMW assist right?
Old 03-21-2011, 10:08 PM
VitaminT VitaminT is offline
Mein Auto: 06 M Roadster
Mine paired up without any issue.
Old 03-22-2011, 06:00 AM
I have the assist and the code on a separate card with the manual. I'll try again as my research shows the car is only able to pair in first 45-60 secs of ignition.
Thanks guys I'll post of it works.
Old 03-22-2011, 03:32 PM
Now it detects the car but says the pin is invalid. Any notes ?
Old 03-22-2011, 06:33 PM
Check the module and make sure you are using the right code. Try putting an extra zero before or after the pin. Try pairing another iPhone with the same code and see if it works. Disconnect the car battery for a minute, then do a full shut down and restart on your iPhone - then try to pair again. My IMac lost its bluetooth one day - 2 hrs later I fixed it by just rebooting everything. Bluetooth sometimes can be funny. Try using all zeros for the pin. If all else fails, maybe your car had the bluetooth module replaced at one point and it changed the pin. In that case, I guess the correct code should be on the module. A last resort, if you bought your car at a BMW dealership ask them to help you pair it. My salesman paired my IPhone as part of the car delivery tutorial. Even if not, I can't imagine they would charge to much to help you pair your phone. Does the phone pair with other devices?
Old 05-11-2011, 11:10 AM
WestCDA WestCDA is offline
Mein Auto: 2006 Z4 3.0si
For those of you using the factory bluetooth with the iphone 4 or 3GS, can you connect to the iphone's voice commands using the steering wheel 'phone' button and dial using the iphone directory (and use other iphone voice commands)? Or are you restricted to making calls using the BMW voice recognition, and the phone directory entries you have set up on the factory TCU?
Old 05-11-2011, 11:31 AM
madurodave's Avatar
BMW Enthusiast!
Using pin code shown on your card? PK = 1234 (or whatever your pass code is).
Madurodave
Member of BMWCCA!
Old 05-11-2011, 11:32 AM
madurodave's Avatar
BMW Enthusiast!
The BMW one only, as far as I know.
Madurodave
Member of BMWCCA!
Old 05-11-2011, 07:52 PM
I know I am able to browse my contacts on my phone using the NAV screen menus. Not sure about voice dialing as I haven't used it.
Old 10-31-2014, 11:39 PM
orkward orkward is offline
Mein Auto: 2.5 Z4 roadster Si
I can't seem to connect my iPhone 5s to my Z4.
We're all 2007 Z4s fitted with bluetooth to connect to the factory fitted business CD?
If not Is it possible to retro fit a factory bluetooth device if I don't already have one?
& which alternative should I get if not?
Thanks in advance for any help!
iphone, iphone 4, iphone bluetooth
