Old 03-05-2016, 07:22 PM
Lorado69 Lorado69 is offline
Mein Auto: 1997 523i
Reconnecting trunk to Central Locking
Hello fellow BMW fans!
My younger brother disconnected the trunk of my 1997 523i from the central locking system by using the key and turning it completely to the right and now I can't figure out how to reconnect the trunk to the central locking system. I've tried all sorts of things with the key and I know there is nothing wrong with wiring or parts.
The user's manual only shows you how to disconnect the trunk from the central locking system but does not show how to reconnect it.
I'm sure it is a simple fix. Any advice would be most appreciated! Thank you!
Old 03-05-2016, 07:28 PM
TheAngryBear's Avatar
TheAngryBear TheAngryBear is online now
Mein Auto: 540iA Sport 03/03 GS56111
Turn it all the way to the left. Hit the 90 mark (parallel to the ground). That should do the trick.
Old 03-05-2016, 08:47 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
To keep the trunk connected to central locking...just keep the trunk lock cylinder vertical ( | ).
It is simple as you said. If you keep the trunk lock cylinder horizontal ( -- )...then the trunk is in valet mode & not connected to central locking and cancels the interior trunk release switch. See SECURE SEPARATELY from owners manual below:
{The interior trunk release WILL NOT WORK when trunk is separated...aka in valet mode}
Q {BMW CCA Member #191509}
(SOLD)
Old 03-05-2016, 10:57 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Rtfm!
Looks like the site does not like acronyms!
Old 03-06-2016, 12:03 AM
Thank you, both of you. However, the first answer only opens the trunk manually and does not seem to re-connect it to central locking.
As for the second answer, my lock is always in vertical mode but still (since whatever my brother did) does not re-connect to the central locking system.
I'm thinking about disconnecting the battery and then reconnecting it. Maybe that will reset the system?
Old 03-07-2016, 03:11 PM
Thanks for the tips. It is in vertical mode all the time. I tried disconnecting the battery and connecting it again - that didn't work either.
The trunk mechanism is working fine. The other guy told me to turn the key all the way to the left, parallel to the ground, but that only unlocks the trunk manually.
Any more advice would be appreciated! It's a real hassle at the moment. Then again, old cars didn't even have central locking...
Old 03-07-2016, 03:28 PM
You may have a failed trunk actuator.
Does the actuator make noise when you try the remote function?
Old 03-07-2016, 04:14 PM
The remote function works normally when I use the "trunk unlock" button on the remote. But when I use the "unlock car" button, it does not trigger the trunk (and there is no sound). It was working fine before my brother opened it manually.
Old 03-08-2016, 09:08 AM
QSilver7's Avatar
I'm slightly confused by the statement above...may I ask just a slight clarification?
Normal operation is...if the trunk lock cylinder is in the vertical position ( | )...it should be connected to central locking. Thus, when you unlock or lock the vehicle...the trunk is in the same mode as the doors.
But when you unlock the doors (manually or with the remote key)...the trunk is accessible & unlocked...but to "OPEN" the trunk, you still have to press the trunk lock cylinder inward...or press the trunk UNLOCK button on the remote.
Are you saying it doesn't operate this way?
(SOLD)
Old 03-08-2016, 10:06 AM
pudl's Avatar
pudl pudl is offline
Mein Auto: E39 530dAT 2001 M-Sport
Just a quick guess... frayed wire to the lock.
EDIT: Or... since I don't know how the lock and the electrics interact... a malfunctioning lock. Someone should find the WDS diagram. Wink, wink, nudge, nudge...
Old 03-08-2016, 02:22 PM
Yes, that is normal operation and it is what is not happening with our car. It is in the vertical position but not connected to the central locking.
As for the trunk unlock, the button on my remote that unlocks the trunk also opens it (I do not need to pull the trunk handle). This has always been the case with our car.
I need to take it to an auto electrician because the airbag warning light is on most of the time for some reason, so I'll get them to have a look.
Thank you for your time!
523i, boot, central locking system, trunk
